Pressure Driven Flow - Boundary Condition
Old   March 30, 2017, 10:58
Default Pressure Driven Flow - Boundary Condition
Fabrizio
kasto89 is on a distinguished road
Hi all, I really need a super urgent help because i am going crazy and I hope someone could help me.
I need to solve the system in the attached picture.
Attachment 55031
We have 3 inlet side and 1 outlet in the upper side. (they are 3 heating exchanger assembled like in the picture, and a suction fan in the top, but I dont need to solve it, I only need to simulate the flow in the box).
I want to understand if the 3 inlets have the same flows or not (i suppose the inlet2 is favorite). So I want to implement a pressure driven flow, imposing the same pressure (for example 150Pa) in the inlets and 0 to the outlet. I tried it, but obiouvsly I have no convergence, bcs I used zeroGradient on all sides for velocity.
Can you please let me know how to set in detail boundary for pressure and velocity and maybe also for k and epsilon for this case?
Do you have some links for a pressure driven INCOMPRESSIBLE guide? I didnt find anything useful.
Thanks
Best Regards
Fabrizio
kasto89 is offline   Reply With Quote
Old   March 30, 2017, 16:01
piu58's Avatar
Uwe Pilz
piu58 is on a distinguished road
Pressure only b.c. are sometimes hard to manage. I recommend to set the pressure gradient to zero at the outlet. You may look in the solution files where it falls and may correct your inlet values if necessary.
Uwe Pilz
Die der Hauptbewegung überlagerte Schwankungsbewegung ist in ihren Einzelheiten so hoffnungslos kompliziert, daß ihre theoretische Berechnung aussichtslos erscheint. (Hermann Schlichting, 1950)
piu58 is offline   Reply With Quote
Old   March 30, 2017, 16:08
Default pressure driven
Fabrizio
Hi, thanks for your reply. I really tried all possible configuration for boundary. But please, be more clear : if i use zerogradient for pressure at outlet I should set the velocity at outlet and the pressure at inlet, correct?
Old   March 30, 2017, 23:55
Arjun
arjun will become famous soon enougharjun will become famous soon enough
The whole top is outlet or the outlet is at the center?
arjun is offline   Reply With Quote
Old   March 31, 2017, 01:31
piu58's Avatar
Uwe Pilz
Yes, that should fit your problem. You'll see how the flow divides between the three inlets.
Uwe Pilz
Old   March 31, 2017, 09:02
Fabrizio
the whole top is the outlet. There is a sucting fan in the top (but I didnt make the mesh on it), so I want impose the static pressure at inlet to simulate the fan.
thanks
Error - Solar absorber - Solar Thermal Radiation MichaelK CFX 12 September 1, 2016 06:15
sonicFoam - pressure driven pipe: flow continuity violation and waveTransmissive BC Endel OpenFOAM Running, Solving & CFD 3 September 11, 2014 17:29
Radiation interface hinca CFX 15 January 26, 2014 18:11
An error has occurred in cfx5solve: volo87 CFX 5 June 14, 2013 18:44
flow in duct-fixed pressure boundary condition sepidehkavousi Main CFD Forum 9 May 20, 2012 13:11
