Dynamic Mesh: solidBody mesh movement + controlled cell deformation
Like Tree14Likes
Old   November 7, 2020, 10:10
TWB
quarkz is on a distinguished road
Hi everyone, I read this interesting thread about having different motions with dynamicMesh.
For me, I am trying to simulate a wing with a rotating aileron (grid deformation) and doing a roll motion (entire grid rotates). Is this possible in OF?
I tried many ways and also tried to modify the relativeMotion tutorial. However, it just can't work. Moreover, I tried to use the solver solidBodyDisplacementLaplacian but OF complains that it can't find it. I wonder why.
quarkz is offline   Reply With Quote
Old   December 17, 2020, 02:19
Default interesting toppics
  #42
Steve Fu
Steve Fu is on a distinguished road
Hello Felix,
I also trying to do such a simulation case, the cylinder rotate and translate in the water domain by using tabulated6DoFMotion.
However, I failed many times.
Could you kindly share your case and ideas to me.
Thank you advanced.
Steve Fu is offline   Reply With Quote
Old   October 31, 2021, 08:16
dzs
dntjudme is on a distinguished road
Originally Posted by ConorMD View Post
Hi everyone,
I have a similar task where I am using solidBody mesh movement and cell deformation. This time though, my cell deformation is happening within the solidbody. I am using a displacementLaplacian to model deflections on a rotating foil in a flow.
The problem I am having is that the displacementLaplacian is somehow shrinking the cellZone I am rotating to the point that the simulation fails (see image). The sim fails at the same point in time, regardless of the timestep size.
When the displacementLaplacian is disabled, the sim runs fine. So it appears the definition of my solidBody movement is ok. It appears to be in issue when combining the two solvers together.
Can anyone help me with this?
Thanks!
My dynamicMeshDict:
dynamicFvMesh  dynamicMotionSolverFvMesh;
motionSolverLibs ("libfvMotionSolvers.so");
solvers
	Turbine
		solver solidBody;
		solidBodyCoeffs
   		 	cellZone        rotorVolume;
    			solidBodyMotionFunction  rotatingMotion;
    			rotatingMotionCoeffs
     			 origin		(0 0 0);
      			 axis		(0 -1 0);
     		 	 omega       5.625;
	Foil
		solver displacementLaplacian;
		//cellzone morphZone;
		displacementLaplacianCoeffs
   		diffusivity quadratic inverseDistance (foil1);
Hi Conor,
May I ask what version you are using?
I'm using .org version OpenFOAM v7, and it seems the dynamicMeshDict you have is not working on v7 version.
Thanks
Zs
dntjudme is offline   Reply With Quote
Old   July 1, 2022, 08:32
Default Corner node displacement in overPimpleDyMFoam
  #44
JunaidAhmad's Avatar
Junaid Ahmad Khan
JunaidAhmad is on a distinguished road
Assalam O Aliqum,
I am running this freefall with inlet velocity simulation, and it run alright till it crash. I notice that in overset patch which is a cubic domain. the corners of this overset patch start displacing as you can see in fig above. the solid body whcih is wall is fine. Any solutions to this problem.
Stay Safe, Stay Happy
JunaidAhmad is offline   Reply With Quote
Old   July 1, 2022, 08:58
  #45
Junaid Ahmad Khan
Found the problem it was the inner and outer distance in dynamicMeshDict.
innerDistance 1e5; it was 0.3
outerDistance 1.1e5; it was 0.4
FoamFile
version 2.0;
format ascii;
class dictionary;
object dynamicMeshDict;
dynamicFvMesh dynamicOversetFvMesh;
motionSolverLibs (sixDoFRigidBodyMotion);
//cellZone oversetZone;
solver sixDoFRigidBodyMotion;
sixDoFRigidBodyMotionCoeffs
patches (solidBody);
innerDistance 1e5;
centreOfMass (0.4 0.4 10.3);
//velocity (1 1 1);
g (0 0 -9.81);
// Cuboid dimensions
Lx 0.1;
Ly 0.1;
Lz 0.1;
// Density of the solid
rhoSolid 7800;
rho rhoInf;
rhoInf 1;
// Cuboid mass
mass #eval{ $rhoSolid*$Lx*$Ly*$Lz };
// Cuboid moment of inertia about the centre of mass
momentOfInertia #codeStream
codeInclude
#include "diagTensor.H"
code
scalar sqrLx = sqr($Lx);
scalar sqrLy = sqr($Ly);
scalar sqrLz = sqr($Lz);
os <<
$mass
*diagTensor(sqrLy + sqrLz, sqrLx + sqrLz, sqrLx + sqrLy)/12.0;
report on;
accelerationRelaxation 0.9;
accelerationDamping 0.9;
solver
type Newmark;
// constraints
fixedPoint
sixDoFRigidBodyMotionConstraint point;
centreOfRotation (0.5 0.45 0.1);
//fixedLine
// sixDoFRigidBodyMotionConstraint line;
// //centreOfRotation (0.5 0.45 0.1);
// direction (0 0 1);
fixedAxis
sixDoFRigidBodyMotionConstraint axis;
axis (0 1 0);
y+ = 1 boundary layer mesh with snappyHexMesh Arzed23 OpenFOAM Running, Solving & CFD 6 November 23, 2022 16:15
simulation flapper movement with mesh deformation in CFX sakalido CFX 11 January 27, 2014 15:28
Update of the variables after dynamic mesh motion. gtg258f OpenFOAM Programming & Development 9 January 18, 2014 11:08
Dynamic Mesh for Movement of Piston vigii Fluent UDF and Scheme Programming 0 November 18, 2013 07:43
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues michele OpenFOAM Meshing & Mesh Conversion 2 July 15, 2005 05:15
