DPMFoam pressure problems
Old   April 26, 2017, 05:16
Default DPMFoam pressure problems
Ali
ali.m.1 is on a distinguished road
Hello
I'm running a submerged jet impingement test using DPMFoam (3.0.x), and although in the log file it says that the pressure is solving (GAMG: Solving for p, Initial residual = 0.006891, Final residual = 5.435e-05, No Iterations 3), and that it converges, when I open a time directory, the whole field is a uniform 1e5 which is my outlet BC.
Here is my p file in my 0 directory:
\    /   O peration     | Version:  2.2.0                                 |
|   \\  /    A nd           | Web:      www.OpenFOAM.org                      |
FoamFile
    version     2.0;
    format      ascii;
    class       volScalarField;
    object      p;
dimensions      [0 2 -2 0 0 0 0];
internalField   uniform 1e5;
boundaryField
    inlet
        type            zeroGradient;
    walls
        type            zeroGradient;
    pOutTop
        type            totalPressure;
        p0              1e+05;
        U               U.water;
        phi             phi.water;
        rho             none;
        psi             none;
        gamma           1;
        value           uniform 1e+05;
       /* type            fixedValue;
        value           100000;*/
    bottomOutlet
        type            totalPressure;
        p0              1e+05;
        U               U.water;
        phi             phi.water;
        rho             none;
        psi             none;
        gamma           1;
      /*  type            fixedValue;
        value           100000;*/
    impingement
        type            zeroGradient;
    symmetry
        type            symmetry;
Does anyone have any ideas? I'm running a similar case on reactingTwoPhaseEulerFoam with the same BCs and this gives me expected pressure plots.
Ali
ali.m.1 is offline   Reply With Quote
Old   April 26, 2017, 12:47
Ali
Hi All
I realised that if I change the initial p file then the solver runs fine. The problem was that I was confusing gauge pressure and absolute.
Here is the p file that works, in case it will help anyone else in the future:
FoamFile
    version     2.0;
    format      ascii;
    object      p;
internalField   uniform 0;//1e5;
boundaryField
    inlet
        type            zeroGradient;
    walls
        type            zeroGradient;
    pOutTop
        type            totalPressure;
        p0              0;//1e+05;
        U               U.water;
        phi             phi.water;
        rho             none;
        psi             none;
        gamma           1;
        value           uniform 0;//1e+05;
       /* type            fixedValue;
        value           100000;*/
    bottomOutlet
        type            totalPressure;
        p0              0;//1e+05;
        U               U.water;
        phi             phi.water;
        rho             none;
        psi             none;
        gamma           1;
      /*  type            fixedValue;
        value           100000;*/
    impingement
        type            zeroGradient;
    symmetry
        type            symmetry;
dpmfoam, field, pressure
Pressure Inlet Boundary Conditions Mr.Goodcat FLUENT 5 June 20, 2019 02:47
Pressure loss Velocity coupling CFXMUFFIN CFX 1 February 6, 2016 05:43
Pulsatile pressure inlet with pressure outlet a.lynchy FLUENT 3 March 23, 2012 14:45
Pressure Boundary Problems Chris Siemens 2 June 21, 2005 09:20
what the result is negatif pressure at inlet chong chee nan FLUENT 0 December 29, 2001 06:13
