High temperature of parcels in coalChemistryFoam |
April 5, 2017, 10:33 |
amin jalalian
Rep Power: 12 |
Hi Foamers,
I have high max temperature for coal parcels around 5000 K, and solver write "Maximum number of iterations exceeded" and stop. I changed maximum time step from 2.5e-5 to 4e-6 but not be correct. I changed h solver from PBiCG to smoothSolver but not be correct. I changed for T of parcel from Euler to analytical but the error is yet. I attached the results picture. What can I do? |
June 5, 2017, 10:49 |
David Buentello
Rep Power: 9 |
What are your boundary conditions? Depending on the case, sometimes those errors arise when the mass balance is incorrect (check the sum of the mass fractions in the boundary conditions, as well as any other physical incoherence that may be present). The time step may be related as well.
[openSmoke] libOpenSMOKE | Tobi | OpenFOAM Community Contributions | 562 | January 25, 2023 10:21 |
problem whit set a high region temperature for start combustion | ca3tiel | FLUENT | 0 | May 22, 2016 09:26 |
Ansys CFX problem: unexpected very high temperatures in premix laminar combustion | faizan_habib7 | CFX | 4 | February 1, 2016 18:00 |
Difficulty In Setting Boundary Conditions | Moinul Haque | CFX | 4 | November 25, 2014 18:30 |
Methane+air temperature too high | Stanislav Kraev | FLUENT | 5 | June 3, 2004 11:54 |
