sonicFoam for supersonic simulation with butane gas
Old   April 20, 2017, 11:24
Exclamation sonicFoam for supersonic simulation with butane gas
power
enginpower is on a distinguished road
Hello all,
I'm trying to simulate butane gas flowing through the geometry in the following picture sonicFoam.jpg which reach supersonic flow in some throats connecting in tube and out tube.
All patches not indicated in the picture, are signed like walls.
I want to simulate real gas, and I calculated all parameters to get it using Peng-Robinson equation of state as you can check in the files: shared.zip
You can also find inside them all applied boundary conditions. Actually it is the first time I'm using sonicFoam solver, so I'm not so expert about that.
Running the simulation I got this error, but it's not clear to me where is the problem:
Maximum number of iterations exceeded functions are :
15
abort
coded
patchProbes
probes
psiReactionThermoMoleFractions
removeRegisteredObject
residuals
rhoReactionThermoMoleFractions
setTimeStep
sets
surfaces
systemCall
timeActivatedFileUpdate
writeDictionary
writeObjects
    From function Foam::scalar Foam::species::thermo<Thermo, Type>::T(Foam::scalar, Foam::scalar, Foam::scalar, Foam::scalar (Foam::species::thermo<Thermo, Type>::*)(Foam::scalar, Foam::scalar) const, Foam::scalar (Foam::species::thermo<Thermo, Type>::*)(Foam::scalar, Foam::scalar) const, Foam::scalar (Foam::species::thermo<Thermo, Type>::*)(Foam::scalar) const) const [with Thermo = Foam::janafThermo<Foam::PengRobinsonGas<Foam::specie> >; Type = Foam::sensibleInternalEnergy; Foam::scalar = double; Foam::species::thermo<Thermo, Type> = Foam::species::thermo<Foam::janafThermo<Foam::PengRobinsonGas<Foam::specie> >, Foam::sensibleInternalEnergy>]
    in file /home/ubuntu/OpenFOAM/OpenFOAM-4.1/src/thermophysicalModels/specie/lnInclude/thermoI.H at line 66.
FOAM aborting
#0  Foam::error::printStack(Foam::Ostream&) at ??:?
#1  Foam::error::abort() at ??:?
#2  Foam::hePsiThermo<Foam::psiThermo, Foam::pureMixture<Foam::sutherlandTransport<Foam::species::thermo<Foam::janafThermo<Foam::PengRobinsonGas<Foam::specie> >, Foam::sensibleInternalEnergy> > > >::calculate() at ??:?
#3  Foam::hePsiThermo<Foam::psiThermo, Foam::pureMixture<Foam::sutherlandTransport<Foam::species::thermo<Foam::janafThermo<Foam::PengRobinsonGas<Foam::specie> >, Foam::sensibleInternalEnergy> > > >::correct() at ??:?
#4  ? at ??:?
#5  __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6"
#6  ? at ??:?
Aborted (core dumped)
All other similar errors in the forum are different from that because it lists some functions but I've not understood where to set them. And what exeeds 15 iterations? Not clear this point.
Please give me some useful ways to get a good simulation of that, mainly on the boundary condition settings
Thanks
enginpower is offline   Reply With Quote
Old   April 21, 2017, 09:37
power
I solved some errors.
Now it runs but I think it doesn't go over the first iteration. Here the log file is:
|  \\    /   O peration     | Version:  4.1                                   |
|   \\  /    A nd           | Web:      www.OpenFOAM.org                      |
Build  : 4.1
Exec   : sonicFoam
Date   : Apr 21 2017
Time   : 14:19:44
Host   : "engine-VirtualBox"
PID    : 10986
Case   : /home/engine/OpenFoam/2DdobleTube
nProcs : 1
allowSystemOperations : Allowing user-supplied system call operations
Create time
Create mesh for time = 0
PIMPLE: Operating solver in PISO mode
Reading thermophysical properties
Selecting thermodynamics package
    type            hePsiThermo;
    mixture         pureMixture;
    transport       sutherland;
    thermo          janaf;
    equationOfState PengRobinsonGas;
    specie          specie;
    energy          sensibleInternalEnergy;
Reading field U
Creating turbulence model
Selecting turbulence model type RAS
Selecting RAS turbulence model kEpsilon
kEpsilonCoeffs
    Cmu             0.09;
    C1              1.44;
    C2              1.92;
    C3              -0.33;
    sigmak          1;
    sigmaEps        1.3;
Creating field kinetic energy K
No MRF models present
No finite volume options present
Starting time loop
Time = 5e-07
Courant Number mean: 0.576416 max: 108.333
diagonal:  Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0
PIMPLE: iteration 1
DILUPBiCG:  Solving for Ux, Initial residual = 1, Final residual = 0.0892473, No Iterations 1001
DILUPBiCG:  Solving for Uy, Initial residual = 1, Final residual = 0.31323, No Iterations 1001
DILUPBiCG:  Solving for e, Initial residual = 1, Final residual = 9.86494e-10, No Iterations 189
It's not clear to me if it performs the first iteration or not. But what does it mean
in the last lines? Does it runs 189 iterations?
What can I do to understand what does not work in the simulation? Finally I chose a kepsilon model as starting model, but the boundary conditions are almost as set in the attached files (see above).
Hope it can help who wants to suggest me something interesting to learn new things
Thanks anyway
butane, real gas model, sonicfoam, supersonic internal flows
Simulation of radial gas turbine, Inlet velocity components dmaz CFX 17 May 19, 2019 10:45
Gas simulation setup anon_p CONVERGE 7 April 30, 2019 12:49
Ideal gas v.s. Real gas for wing simulation Anna Tian Main CFD Forum 1 December 16, 2013 12:39
SonicFoam simulation probleme bruxellois OpenFOAM 7 October 30, 2010 12:06
Gas pressure question Dan Moskal Main CFD Forum 0 October 24, 2002 23:02
