Coupled Species boundary condition
Like Tree4Likes
Old   February 28, 2020, 01:49
Zhiheng Wang
Zhiheng Wang is on a distinguished road
Better comment or provide switch turbulence part as/if turbulence is used then only species will be coupled in TotalAdvectivePyrolysisCoupled, for momentum in fireFOAM version of FM-Global you can take the boundary of flowRateInletCoupledPyrolysisCoupled and fo temperature radiationCoupled compile as your need.
Zhiheng Wang is offline   Reply With Quote
Old   September 27, 2021, 08:46
Bushra Rasheed
B_R_Khan is on a distinguished road
Originally Posted by ashish.vinayak View Post
Hi Archana,
This multi-region transport was a part of my master thesis. I would suggest you refer to it Here's the link on RG: LINK
Inside the thesis, you will also find the GitHub repo, where you can download the boundary conditions. They have been compiled on OpenFOAM-2.4. However, someone did try to compile the BC recently for OpenFOAM-5 and it seemed to work for them barring some changes in the Make folder.
Hi!
I want to give a specie mass fraction boundary condition in one region only. Can you guide which changes should I make? Is your boundary condition applicable for single region as well or is there any simpler way around for single region?
Thanks!
Edit: I used salar transport function object from condensation on wind shield tutorial and was able to achieve desired results
B_R_Khan is offline   Reply With Quote
boundary conditions, multiregion, openfoam, species
My radial inflow turbine Abo Anas CFX 27 May 11, 2018 02:44
Boundary Condition for reacting species flow at outlet Astrodan OpenFOAM Running, Solving & CFD 0 September 25, 2014 11:59
Error finding variable "THERMX" sunilpatil CFX 8 April 26, 2013 08:00
vorticity boundary condition bearcharge Main CFD Forum 0 May 14, 2010 12:32
RPM in Wind Turbine Pankaj CFX 9 November 23, 2009 05:05
