Does the Case Termination Control based on coefficient convergence work?
Old   May 1, 2017, 05:27
Unhappy Does the Case Termination Control based on coefficient convergence work?
Ronith Stanly
ronithstanly is on a distinguished road
I tried the new runTimeControl feature ( http://www.openfoam.com/version-v3.0...on-control.php ) using the convergence of lift, drag and moment coefficients for the simpleFoam simulation of flow around an airfoil that I did. But even though I tried with different averaging window values (ranging from 1 to 1000 for a solution that calculated more than 1e05 timesteps) and tolerances (even 0.1), eventhough I could see that the coefficients did not oscillate more than 1% for more than the last 10% of the timesteps, the solution did not seem to stop there. I thought that the convergence criterion under SIMPLE based on the residuals of p, U and nut were causing the problem, so I tried commenting that and also tried reducing it, but in either case, the coefficient based control did not seem to stop the solution.
Has someone successfully used this feature to terminate their solution based on the convergence of coefficients?
Am I making some fundamental error in defining the feature?
What should I look out for while setting this control feature?
Any guidance for using this utility will be really helpful.
Thanks in advance,
Ronith Stanly.
ronithstanly is offline   Reply With Quote
coefficient of lift, convergence criterion, run-time, solution control
Error - Solar absorber - Solar Thermal Radiation MichaelK CFX 12 September 1, 2016 06:15
Simple piston movement in cylinder- fluid models arun1994 CFX 4 July 8, 2016 03:54
Is Playstation 3 cluster suitable for CFD work hsieh OpenFOAM 9 August 16, 2015 15:53
How to control the convergence? titio OpenFOAM Running, Solving & CFD 4 September 21, 2011 12:29
Automotive test case vinz OpenFOAM Running, Solving & CFD 98 October 27, 2008 09:43
