Strange error message whil running interFOAM
Old   May 5, 2017, 12:22
Default Strange error message whil running interFOAM
Kim Le
lethu is on a distinguished road
I am using interFOAM and I got this error message when launching interFOAM command.
Can anyone know what the problem is ?
Many thanks !
OpenFOAM-4.1(508) mpirun -np 4 interFoam -parallel 2>&1 | tee interFoam.log
| \\ / O peration | Version: 4.1 |
| \\ / A nd | Web: www.OpenFOAM.org |
| \\/ M anipulation | |
Build : 4.1
Exec : interFoam -parallel
Date : May 05 2017
Time : 14:26:13
Host : "bbff4ea8aacc"
PID : 536
Case : /home/openfoam/run/17-puitsDeChute
nProcs : 4
Slaves :
3
"bbff4ea8aacc.537"
"bbff4ea8aacc.538"
"bbff4ea8aacc.539"
Pstream initialized with:
floatTransfer : 0
nProcsSimpleSum : 0
commsType : nonBlocking
polling iterations : 0
allowSystemOperations : Allowing user-supplied system call operations
Create time
Create mesh for time = 0
PIMPLE: Operating solver in PISO mode
Reading field p_rgh
Reading field U
Reading transportProperties
Selecting incompressible transport model Newtonian
Selecting turbulence model type RAS
Selecting RAS turbulence model kOmegaSST
Selecting patchDistMethod meshWave
kOmegaSSTCoeffs
alphaK1 0.85;
alphaK2 1;
alphaOmega1 0.5;
alphaOmega2 0.856;
gamma1 0.555556;
gamma2 0.44;
beta1 0.075;
beta2 0.0828;
betaStar 0.09;
a1 0.31;
b1 1;
c1 10;
F3 false;
Reading g
Reading hRef
Calculating field g.h
No MRF models present
No finite volume options present
DICPCG: Solving for pcorr, Initial residual = 1, Final residual = 9.32447e-06, No Iterations 386
time step continuity errors : sum local = 2.08064e-09, global = -1.01939e-10, cumulative = -1.01939e-10
Courant Number mean: 0.000805354 max: 0.263083
forces forces:
--> FOAM Warning :
From function Foam::labelHashSet Foam::polyBoundaryMesh::patchSet(const Foam::UList<Foam::wordRe>&, bool, bool) const
in file meshes/polyMesh/polyBoundaryMesh/polyBoundaryMesh.C at line 794
Cannot find any patch or group names matching dalleHaut|dalleBas|bottom
Not including porosity effects
Starting time loop
Courant Number mean: 0.000805274 max: 0.263057
Interface Courant Number mean: 0 max: 0
deltaT = 0.000118991
Time = 0.000118991
PIMPLE: iteration 1
smoothSolver: Solving for alpha.water, Initial residual = 0, Final residual = 0, No Iterations 0
Phase-1 volume fraction = 0 Min(alpha.water) = 0 Max(alpha.water) = 0
MULES: Correcting alpha.water
[1] #0 [0] #0 [2] #0 [3] #0 Foam::error::printStack(Foam::Ostream&)Foam::error ::printStack(Foam::Ostream&)Foam::error::printStac k(Foam::Ostream&)Foam::error::printStack(Foam::Ost ream&) at ??:?
[0] #1 Foam::sigFpe::sigHandler(int) at ??:?
[1] #1 Foam::sigFpe::sigHandler(int) at ??:?
[3] #1 Foam::sigFpe::sigHandler(int) at ??:?
[2] #1 Foam::sigFpe::sigHandler(int) at ??:?
[1] #2 ? at ??:?
[3] #2 ? at ??:?
[0] #2 ? at ??:?
[2] #2 ? in "/lib/x86_64-linux-gnu/libc.so.6"
[3] #3 Foam::variableHeightFlowRateInletVelocityFvPatchVe ctorField::updateCoeffs() in "/lib/x86_64-linux-gnu/libc.so.6"
[0] #3 Foam::variableHeightFlowRateInletVelocityFvPatchVe ctorField::updateCoeffs() in "/lib/x86_64-linux-gnu/libc.so.6"
[1] #3 Foam::variableHeightFlowRateInletVelocityFvPatchVe ctorField::updateCoeffs() in "/lib/x86_64-linux-gnu/libc.so.6"
[2] #3 Foam::variableHeightFlowRateInletVelocityFvPatchVe ctorField::updateCoeffs() at ??:?
[3] #4 at ??:?
[1] #4 at ??:?
[0] #4 at ??:?
[2] #4 Foam::fvMatrix<Foam::Vector<double> >::fvMatrix(Foam::GeometricField<Foam::Vector<doub le>, Foam::fvPatchField, Foam::volMesh> const&, Foam::dimensionSet const&)Foam::fvMatrix<Foam::Vector<double> >::fvMatrix(Foam::GeometricField<Foam::Vector<doub le>, Foam::fvPatchField, Foam::volMesh> const&, Foam::dimensionSet const&)Foam::fvMatrix<Foam::Vector<double> >::fvMatrix(Foam::GeometricField<Foam::Vector<doub le>, Foam::fvPatchField, Foam::volMesh> const&, Foam::dimensionSet const&)Foam::fvMatrix<Foam::Vector<double> >::fvMatrix(Foam::GeometricField<Foam::Vector<doub le>, Foam::fvPatchField, Foam::volMesh> const&, Foam::dimensionSet const&) at ??:?
[3] #5 at ??:?
[0] #5 ? at ??:?
[1] #5 ? at ??:?
[2] #5 ? at ??:?
[3] #6 ? at ??:?
[1] #6 at ??:?
[0] #6 ? at ??:?
[2] #6 ?? at ??:?
[3] #7 __libc_start_main? at ??:?
[1] #7 __libc_start_main at ??:?
[0] #7 __libc_start_main at ??:?
[2] #7 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6"
[3] #8 in "/lib/x86_64-linux-gnu/libc.so.6"
[1] #8 in "/lib/x86_64-linux-gnu/libc.so.6"
[0] #8 ? in "/lib/x86_64-linux-gnu/libc.so.6"
[2] #8 ?? at ??:?
[bbff4ea8aacc:00539] *** Process received signal ***
[bbff4ea8aacc:00539] Signal: Floating point exception (8)
[bbff4ea8aacc:00539] Signal code: (-6)
[bbff4ea8aacc:00539] Failing at address: 0x3e80000021b
[bbff4ea8aacc:00539] [ 0] /lib/x86_64-linux-gnu/libc.so.6(+0x354b0)[0x7f3724ee04b0]
[bbff4ea8aacc:00539] [ 1] /lib/x86_64-linux-gnu/libc.so.6(gsignal+0x38)[0x7f3724ee0428]
[bbff4ea8aacc:00539] [ 2] /lib/x86_64-linux-gnu/libc.so.6(+0x354b0)[0x7f3724ee04b0]
[bbff4ea8aacc:00539] [ 3] /opt/openfoam4/platforms/linux64GccDPInt32Opt/lib/libfiniteVolume.so(_ZN4Foam53variableHeightFlowRat eInletVelocityFvPatchVectorField12updateCoeffsEv+0 x719)[0x7f3728246f59]
[bbff4ea8aacc:00539] [ 4] interFoam(_ZN4Foam8fvMatrixINS_6VectorIdEEEC1ERKNS _14GeometricFieldIS2_NS_12fvPatchFieldENS_7volMesh EEERKNS_12dimensionSetE+0x5af)[0x4716df]
[bbff4ea8aacc:00539] [ 5] interFoam[0x4718ad]
[bbff4ea8aacc:00539] [ 6] interFoam[0x439955]
[bbff4ea8aacc:00539] [ 7] /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xf0)[0x7f3724ecb830]
[bbff4ea8aacc:00539] [ 8] interFoam[0x441db9]
[bbff4ea8aacc:00539] *** End of error message ***
? at ??:?
[bbff4ea8aacc:00537] *** Process received signal ***
[bbff4ea8aacc:00537] Signal: Floating point exception (8)
[bbff4ea8aacc:00537] Signal code: (-6)
[bbff4ea8aacc:00537] Failing at address: 0x3e800000219
[bbff4ea8aacc:00537] [ 0] /lib/x86_64-linux-gnu/libc.so.6(+0x354b0)[0x7f9e21a034b0]
[bbff4ea8aacc:00537] [ 1] /lib/x86_64-linux-gnu/libc.so.6(gsignal+0x38)[0x7f9e21a03428]
[bbff4ea8aacc:00537] [ 2] /lib/x86_64-linux-gnu/libc.so.6(+0x354b0)[0x7f9e21a034b0]
[bbff4ea8aacc:00537] [ 3] /opt/openfoam4/platforms/linux64GccDPInt32Opt/lib/libfiniteVolume.so(_ZN4Foam53variableHeightFlowRat eInletVelocityFvPatchVectorField12updateCoeffsEv+0 x719)[0x7f9e24d69f59]
[bbff4ea8aacc:00537] [ 4] interFoam(_ZN4Foam8fvMatrixINS_6VectorIdEEEC1ERKNS _14GeometricFieldIS2_NS_12fvPatchFieldENS_7volMesh EEERKNS_12dimensionSetE+0x5af)[0x4716df]
[bbff4ea8aacc:00537] [ 5] interFoam[0x4718ad]
[bbff4ea8aacc:00537] [ 6] interFoam[0x439955]
[bbff4ea8aacc:00537] [ 7] /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xf0)[0x7f9e219ee830]
[bbff4ea8aacc:00537] [ 8] interFoam[0x441db9]
[bbff4ea8aacc:00537] *** End of error message ***
at ??:?
[bbff4ea8aacc:00536] *** Process received signal ***
[bbff4ea8aacc:00536] Signal: Floating point exception (8)
[bbff4ea8aacc:00536] Signal code: (-6)
[bbff4ea8aacc:00536] Failing at address: 0x3e800000218
[bbff4ea8aacc:00536] [ 0] /lib/x86_64-linux-gnu/libc.so.6(+0x354b0)[0x7fd5279474b0]
[bbff4ea8aacc:00536] [ 1] /lib/x86_64-linux-gnu/libc.so.6(gsignal+0x38)[0x7fd527947428]
[bbff4ea8aacc:00536] [ 2] /lib/x86_64-linux-gnu/libc.so.6(+0x354b0)[0x7fd5279474b0]
[bbff4ea8aacc:00536] [ 3] /opt/openfoam4/platforms/linux64GccDPInt32Opt/lib/libfiniteVolume.so(_ZN4Foam53variableHeightFlowRat eInletVelocityFvPatchVectorField12updateCoeffsEv+0 x719)[0x7fd52acadf59]
[bbff4ea8aacc:00536] [ 4] interFoam(_ZN4Foam8fvMatrixINS_6VectorIdEEEC1ERKNS _14GeometricFieldIS2_NS_12fvPatchFieldENS_7volMesh EEERKNS_12dimensionSetE+0x5af)[0x4716df]
[bbff4ea8aacc:00536] [ 5] interFoam[0x4718ad]
[bbff4ea8aacc:00536] [ 6] interFoam[0x439955]
[bbff4ea8aacc:00536] [ 7] /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xf0)[0x7fd527932830]
[bbff4ea8aacc:00536] [ 8] interFoam[0x441db9]
[bbff4ea8aacc:00536] *** End of error message ***
at ??:?
[bbff4ea8aacc:00538] *** Process received signal ***
[bbff4ea8aacc:00538] Signal: Floating point exception (8)
[bbff4ea8aacc:00538] Signal code: (-6)
[bbff4ea8aacc:00538] Failing at address: 0x3e80000021a
[bbff4ea8aacc:00538] [ 0] /lib/x86_64-linux-gnu/libc.so.6(+0x354b0)[0x7f2b729e44b0]
[bbff4ea8aacc:00538] [ 1] /lib/x86_64-linux-gnu/libc.so.6(gsignal+0x38)[0x7f2b729e4428]
[bbff4ea8aacc:00538] [ 2] /lib/x86_64-linux-gnu/libc.so.6(+0x354b0)[0x7f2b729e44b0]
[bbff4ea8aacc:00538] [ 3] /opt/openfoam4/platforms/linux64GccDPInt32Opt/lib/libfiniteVolume.so(_ZN4Foam53variableHeightFlowRat eInletVelocityFvPatchVectorField12updateCoeffsEv+0 x719)[0x7f2b75d4af59]
[bbff4ea8aacc:00538] [ 4] interFoam(_ZN4Foam8fvMatrixINS_6VectorIdEEEC1ERKNS _14GeometricFieldIS2_NS_12fvPatchFieldENS_7volMesh EEERKNS_12dimensionSetE+0x5af)[0x4716df]
[bbff4ea8aacc:00538] [ 5] interFoam[0x4718ad]
[bbff4ea8aacc:00538] [ 6] interFoam[0x439955]
[bbff4ea8aacc:00538] [ 7] /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xf0)[0x7f2b729cf830]
[bbff4ea8aacc:00538] [ 8] interFoam[0x441db9]
[bbff4ea8aacc:00538] *** End of error message ***
mpirun noticed that process rank 0 with PID 536 on node bbff4ea8aacc exited on signal 8 (Floating point exception).
lethu is offline   Reply With Quote
Old   May 9, 2017, 11:45
Phanindra
phani45 is on a distinguished road
It seems that a group/region is missing in your boundary condition setting file.
Please check your mesh files once again and define missing zones . It should work fine
phani45 is offline   Reply With Quote
Old   May 10, 2017, 04:24
Kim Le
Thanks phani45 ! I managed the problem by starting over the wrinting of the BC files. I don't know exactly what the problem was but it was in those files !
#error #interfoam
InterFoam stops after deltaT goes to 1e14 francesco_b OpenFOAM Running, Solving & CFD 9 July 25, 2020 07:36
Statically Compiling OpenFOAM Issues herzfeldd OpenFOAM Installation 21 January 6, 2009 10:38
Strange epsilon chris1980 OpenFOAM Running, Solving & CFD 6 October 24, 2006 10:05
Performance of interFoam running in parallel hsieh OpenFOAM Running, Solving & CFD 8 September 14, 2006 10:15
InterFoam problem running parallel vatant OpenFOAM Running, Solving & CFD 0 April 28, 2006 20:22
