A mesh independence study when using simpleFoam.
Old   April 17, 2017, 05:53
Default A mesh independence study when using simpleFoam.
Emery
TemC is on a distinguished road
Hi foamers, I Hope you're all doing well...
I'am simulating the flow of a Bingham fluid through a single cylinder, with a constant circular section. (The dimensions of this cylinder are Radius = 0.25 cm and Length = 2.5 cm). So I have one inlet, one outlet, and some lateral walls.
For the velocity field: I set 'zeroGradient' boundary condition at both inlet and outlet; for the lateral walls I set a 'noSlip' BCs, and the initial field is set to (0 0 0).
For the pressure field: I impose a fixed pressure difference between the inlet and the outlet, and a 'zeroGradient' BC for the lateral walls.
The fluid parameters are the yield stress 'tau0', and the fluid consistancy 'k'. I have chosen some values for those parameters. Now I apply a well chosen pressure gradient, so that I obtain a plugged zone with 0.18 cm of radius.
Basicaly the 'plugged zone' is a zone where the fluid velocity is constant.
So far so good.
Now I'am trying to conduct a mesh independence study, to make sure that my simulation results will not depend of the mesh coarsement anymore.
attachment1 is my tolerances, attachment2 is my discretization schemes, and attachment3 shows how my velocity profiles evolve when I refine my mesh.
- When monitoring the residuals, my criteria are reached (both for U and p);
- When checking some probe points for the pressure, they all reach a steady state;
- And about the domain imbalance, the volumetric flow rate at the inlet is exactly the opposite of the one at the outlet.
Now what bothers me is that the extension of this so called 'plugged zone' is increasing when I refine the mesh. I was expecting this extension to remain the same. May it be linked to my discretization Schemes? My tolerances? (It is a steadyState, laminar flow with Re < 0.1)
And secondly, my velocity profile doesn't seem to converge towards a 'limit' profile. Do you think I need to refine the mesh a lot more?
I hope you will find some time to share your point of view, or even some suggestions... Thanks in advance, and have a good day.
Regards.
TemC is offline   Reply With Quote
Old   April 17, 2017, 15:04
Fynn
PanPeter is on a distinguished road
Hi Térence,
How did you mesh your geometry? Did you add a boundary layer?
If not:
If you're interested in the velocity profile in a pipe you must take extra care to finely resolve the steep velocity gradients towards the no-slip wall.
Increase the resolution towards the pipe wall by adding boundary layers, while keeping a fine bulk resolution. Now make your mesh independence study first on the boundary layers and then on the bulk mesh.
cheers,
Fynn
PanPeter is offline   Reply With Quote
Old   April 17, 2017, 16:37
Emery
Hi Fynn,
Thank you very much for your reply. You are really ringing a bell when talking about boundary layer. I've never thought about that... In attachment is the type of geometry I'm currently working with. I do those with Gmsh.
As you guessed, I'am interested in the velocity profile in a pipe. Can you suggest me some threads, links, or whatever where I could find more details about meshing boundary layers?
Thanks in advance, and have a good week.
Regards.
Old   April 17, 2017, 17:01
Fynn
I'm not experienced in gmsh. I like salome for meshing but you could also write a script for a blockMesh.
cheers,
Fynn
Old   April 24, 2022, 11:48
Exclamation have you solve this mesh independence problem?
Zhen Liao
zyliao is on a distinguished road
So far so good.
Regards.
Hi Emery,
These days I met the same mesh independence problem when I simulated the plane-Poiseuille flow, i.e., when the cells incerase, the outlet flux decreases and the value didn't seem to converge to a stable value. I wonder have you solve this problem?
zyliao is offline   Reply With Quote
sliding mesh problem in CFX Saima CFX 46 September 11, 2021 08:38
[mesh manipulation] Importing Multiple Meshes thomasnwalshiii OpenFOAM Meshing & Mesh Conversion 18 December 19, 2015 19:57
Solver Error for fine mesh in translationally periodic element AliLemprex CFX 3 March 26, 2014 15:32
[snappyHexMesh] Layers:problem with curvature giulio.topazio OpenFOAM Meshing & Mesh Conversion 10 August 22, 2012 10:03
Mesh generator and CFD solver Gennady Kireyko Main CFD Forum 0 May 6, 2001 12:13
