NACA 0012 k epsilon LRC - convergence problem
Old   May 15, 2017, 07:14
Question NACA 0012 k epsilon LRC - convergence problem
Ajeje Brazov
Bernoulli666 is on a distinguished road
I am trying to run the NACA0012 validation case with k-epsilon model. The data that I am using are in the folders attached. I am not reaching convergence as you can see in the picture. I am using the mesh given by the NASA website, with size smaller than 449-129 I reach convergence but results are not accurate, with mesh size higher than 449-129 I have the residuals as in the picture. Which parameters do I have to change? I tried increasing and decreasing relaxation factors but it does not reach convergence anyway.
File Type: jpg Screenshot from 2017-05-15 12:16:36.jpg (96.7 KB, 60 views)
Bernoulli666 is offline   Reply With Quote
Old   May 15, 2017, 09:01
Mikko
Flowkersma is on a distinguished road
k-epsilon turbulence model uses wall functions and therefore the first cell wall distance should be y+ > 30. The meshes from NASA have y+ < 1 and therefore should not be used with standard wall functions.
Flowkersma is offline   Reply With Quote
Old   May 15, 2017, 09:33
Ajeje Brazov
So which kind of boundary conditions do I have to use for k epsilon and nut in the airfoil?
I read in the forum that, if y+<1, zeroGradient is ok. Could you please explain me why?
Thank you
Old   May 15, 2017, 10:01
Mikko
Basically, what I am saying is that you cannot use that mesh with k-epsilon model. However, this is not exactly true because there are also enhanced wall functions which can be used with y+<30. I think I have read somewhere that enhanced wall functions were also recently implemented to OpenFOAM but I would still suggest to use some other turbulence model such as k-omega SST or Spalart Almaras.
naca0012 k-epsilon
[ICEM] issue occur after extrude 2D airfoil mesh and convergence problem in CFX shiyun ANSYS Meshing & Geometry 4 May 9, 2012 20:55
Submerged fin, Convergence problem supermouniette FLUENT 10 July 6, 2009 11:47
Epsilon Convergence Trouble Carlos FLUENT 4 August 27, 2007 12:22
CONVERGENCE PROBLEM - oil boiler MM FLUENT 1 February 15, 2007 06:24
convergence problem with SIMPLER NURAY KAYAKOL Main CFD Forum 1 February 24, 1999 14:43
