MRFSimpleFoam, 1/3 WindTurbine Simulation, Timestep Continuity Errors, Diverges
Old   March 31, 2017, 18:13
Default MRFSimpleFoam, 1/3 WindTurbine Simulation, Timestep Continuity Errors, Diverges
Sohail
sohailr is on a distinguished road
Dear all,
I am trying to simulate a single wind turbine blade (1/3 of the complete geometry) using simpleFoam (with MRFProperties file).
At the moment the simulation is laminar, with fixedValue inlet velocity of 5m/s and zeroGradient pressure and an outlet pressure of 0. I am using cyclicAMI for periodicity. The blade should rotate at 12 rpm (omega = 12) but I am have issues getting it to converge (even for omega = 0).
The residuals oscillate then the time step continuity errors blow up.I have tried several settings for the solver and schemes, as well as specifying omega = 0 to get a stable solution. In all cases the run diverges. I have also tried changing the boundary conditions and the mesh.
checkMesh showed no errors with the mesh.
I have attached the log files for simpleFoam, snappyHexMesh and checkMesh for your reference, as well as my fvSolution and fvSchemes files. The dropbox link to the complete case setup is below
https://www.dropbox.com/sh/iio2zzzt7...Yx8r3gA2a?dl=0
The attached pic shows my domain (green=inlet, red=outlet, blue = cyclicAMI).
I greatly appreciate any and all help with this problem!
Thanks!!
Sohail
checkMesh.txt
fvSchemes.txt
fvSolution.txt
simpleFoam.txt
sohailr is offline   Reply With Quote
mrfsimplefoam, simplefoam convergence, windturbine
courant number increases to rather large values 6863523 OpenFOAM Running, Solving & CFD 22 July 6, 2023 00:48
Transient simulation not converging skabilan OpenFOAM Running, Solving & CFD 14 December 17, 2019 00:12
Help for the small implementation in turbulence model shipman OpenFOAM Programming & Development 25 March 19, 2014 11:08
How to write k and epsilon before the abnormal end xiuying OpenFOAM Running, Solving & CFD 8 August 27, 2013 16:33
IcoFoam parallel woes msrinath80 OpenFOAM Running, Solving & CFD 9 July 22, 2007 03:58
