floating point exception (core dumped)
Old   May 5, 2017, 15:20
Default floating point exception (core dumped)
Justin Maris L. Natividad
Juzzvy is on a distinguished road
Good day. I am currently running a simulation in openFoam using the simple method, with the kEpsilon turbulence model. The run was going fine, but after I tried to experimentally change the wind direction, this error appears
#0 Foam::error:rintStack(Foam::Ostream&) at ??:?
#1 Foam::sigFpe::sigHandler(int) at ??:?
#2 ? in "/lib/x86_64-linux-gnu/libc.so.6"
#3 Foam::GAMGSolver::scale(Foam::Field<double>&, Foam::Field<double>&, Foam::lduMatrix const&, Foam::FieldField<Foam::Field, double> const&, Foam::UPtrList<Foam::lduInterfaceField const> const&, Foam::Field<double> const&, unsigned char) const at ??:?
#4 Foam::GAMGSolver::Vcycle(Foam::PtrList<Foam::lduMa trix::smoother> const&, Foam::Field<double>&, Foam::Field<double> const&, Foam::Field<double>&, Foam::Field<double>&, Foam::Field<double>&, Foam::Field<double>&, Foam::Field<double>&, Foam::PtrList<Foam::Field<double> >&, Foam::PtrList<Foam::Field<double> >&, unsigned char) const at ??:?
#5 Foam::GAMGSolver::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const at ??:?
#6 Foam::fvMatrix<double>::solveSegregated(Foam::dict ionary const&) at ??:?
#7 Foam::fvMatrix<double>::solve(Foam::dictionary const&) at ??:?
#8 Foam::fvMatrix<double>::solve() at ??:?
#9 ? at ??:?
#10 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6"
#11 ? at ??:?
Floating point exception (core dumped)
I don't understand yet what could have gone wrong. the previous run it was ok, though I changed the inlet and outlet so as to suit with the wind direction I am aiming at. Thank you for the time and your suggestions are appreciated
Juzzvy is offline   Reply With Quote
Old   May 5, 2017, 15:48
Joshua
Joshua14 is on a distinguished road
Juzzvy,
Your "Osteam" error most likely is related to what you changed your boundary conditions to. Double check to see that they are correct or that you don't need to add additional changes based on the changes you made.
Feel free to post your old and new boundary conditions so that people can visually look at what you have.
Joshua
Joshua14 is offline   Reply With Quote
Old   May 5, 2017, 16:04
Joshua,
Basically I only changed the wind direction, I attached the boundary condition for U which worked (2.83 -2.83 0) and the other that didn't (2.83 2.83 0). I wanted to use the latter, since it will exhibit the northwest direction which I was aiming for. I'll also put here the other boundary conditions/ Sorry as of now I can't attach it due to some reasons
| \\ / O peration | Version: 3.0.1 |
| \\ / A nd | Web: www.OpenFOAM.org |
| \\/ M anipulation | |
FoamFile
version 2.0;
format ascii;
class volVectorField;
object U;
Uinlet (2.83 2.83 0);
dimensions [0 1 -1 0 0 0 0];
internalField uniform (0 0 0);
boundaryField
inlet
type fixedValue;
value uniform $Uinlet;
outlet
type inletOutlet;
inletValue uniform (0 0 0);
value $internalField;
rooseveltGroup
type fixedValue;
value uniform (0 0 0);
frontAndBack
type slip;
lowerWall
type slip;
upperWall
type slip;
#includeEtc "caseDicts/setConstraintTypes"
FoamFile
version 2.0;
format ascii;
class volScalarField;
object p;
dimensions [0 2 -2 0 0 0 0];
internalField uniform 0;
boundaryField
inlet
type zeroGradient;
outlet
type totalPressure;
p0 uniform 0;
gamma 1.4;
value uniform 0;
rooseveltGroup
type zeroGradient;
frontAndBack
type slip;
lowerWall
type slip;
upperWall
type slip;
FoamFile
version 2.0;
format ascii;
object nut;
dimensions [0 2 -1 0 0 0 0];
boundaryField
inlet
type calculated;
value uniform 0;
outlet
type calculated;
value uniform 0;
rooseveltGroup
type nutkWallFunction;
value uniform 0;
frontAndBack
type slip;
lowerWall
type slip;
upperWall
type slip;
FoamFile
version 2.0;
format ascii;
object k;
kInlet 1.5; // approx k = 1.5*(I*U)^2 ; I = 0.1
internalField uniform $kInlet;
boundaryField
inlet
type fixedValue;
value uniform $kInlet;
outlet
type inletOutlet;
inletValue uniform $kInlet;
rooseveltGroup
type kqRWallFunction;
frontAndBack
type slip;
lowerWall
type slip;
upperWall
type slip;
FoamFile
version 2.0;
format ascii;
object epsilon;
epsilonInlet 0.03; // Cmu^0.75 * k^1.5 / L ; L =10
dimensions [0 2 -3 0 0 0 0];
internalField uniform $epsilonInlet;
boundaryField
inlet
type fixedValue;
value uniform $epsilonInlet;
outlet
type inletOutlet;
inletValue uniform $epsilonInlet;
rooseveltGroup
type epsilonWallFunction;
frontAndBack
type slip;
lowerWall
type slip;
upperWall
type slip;
FoamFile
version 2.0;
format ascii;
class dictionary;
object blockMeshDict;
convertToMeters 1;
vertices
(-200 -117 0)
(200 -117 0)
(200 177 0)
(-200 177 0)
(-200 -117 200)
(200 -117 200)
(200 177 200)
(-200 177 200)
blocks
hex (0 1 2 3 4 5 6 7) (14 77 14) simpleGrading (1 1 1)
edges
boundary
inlet
type patch;
faces
(0 4 7 3)
(1 5 4 0)
outlet
type patch;
faces
(2 6 5 1)
(3 7 6 2)
lowerWall
type slip;
faces
(0 3 2 1)
upperWall
type slip;
faces
(4 5 6 7)
Floating Point Exception Error nyox FLUENT 11 November 30, 2018 13:31
Floating point exception (core dumped), running a new solver Mahyar Javidi OpenFOAM Running, Solving & CFD 6 April 7, 2018 13:43
simpleFoam: floating point exception student666 OpenFOAM Running, Solving & CFD 9 March 13, 2016 19:23
sonicFoam - Floating point eception (core dumped) MSans OpenFOAM Running, Solving & CFD 12 August 4, 2015 06:10
Floating point exception (core dumped) for GAMG solver yuhou1989 OpenFOAM Running, Solving & CFD 2 March 24, 2015 20:28
