April 10, 2017, 13:08 |
timeVaryingMappedFixedValue: Won't run
Rep Power: 9 |
Hi!
I am trying to incorporate a stationary external inlet BC for U in a channel flow problem in openFoam using timeVaryingMappedFixedValue. I have managed to solve the problem with a parabolic inlet BC, but when I change to the external BC using timeVaryingMappedFixedValue, which looks a little bit more flat than the parabolic profile, the program will not solve. All velocity values for the exernal BC are in the same ballpark as for the parabolic velocity profile, which solved, so the physics should not be much changed. My files look very much like the original PitzDaily from the tutorial. What I have changed is: - Copied the folder boundaryData from pitzDailyExptInlet-tutorial - Deleted the files k and u in the above mentioned folder, since I do not change the inlet BC's for these variables (also tried keeping these files, but that does not change anything) - Edited the files in "U" and "points" in boundaryData to my physical problem - In the file "U" in the normal folder "0", I changed the U-inlet to be as in the corresponding file in pitzDailyExptInlet. Doing the above gives the error message below. I hope someone maybe see what is going wrong here! I tried doing the same changes in the original PitzDaily, and that worked. The error message I get for my channel problem: Code:
Build : 4.1 Exec : simpleFoam // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create mesh for time = 0 SIMPLE: convergence criteria field p tolerance 0.01 field U tolerance 0.001 field "(k|epsilon|omega|f|v2)" tolerance 0.001 Reading field p Reading field U #0 Foam::error::printStack(Foam::Ostream&) at ??:? #1 Foam::sigFpe::sigHandler(int) at ??:? #2 ? in "/lib/x86_64-linux-gnu/libc.so.6" #3 Foam::pointToPointPlanarInterpolation::calcCoordinateSystem(Foam::Field<Foam::Vector<double> > const&) const at ??:? #4 Foam::pointToPointPlanarInterpolation::pointToPointPlanarInterpolation(Foam::Field<Foam::Vector<double> > const&, Foam::Field<Foam::Vector<double> > const&, double, bool) at ??:? #5 Foam::timeVaryingMappedFixedValueFvPatchField<Foam::Vector<double> >::checkTable() at ??:? #6 Foam::timeVaryingMappedFixedValueFvPatchField<Foam::Vector<double> >::updateCoeffs() at ??:? #7 Foam::timeVaryingMappedFixedValueFvPatchField<Foam::Vector<double> >::timeVaryingMappedFixedValueFvPatchField(Foam::fvPatch const&, Foam::DimensionedField<Foam::Vector<double>, Foam::volMesh> const&, Foam::dictionary const&) at ??:? #8 Foam::fvPatchField<Foam::Vector<double> >::adddictionaryConstructorToTable<Foam::timeVaryingMappedFixedValueFvPatchField<Foam::Vector<double> > >::New(Foam::fvPatch const&, Foam::DimensionedField<Foam::Vector<double>, Foam::volMesh> const&, Foam::dictionary const&) at ??:? #9 Foam::fvPatchField<Foam::Vector<double> >::New(Foam::fvPatch const&, Foam::DimensionedField<Foam::Vector<double>, Foam::volMesh> const&, Foam::dictionary const&) at ??:? #10 Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh>::Boundary::readField(Foam::DimensionedField<Foam::Vector<double>, Foam::volMesh> const&, Foam::dictionary const&) at ??:? #11 Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh>::readFields(Foam::dictionary const&) at ??:? #12 Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh>::readFields() at ??:? #13 Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh>::GeometricField(Foam::IOobject const&, Foam::fvMesh const&) at ??:? #14 ? at ??:? #15 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6" #16 ? at ??:? Floating point exception (core dumped) |
April 10, 2017, 15:12 |
Rep Power: 9 |
I think I found one bug in my program.
For "points" I used the exact same points for "minz" and "maxz". Looking at what was done in PitzDaily, there was a slight difference in the z-coordinate. Now I have changed the z-coordinate slightly, but still it will not run. The new error message is: Code:
// * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create mesh for time = 0 SIMPLE: convergence criteria field p tolerance 0.01 field U tolerance 0.001 field "(k|epsilon|omega|f|v2)" tolerance 0.001 Reading field p Reading field U --> FOAM FATAL IO ERROR: "ill defined primitiveEntry starting at keyword 'version' on line 10 and ending at line 98" file: /home/.../constant/boundaryData/inlet/0/U at line 98. From function void Foam::primitiveEntry::readEntry(const Foam::dictionary&, Foam::Istream&) in file db/dictionary/primitiveEntry/primitiveEntryIO.C at line 189. FOAM exiting |
April 10, 2017, 15:18 |
Rep Power: 9 |
Found the error.
One file included a parenthesis that was not supposed to be there. |
external bc |
fatal overflow error in the FINMES subroutine for CHT run | prashant79_ss | CFX | 5 | September 27, 2014 05:54 |
Cannot run phoenix on linux opensuse 13.1 kde | mabal | Phoenics | 0 | June 15, 2014 07:16 |
[mesh manipulation] Cannot get refineMesh to run in parallel | smschnob | OpenFOAM Meshing & Mesh Conversion | 2 | June 3, 2014 12:20 |
First Parallel Run - need some help | Gian Maria | OpenFOAM | 3 | June 17, 2011 13:08 |
Windows 64-bit, Distributed Parallel Run Issues... | Erich | CFX | 3 | March 28, 2006 17:36 |
