May 2, 2017, 08:21 |
twoPhaseEulerFoam: air is created at edges
Rep Power: 9 |
Hi all,
I'm doing a simulation using twoPhaseEulerFoam with an air injection in water (see tutorial injection). I'm using the mixtureKEpsilon model for turbulence, using the same boundary conditons as the other RAS tutorials. I have a problem at edges where boundary layers start to develop, since air (alpha1) is created at these edges. without fvOptions only small quantities of air appear, while with an air mass source this problem is enhanced. I have the same problem in laminar flow. I also tried different div schemes without changes. Any suggestions? Thanks (I'll send the input in private if needed). |
Data Center Air conditioning Boundary Condition problem | jaypatel | OpenFOAM | 9 | April 8, 2020 15:04 |
Air to Air Heat Exchanger | visser1975 | FLUENT | 2 | November 10, 2012 13:34 |
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! | sc298 | OpenFOAM Meshing & Mesh Conversion | 2 | March 27, 2011 21:11 |
OpenFOAM 1.7.1 installation problem on OpenSUSE 11.3 | flakid | OpenFOAM Installation | 16 | December 28, 2010 08:48 |
air bubble is disappear increasing time using vof | xujjun | CFX | 9 | June 9, 2009 07:59 |
