What is this FOAM warning: Unknown matrix type combination means?
Old   May 13, 2017, 21:46
Question What is this FOAM warning: Unknown matrix type combination means?
Di Cheng
chengdi is on a distinguished road
Hi, everyone
I got the following msg when I turned on DebugSwitches in rhoSimpleFoam.
Here is part of the log:
Starting time loop
forces forces1:
    Not including porosity effects
forceCoeffs forces1:
Time = 1
--> FOAM Warning :
    From function void Foam::lduMatrix::operator-=(const Foam::lduMatrix&)
    in file matrices/lduMatrix/lduMatrix/lduMatrixOperations.C at line 286
    this : diagonal:0 symmetric:0 asymmetric:1
    A    : diagonal:0 symmetric:0 asymmetric:0
   Normalisation factor = 438.8332991218
DILUPBiCGStab:  Solving for Ux, Initial residual = 0.9999999196256, Final residual = 9.665819444403e-10, No Iterations 3
   Normalisation factor = 111.6043953712
DILUPBiCGStab:  Solving for Uy, Initial residual = 0.9999999122811, Final residual = 6.521155555565e-10, No Iterations 3
--> FOAM Warning :
   Normalisation factor = 25947.66551949
DILUPBiCGStab:  Solving for e, Initial residual = 0.9999966481434, Final residual = 3.3088000014e-10, No Iterations 2
--> FOAM Warning :
    this : diagonal:0 symmetric:1 asymmetric:0
   Normalisation factor = 46.30762557178
DICPCG:  Solving for p, Initial residual = 0.9999999949062, Final residual = 9.456697817244e-11, No Iterations 103
--> FOAM Warning :
   Normalisation factor = 69959.97350504
DICPCG:  Solving for p, Initial residual = 0.0007458501311764, Final residual = 8.84361415006e-11, No Iterations 69
time step continuity errors : sum local = 7.073776712562e-12, global = 1.62754446914e-13, cumulative = 1.62754446914e-13
rho max/min : 2.632186229715 1.93075973848
ExecutionTime = 0.08 s  ClockTime = 1 s
SIMPLE solution statistics:
    U: tolerance = 0.9999999196256 (1e-08)
    p: tolerance = 0.9999999949062 (1e-08)
forceCoeffs forces1 write:
    Cm    = 1.668416584837
    Cd    = 2.102251277892
    Cl    = 6.004158371472
    Cl(f) = 4.670495770573
    Cl(r) = 1.333662600899
fieldMinMax fieldMinMax1 write:
    min(mag(U)) = 0 at location (0.9995180946345 -6.8329751524e-05 0.5)
    max(mag(U)) = 59.0424609648 at location (0.09116378316311 0.04698392201502 0.5)
    min(p) = 166205.3080159 at location (0.948828058586 0.007031629229023 0.5)
    max(p) = 226738.9321484 at location (0.001180689701005 -0.005843479396189 0.5)
    min(T) = 299.6079419896 at location (0.1926696369711 0.05614551067966 0.5)
    max(T) = 300.3763734475 at location (0.9966139497257 -0.0004883533836858 0.5)
    min(nuTilda) = 0 at location (0.9995180946345 -6.8329751524e-05 0.5)
    max(nuTilda) = 2.604143606306e-05 at location (398.1856161464 -4.245372262308e-06 0.5)
Time = 2
Any idea what is wrong? How could a matrix being either symmetric or asymmetric?
chengdi is offline   Reply With Quote
Old   May 13, 2017, 22:34
Di Cheng
I just tried to use DDD to locate the warning. It is in the code like this:
fvScalarMatrix EEqn
fvm::div(phi, he)
he.name() == "e"
? fvc::div(phi, volScalarField("Ekp", 0.5*magSqr(U) + p/rho))
: fvc::div(phi, volScalarField("K", 0.5*magSqr(U)))
- fvm::laplacian(turbulence->alphaEff(), he)
fvOptions(rho, he)
more specific, it is in the operator==() . I did not compile the full version of debug, So I cannot follow into it now.
openfoam, warning
problem during mpi in server: expected Scalar, found on line 0 the word 'nan' muth OpenFOAM Running, Solving & CFD 3 August 27, 2018 05:18
Floating point exception error lpz_michele OpenFOAM Running, Solving & CFD 53 October 19, 2015 03:50
[Other] How to create an MRF zone ? aminem OpenFOAM Meshing & Mesh Conversion 2 December 8, 2014 11:45
[blockMesh] non-orthogonal faces and incorrect orientation? nennbs OpenFOAM Meshing & Mesh Conversion 7 April 17, 2013 06:42
compressible two phase flow in CFX4.4 youngan CFX 0 July 2, 2003 00:32
