May 5, 2017, 04:41
Definition of object registry field for mesh boundary
Fynn
Hi together
I want to define a field in the object registry in the same manner as phi is defined for the rhoSimpleFoam solver, in which the density rho*U interpolated to the fv surfaces and multiplied with the respective fv surface size (line 11).
surfaceScalarField phi
IOobject
"phi",
runTime.timeName(),
mesh,
IOobject::READ_IF_PRESENT,
IOobject::AUTO_WRITE
linearInterpolate(rho*U) & mesh.Sf()
How can I define a new object phi_out that only interpolates the density flux rho*U on a specific mesh boundary, for example an outlet?
I.e. how should I change line 11 to apply the calculation to the mesh boundary only?
