A simpleTsunami with interDyMFoam
Old   April 29, 2017, 22:09
Unhappy A simpleTsunami with interDyMFoam
saatt is on a distinguished road
Hello, everyone!
Recently, i try to run a case named simpleTsunami which is a course project(how to make a dynamicMotionRefineFvMesh class) at Chalmers University(http://www.tfd.chalmers.se/~hani/kurser/OS_CFD/). However ,when i changed the boxTocell in setFieldsDict document and run the case. I always get some errors and warnings. The errors or warnings just like these:
The errors when i don't change the boxTocell (There are some warnings but program can go on )
the number of vertices in the geometry is odd - this should not be the case for a 2-D case. Please check the geometry.
--> FOAM Warning :
From function twoDPointCorrector::calcAddressing()
in file twoDPointCorrector/twoDPointCorrector.C at line 160
The number of points in the mesh is not equal to twice the number of edges normal to the plane - this may be OK only for wedge geometries.
Please check the geometry or adjust the orthogonality tolerance.
Number of normal edges: 7859 number of points: 11621
Selected 1 cells for refinement out of 7014.
Refined from 7014 to 7021 cells.
--> FOAM Warning :
From function dynamicMotionRefineFvMesh::refine(const labelList&)
in file dynamicMotionRefineFvMesh/dynamicMotionRefineFvMesh.C at line 324
Cannot find surfaceScalarField faceDiffusivity in user-provided flux mapping table
4
phi none
rhoPhi none
nHatf none
ghf none
The flux mapping table is used to recreate the flux on newly created faces.
Either add the entry if it is a flux or use (faceDiffusivity none) to suppress this warning.
--> FOAM Warning :
Cannot find surfaceScalarField alphaPhi in user-provided flux mapping table
4
phi none
rhoPhi none
nHatf none
ghf none
Either add the entry if it is a flux or use (alphaPhi none) to suppress this warning.
The errors when i change the boxTocell like as boxTocellbox (0 0 0) (0.4 0.292 1) (There are some warnings and errors, and program can go on and interrupt later )
--> FOAM Warning :
Number of normal edges: 9217 number of points: 13316
Selected 30 cells for refinement out of 8078.
Refined from 8078 to 8288 cells.
--> FOAM Warning :
4
phi none
rhoPhi none
nHatf none
ghf none
--> FOAM Warning :
4
phi none
rhoPhi none
nHatf none
ghf none
Selected 24 split points out of a possible 735.
Unrefined from 8288 to 8120 cells.
--> FOAM Warning :
in file dynamicMotionRefineFvMesh/dynamicMotionRefineFvMesh.C at line 553
4
phi none
rhoPhi none
nHatf none
ghf none
--> FOAM Warning :
4
phi none
rhoPhi none
nHatf none
ghf none
Execution time for mesh.update() = 0.17 s
GAMG: Solving for pcorr, Initial residual = 1, Final residual = 8.14214e-05, No Iterations 8
time step continuity errors : sum local = 3.24511e-08, global = -7.41633e-09, cumulative = 0.00247612
MULES: Solving for alpha.water
Phase-1 volume fraction = 0.339611 Min(alpha.water) = 0 Max(alpha.water) = 1
Phase-1 volume fraction = 0.339612 Min(alpha.water) = 0 Max(alpha.water) = 1
GAMG: Solving for p_rgh, Initial residual = 0.0922006, Final residual = 0.000216608, No Iterations 2
#0 Foam::error:rintStack(Foam::Ostream&) at ??:?
#1 Foam::sigFpe::sigHandler(int) at ??:?
#2 ? in "/lib/x86_64-linux-gnu/libc.so.6"
#3 ? at tensorField.C:?
#4 ? at ??:?
#5 ? at ??:?
#6 ? at ??:?
#7 ? at ??:?
#8 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6"
#9 ? at ??:?
Can anyone help me and solve this problem?
saatt is offline   Reply With Quote
Old   December 20, 2018, 10:56
Default Have you solved the problem?
AndreiCFD
andrei.cimpoeru is on a distinguished road
Hi ! Have you solved the problem as I am getting the same error? Any help would be much appreciated.
Cheers, Andrei
andrei.cimpoeru is offline   Reply With Quote
dynamicmotionrefinefvmesh, interdymfoam
interDyMFoam with VOF + 6DOF instable pbalz OpenFOAM Running, Solving & CFD 11 October 9, 2020 06:19
Standard InterDyMFoam doesn't work after modifying interFoam nesca87 OpenFOAM Running, Solving & CFD 7 January 5, 2017 23:47
modifying interDyMFoam for floatingObject Elisabeth_ofoam OpenFOAM Programming & Development 7 June 11, 2014 09:42
interDyMFoam with GGI in 3d stawrogin OpenFOAM Running, Solving & CFD 2 January 5, 2011 03:17
error using interDyMFoam with kOmegaSST to simulate sloshing anmartin OpenFOAM Running, Solving & CFD 0 July 20, 2010 14:21
