April 12, 2017, 20:15 |
particle number/mass flux across a plane
Karelke Yu
Rep Power: 12 |
Hi all,
I am doing LPT with the very simple solidParticle class in OF-2.3.0. I have a question for post-processing the LPT data regarding calculating the particle (number/mass) flux across a specific user-defined plane or surface. In my case, the plane is in the computational domain and it's not a patch. The plane can be easily located by X=10. I also want to record the data (diameter, density, location) of the particles which contribute to the particle flux across the plane. But what is the best way to do this? I do not know if this should be done by changing the source code of the solidParticle class or just looking for a post-processing utility or using paraview. If there is a method/utility/patchType for this when the plane is a patch, pls also let me know. Thanks in advance. Karelke |
May 19, 2017, 19:32 |
#2 | |
Karelke Yu
Rep Power: 12 |
UDF for particle interception with pt_termination fortran routine | abcdefgh | CFX | 6 | October 6, 2019 14:30 |
Question about heat transfer coefficient setting for CFX | Anna Tian | CFX | 1 | June 16, 2013 07:28 |
DPM UDF particle position using the macro P_POS(p)[i] | dm2747 | FLUENT | 0 | April 17, 2009 02:29 |
Display Particle Position on a Plane | Jana | FLUENT | 2 | July 13, 2007 03:46 |
mass flux at any plane | Mohan R. | FLUENT | 0 | March 21, 2007 06:43 |
