Auto restart of crashing simulations in OpenFOAM |
May 1, 2017, 07:36 |
Vijaya Kumar. G
Rep Power: 10 |
I use 'chtMultiRegionFoam' solver on a big geometry (60 m3). Sometimes the solver crashes with 'Floating point Exception error' during parallel run (mpirun). But when I restart the same, the simulation run continues without any issue. This is definitely not a case of diverging solution, as I have good pretty good match with experimental data.
This problem becomes a nuisance because I cannot give a simulation to a HPC and just relax for a day or two, the simulation would have broken down in between resulting in idle time of HPC. I then decided to use a python script, which itself kills a process every 1 hour and then restarts it. By this way I can restrict the idle time of the systems. python script: cycle.py # Start of script #!/usr/bin/env python3 import subprocess import time import sys force = False args = sys.argv[1:]; app = args[0].replace("'", "") proc = app.split()[0].split("/")[-1] cycle = int(args[1])*60; run = int(args[2])*60 try: if args[3] == "force": force = True except IndexError: pass def get_pid(proc_name): try: return subprocess.check_output( ["pgrep", proc_name] ).decode("utf-8").strip() except subprocess.CalledProcessError: pass def kill(pid, force): if force == False: subprocess.Popen(["kill", "-s", "TERM", pid]) elif force == True: subprocess.Popen(["kill", pid]) while True: subprocess.Popen(["/bin/bash", "-c", app]) time.sleep(run) pid = get_pid(proc) if pid != None: kill(pid, force) time.sleep(cycle - run) #End of script The script works with python3 and the command is as follows python3 <script> <command_to_run_application> <cycle_time> <application_run_time> <script> - Name of the python script <command_to_run_application> - chtMultiRegionFoam (or any solver) <cycle_time> - Periodic interval for restart <application_run_time> - Time till which the application runs I have tested the script with 'firefox' browser and it does the intended job. But when I tried this script with OpenFOAM it is restarting as specified by <cycle_time> but it is not killing the process as specified by the <application_run_time>. Which means the new process starts wihtout closing the old one. I suppose this has to do something with the 'controlDict'. The application run time is dictated by the 'contolDict' file which overrides the application run time given in the python script. Any help would be welcome. Regards Vijaya Kumar G Ph.D Student IIT Madras India |
auto restart after crash., chtmultiregionfoam, openfoam 4.0, simulation crash |
Simulations are not converging in OpenFOAM for many elements (more than 1 000 000) | silvai | OpenFOAM Running, Solving & CFD | 6 | April 3, 2017 09:33 |
OpenFOAM Training: Programming CFD Course 12-13 and 19-20 April 2016 | cfd.direct | OpenFOAM Announcements from Other Sources | 0 | January 14, 2016 11:19 |
OpenFOAM v3.0.1 Training, London, Houston, Berlin, Jan-Mar 2016 | cfd.direct | OpenFOAM Announcements from Other Sources | 0 | January 5, 2016 04:18 |
Suggestion for a new sub-forum at OpenFOAM's Forum | wyldckat | Site Help, Feedback & Discussions | 20 | October 28, 2014 10:04 |
OpenFOAM Training and Workshop Zagreb 2628Jan2006 | hjasak | OpenFOAM | 1 | February 2, 2006 22:07 |
