twoPhaseEulerSedFoam scour case diverges
Old   May 1, 2017, 22:25
Default twoPhaseEulerSedFoam scour case diverges
Lee
jylee4 is on a distinguished road
Please pardon my ignorance, I am new to OpenFOAM. Could you please point me in the right direction?
I'm trying to model 2D scour beneath a pipeline, under a steady current condition, using twoPhaseEulerSedFoam (link below) on OpenFOAM-2.1.1. Although it was developed using OpenFOAM-2.1.0, the example cases ran fine on OpenFOAM-2.1.1.
https://github.com/csdms-contrib/twophaseeulersedfoam
I hope that the attached "alpha0.jpg" and "Ub0.jpg" can give you a good overview of the initial conditions. The problem is that there are very large time step continuity errors (as shown below)
|  \\    /   O peration     | Version:  2.1.1                                 |
|   \\  /    A nd           | Web:      www.OpenFOAM.org                      |
Build  : 2.1.1-221db2718bbb
Exec   : twoPhaseEulerSedFoam
Date   : May 02 2017
Time   : 09:59:46
Host   : "jylee4-VirtualBox"
PID    : 19239
Case   : /home/jylee4/OpenFOAM/jylee4-2.1.1/run/case2h
nProcs : 1
allowSystemOperations : Disallowing user-supplied system call operations
Create time
Create mesh for time = 0
Reading g
Reading transportProperties
Calculating face flux field phia
Calculating face flux field phib
Reading field alpha
Reading field p
kEpsilonCoeffs
    Cmu             0.09;
    C1              1.44;
    C2              1.92;
    alphak          1;
    alphaEps        0.76923;
wallFunctionCoeffs
    kappa           0.41;
    E               9.8;
Reading field k
Reading field epsilon
Calculating field nutb
Calculating field nuEffa
Calculating field nuEffb
Calculating field DDtUa and DDtUb
Calculating field g.h
Selecting dragModel for phase a: GidaspowErgunWenYu
Selecting dragModel for phase b: GidaspowErgunWenYu
dragPhase is a
Selecting viscosityModel Gidaspow
Selecting conductivityModel Gidaspow
Selecting radialModel CarnahanStarling
Selecting granularPressureModel Lun
Selecting frictionalStressModel SrivastavaSundaresan
Courant Number mean: 0.00137713 max: 0.0190682
Reading transportProperties for gradP
Initializing with specified pressure gradient:(46.9899 0 0)
PIMPLE: max iterations = 50
    field p    : relTol 0, tolerance 0.0001
    field U    : relTol 0, tolerance 0.0001
    field alpha    : relTol 0, tolerance 0.0001
Starting time loop
Turbulence suspension term is included
Max Ur Courant Number = 0.0190682
Interface Courant Number mean: 0.00137713 max: 0.0190682
deltaT = 1.19904e-05 < 0.0005
Time = 1.19904e-05
PIMPLE: iteration 1
DILUPBiCG:  Solving for alpha, Initial residual = 1.49347e-07, Final residual = 3.21951e-25, No Iterations 3
Dispersed phase volume fraction = 0.182364  Min(alpha) = 0  Max(alpha) = 0.6
DILUPBiCG:  Solving for alpha, Initial residual = 5.486e-10, Final residual = 6.01472e-21, No Iterations 2
DILUPBiCG:  Solving for Theta, Initial residual = 1, Final residual = 7.43123e-11, No Iterations 8
kinTheory: max(Theta) = 0.000137375 min(Theta) = 0
kinTheory: min(nua) = 0, max(nua) = 2.27681e+32
kinTheory: min(pa) = 0, max(pa) = 5.37874
Max gradPs =119910,Min gradPs =0
Max gradPf =573016,Min gradPf =0
swak4Foam: Allocating new repository for sampledGlobalVariables
GAMG:  Solving for p, Initial residual = 1, Final residual = 6.44256e-10, No Iterations 161
GAMG:  Solving for p, Initial residual = 0.0567147, Final residual = 5.77517e-10, No Iterations 73
time step continuity errors : sum local = 4.97447e-13, global = 3.86504e-14, cumulative = 3.86504e-14
DILUPBiCG:  Solving for alpha, Initial residual = 1.64902e-06, Final residual = 8.65104e-25, No Iterations 4
DILUPBiCG:  Solving for alpha, Initial residual = 1.25664e-08, Final residual = 6.23708e-24, No Iterations 3
GAMG:  Solving for p, Initial residual = 0.0058589, Final residual = 8.81012e-10, No Iterations 119
GAMG:  Solving for p, Initial residual = 0.794251, Final residual = 9.101e-10, No Iterations 89
time step continuity errors : sum local = 5.50086e-14, global = 1.83734e-15, cumulative = 4.04877e-14
DILUPBiCG:  Solving for alpha, Initial residual = 1.61092e-06, Final residual = 7.69513e-22, No Iterations 13
DILUPBiCG:  Solving for alpha, Initial residual = 1.59849e-08, Final residual = 3.91697e-22, No Iterations 8
PIMPLE: iteration 2
DILUPBiCG:  Solving for alpha, Initial residual = 8.06833e-10, Final residual = 2.4574e-21, No Iterations 10
DILUPBiCG:  Solving for alpha, Initial residual = 4.38846e-10, Final residual = 4.53047e-22, No Iterations 10
DILUPBiCG:  Solving for Theta, Initial residual = 6.31348e-17, Final residual = 6.31348e-17, No Iterations 0
kinTheory: min(nua) = 0, max(nua) = 1.81897e+32
Max gradPs =113411,Min gradPs =0
Max gradPf =541822,Min gradPf =0
GAMG:  Solving for p, Initial residual = 1, Final residual = 6.25606e-10, No Iterations 70
GAMG:  Solving for p, Initial residual = 0.000466378, Final residual = 8.81131e-10, No Iterations 52
time step continuity errors : sum local = 5.33473e+07, global = 1.91681e+06, cumulative = 1.91681e+06
DILUPBiCG:  Solving for alpha, Initial residual = 3.45233e-08, Final residual = 3.45233e-08, No Iterations 1001
Dispersed phase volume fraction = 0.182515  Min(alpha) = 0  Max(alpha) = 0.6
DILUPBiCG:  Solving for alpha, Initial residual = 3.45166e-08, Final residual = 1.00473e-07, No Iterations 1001
Dispersed phase volume fraction = 0.374457  Min(alpha) = 0  Max(alpha) = 0.634
GAMG:  Solving for p, Initial residual = 0.999775, Final residual = 7.53284e-10, No Iterations 101
GAMG:  Solving for p, Initial residual = 0.000436472, Final residual = 8.85226e-10, No Iterations 47
time step continuity errors : sum local = 2.54219e+11, global = -2.31365e+10, cumulative = -2.31345e+10
#0  Foam::error::printStack(Foam::Ostream&) in "/home/jylee4/OpenFOAM/OpenFOAM-2.1.1/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#1  Foam::sigFpe::sigHandler(int) in "/home/jylee4/OpenFOAM/OpenFOAM-2.1.1/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#2   in "/lib/x86_64-linux-gnu/libc.so.6"
#3  Foam::DILUPreconditioner::calcReciprocalD(Foam::Field<double>&, Foam::lduMatrix const&) in "/home/jylee4/OpenFOAM/OpenFOAM-2.1.1/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#4  Foam::DILUPreconditioner::DILUPreconditioner(Foam::lduMatrix::solver const&, Foam::dictionary const&) in "/home/jylee4/OpenFOAM/OpenFOAM-2.1.1/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#5  Foam::lduMatrix::preconditioner::addasymMatrixConstructorToTable<Foam::DILUPreconditioner>::New(Foam::lduMatrix::solver const&, Foam::dictionary const&) in "/home/jylee4/OpenFOAM/OpenFOAM-2.1.1/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#6  Foam::lduMatrix::preconditioner::New(Foam::lduMatrix::solver const&, Foam::dictionary const&) in "/home/jylee4/OpenFOAM/OpenFOAM-2.1.1/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#7  Foam::PBiCG::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const in "/home/jylee4/OpenFOAM/OpenFOAM-2.1.1/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#8  Foam::fvMatrix<double>::solve(Foam::dictionary const&) in "/home/jylee4/OpenFOAM/OpenFOAM-2.1.1/platforms/linux64GccDPOpt/lib/libfiniteVolume.so"
#9  Foam::fvMatrix<double>::solve() in "/home/jylee4/OpenFOAM/jylee4-2.1.1/platforms/linux64GccDPOpt/bin/twoPhaseEulerSedFoam"
#11  __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6"
#12
Floating point exception (core dumped)
How did I end up in this mess:
1. Copied the "Sumer1996" steady flow example case for twoPhaseEulerSedFoam, and replaced the mesh via fluent3DMeshToFoam (checkMesh.log provided below)
checkMesh.log:
Exec   : checkMesh
Date   : May 02 2017
Time   : 09:14:18
PID    : 18757
nProcs : 1
Create time
Create polyMesh for time = 0
Time = 0
Mesh stats
    internal points:  0
    faces:            445612
    internal faces:   221612
    cells:            111204
    boundary patches: 8
    point zones:      0
    face zones:       1
    cell zones:       1
Overall number of cells of each type:
    hexahedra:     111204
    prisms:        0
    wedges:        0
    pyramids:      0
    tet wedges:    0
    tetrahedra:    0
    polyhedra:     0
Checking topology...
    Boundary definition OK.
    Cell to face addressing OK.
    Point usage OK.
    Upper triangular ordering OK.
    Face vertices OK.
    Number of regions: 1 (OK).
Checking patch topology for multiply connected surfaces ...
    Patch               Faces    Points   Surface topology
    bed                 448      898      ok (non-closed singly connected)
    fluidin             149      300      ok (non-closed singly connected)
    fluidout            149      300      ok (non-closed singly connected)
    pipe                200      400      ok (non-closed singly connected)
    sedin               99       200      ok (non-closed singly connected)
    sedout              99       200      ok (non-closed singly connected)
    symsides            222408   224000   ok (non-closed singly connected)
    top                 448      898      ok (non-closed singly connected)
Checking geometry...
    Overall domain bounding box (-1 0 0) (1 0.33 0.005)
    Mesh (non-empty, non-wedge) directions (1 1 0)
    Mesh (non-empty) directions (1 1 0)
    All edges aligned with or perpendicular to non-empty directions.
    Boundary openness (3.79223e-21 8.50472e-18 1.63851e-15) OK.
    Max cell openness = 2.89168e-16 OK.
    Max aspect ratio = 20.0908 OK.
    Minumum face area = 5.62712e-07. Maximum face area = 8.99651e-05.  Face area magnitudes OK.
    Min volume = 2.81356e-09. Max volume = 3.6539e-07.  Total volume = 0.00329018.  Cell volumes OK.
    Mesh non-orthogonality Max: 44.0733 average: 10.1293
    Non-orthogonality check OK.
    Face pyramids OK.
    Max skewness = 0.456248 OK.
    Coupled point location match (average 0) OK.
Mesh OK.
End
2. then edited the boundary conditions in the "0" folder. I used groovyBC to specify a log velocity profile for the fluid phase at the inlet:
0/Ub:
FoamFile
    version     2.0;
    format      ascii;
    class       volVectorField;
    object      Ub; //fluid velocity
dimensions          [ 0 1 -1 0 0 0 0 ];
internalField       uniform (0 0 0);
boundaryField
    bed
        type               fixedValue;
        value              uniform (0 0 0);
    fluidin
    type         groovyBC;
        variables
        "uf=0.043914724;" // friction velocity, m/s
        "z0=3e-05;" // bed roughness length, m
        "kappaa=0.40;" // von Karman's constant (Soulsby, 1997)
        //"height=pos().y-0.1+z0;" // elevation - sediment box height; CAN'T BE 0
        "height=sqrt(sqr(pos().y-0.1+z0));" // elevation - sediment box height; CAN'T BE 0
        "velx=(uf/kappaa)*log(height/z0)*normal();"
        valueExpression "-velx";
    fluidout
        //type                zeroGradient;
        type                inletOutlet;
        inletValue          uniform (0 0 0); //no backflow
        value               uniform ( 0 0 0 ); //zero gradient for outflow
    pipe
        type               fixedValue;
    sedin
        type                zeroGradient;
        //type        fixedValue;
    //value        uniform (0 0 0);
    sedout
        type                inletOutlet;
    symsides
        type            empty;
    top
        type               symmetryPlane;
        //type                slip;
        //type            pressureInletOutletVelocity;
        //value           uniform (0.982 0 0);
3. used setFieldsDict and funkySetFieldsDict to have non-uniform internal fields for alpha (volume fraction) and Ub (fluid velocity).
system/setFieldsDict:
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    location    "system";
    object      setFieldsDict;
defaultFieldValues /* outside sediment box */
    volScalarFieldValue alpha 0
regions
    boxToCell
        box ( -1 0 0 ) ( 1 0.1 0.005 ) ; // inside sediment box
        fieldValues
            volScalarFieldValue alpha 0.6 //6.107060e-01
system/funkySetFieldsDict:
FoamFile
    version         2.0;
    format          ascii;
    //root            "~/OpenFOAM/jylee4-2.1.1/run";
    //case            "case2h";
    //instance        "system";
    //local           "";
    class           dictionary;
    location        "system";
    object          funkySetFieldsDict;
expressions
    initialVelProfile
        field Ub; // field to initialise
        condition "pos().y>0.1 && pos().y<0.33";
        keepPatches true; //keep the boundary conditions that were set before
        //expression "vector(1,0,0)*(0.043914724/0.4)*log((pos().y)/3e-05)";
        expression "vector(1,0,0)*(0.043914724/0.4)*log((sqrt(sqr(pos().y-0.1+3e-05)))/3e-05)";
        dimension [0 1 -1 0 0];
4. ran:
setFields
funkySetFields -time 0
5. solution diverges; so I tried copy and pasting the mesh and "0" folder into a twoPhaseEulerFoam tutorial case (e.g. bed2), and it ran fine.
6. back to twoPhaseEulerSedFoam, I reduced the nOuterCorrectors in the PIMPLE loop to 1 (in fvSolution), and reduced the writeInterval to a value which is equal to deltaT (in controlDict), to visualise the output.
With reference to the attached "p1.jpg" and "Ub1.jpg" files, it seems that there are very large pressure and velocity values at the outlet, or more specifically, at the interface between the fluid and sediment phase. However, I have no idea how to fix this.
I've tried using zeroGradient and fixedValue for the outlet boundary for p, zeroGradient and inletOutlet for the outlet for Ua and Ub, but that didn't work.
Please find the files here:
https://www.dropbox.com/s/ka99wfmfnx...2h.tar.gz?dl=0
Many thanks for your patience and kind assistance.
jylee4 is offline   Reply With Quote
Old   October 16, 2017, 07:25
asin is on a distinguished road
hey,I'm doing some research on scour recently,do you solve your problem?
asin is offline   Reply With Quote
Old   November 10, 2017, 11:50
Tina Ebrahimi
Tina Ebrahimi is on a distinguished road
Hello Asin. I want to simulate scouring in OpenFOAM too. Can I ask you for some help?
Tina Ebrahimi is offline   Reply With Quote
Old   November 12, 2017, 13:32
Declan
decah is on a distinguished road
Try checking out scourFoam
Erosion/sediment transport with OpenFOAM: Which model to use?
Or a Larangian solver depending on the scale of your problem
decah is offline   Reply With Quote
[DesignModeler] DesignModeler Scripting: How to get Full Command Access ANT ANSYS Meshing & Geometry 53 February 16, 2020 16:13
Is Playstation 3 cluster suitable for CFD work hsieh OpenFOAM 9 August 16, 2015 15:53
Superlinear speedup in OpenFOAM 13 msrinath80 OpenFOAM Running, Solving & CFD 18 March 3, 2015 06:36
Transient case running with a super computer microfin FLUENT 0 March 31, 2009 12:20
Turbulent Flat Plate Validation Case Jonas Larsson Main CFD Forum 0 April 2, 2004 11:25
