wind simulation on buildings
Old   May 3, 2017, 10:31
Question wind simulation on buildings
rmz
rmz
rmz is on a distinguished road
I am working on a CFD model to simulate wind loads on buildings. I am using the simpleFoam solver and applying ABL conditions.
I already checked different simpleFoam tutorials and constructed my model based on these tutorials.
I want to simulate all possible wind directions so I chose to change the flow direction by 15 degrees (each simulation); So I have 25 simulations to run.
Since I have a very big Mesh, I don't want to rerun snappyHexMesh every time. so I decided to do a cylindrical domain with blockMesh.
my entire cylinder outer face is considered as 1 patch (named outerRim). I don't have separate inlet and outlet patches. I am applying ABL conditions for U on this patch and zeroGradient for p. (since I am applying "atmBoundaryLayerInletVelocity" on the outer face of the cylinder, this condition is also applied on the faces where the flow exists the domain)
using this model I can use the same Mesh, change the flowDirection every time and run only simpleFoam.
I evaluated my model without the stl files (blockMesh and simpleFoam) and I recognized that i have a weird flow near the exit (image below).
*cylindrical domain: diameter: 6000 m and height: 250 m
-the entire outer face of the cylinder is considered as 1 patch named outerRim (color red in the image).
-in Red: "outerRim" patch
in blue: "top" patch
*U file:
*p file:
*streamLines exiting domain: flow exiting domain with sudden change of gradient.
Because of the weird flow near the exist, I thought my model could be bad and give non realistic results.
questions:
1-should a CFD model have seperate inlet and outlet patches and boundary conditions?
2-is acceptable to apply "atmBoundaryLayerInletVelocity" on the outerRim, so it is also applied on the faces where the flow exists the domain?
3-is my model physically (mechanically) good, and does it give good realistice results?
4-in case my model is good, how can I calibrate it (which boundary conditions to use for the variables) in order to have a smooth ABL wind profile and good results from the simulation?
rmz is offline   Reply With Quote
abl flow, boundary condition, building aerodynamics, wind profile
Wind tunnel blockage simulation for VAWT urbanzakapa FLUENT 0 March 11, 2016 04:39
Wind turbine simulation problem sanchovg2 STAR-CCM+ 12 March 5, 2013 05:18
shaft power versus RMP curve in wind turbine simulation zhenduan306 CFX 28 November 8, 2012 11:11
