April 2, 2017, 14:28 |
Conjugate Heat Transfer in OpneFOAM 2.2.0
seyfi girgin
Rep Power: 9 |
Hello all,
I am new to OpenFOAM. I started to run cavity example in OpenFOAM.I want to understand the case conjugate heat transfer. I found a tutorial actually which is in the link. https://openfoamwiki.net/index.php/T..._Heat_Transfer However, it is not easy like in the cavity tutorial.Can someone explain to me how to handle this tutorial in OpenFOAM 2.2.0? I download the necessary files but could not progress. Please help Regards, |
April 2, 2017, 15:16 |
Oskar
Rep Power: 10 |
Hello.
Your case is preapred for openFoam 1.3 and I think You cannot run it in openFoam 2.2.0 Maybe this one will satisfy You? http://openfoamwiki.net/index.php/Ge..._-_planeWall2D |
April 2, 2017, 17:05 |
seyfi girgin
Rep Power: 9 |
If so I need to post a new thread cause in planewall2D tutorial there is no polyMesh file in constant folder, I cannot create mesh.
April 2, 2017, 18:04 |
Oskar
Rep Power: 10 |
I have just download planeWall2D-2.2.tar.gz and it looks everything is inside.
conjugate heat transfer, openfoam 2.2.0 |
VOF with conjugate heat transfer | vs138 | Fluent Multiphase | 1 | November 12, 2014 08:52 |
fireFoam - conjugate heat transfer | Duy Le | OpenFOAM Programming & Development | 0 | October 2, 2014 10:48 |
conjugate heat transfer in porous media-variable HTC | hmasenger | CFX | 3 | June 21, 2014 07:57 |
Conjugate Heat transfer in CFX | ksp1717 | CFX | 11 | December 10, 2010 22:07 |
Conjugate heat transfer with periodic boundaries | Suresh | FLUENT | 0 | February 23, 2009 09:51 |
