NACA 0012 k epsilon turbulence intensity and nut |
May 9, 2017, 08:43 |
Ajeje Brazov
Rep Power: 9 |
Hi everyone,
I am trying to run the case NACA0012 with the mesh downloaded from the Langley research website using k epsilon turbulence model. The website doesn't provide any data neither results for such model. Could you please explain me how do I have to calculate the turbulence intensity for running the case. I used 0.0052% as in the k omega SST case but the results are not good. I also don't know how do I have to calculate nut. I used nut=0.009 as in the k omega SSt case but I don't know if it's correct. Thank you. |
naca 0012, nut, turbulence intensity |
