Simulations are not converging for many elementes (more than 1 000 000)
Old   March 27, 2017, 07:55
Post Simulations are not converging for many elementes (more than 1 000 000)
silvai is on a distinguished road
Hi OpenFOAM people!
I am simulating blood flow in a 3D artery, in OpenFOAM code, and unfortunatly, my simulations are not converging for many elements (more than 1 000 000 like you can see below in the "Boundary" file). And many elements are necessary for mt work. I know this is a problem element, since for a number of elements much lower (5 or 10 times) the simulation converges.
In the "boundary" file, the elements are:
wall-interior
type wall;
nFaces 59205;
startFace 1248069;
inlet_lca
type patch;
nFaces 2625;
startFace 1307274;
outlet_lda
type patch;
nFaces 2130;
startFace 1309899;
outlet_lcx
type patch;
nFaces 2214;
startFace 1312029;
In the "controlDict" file:
startFrom latestTime;
startTime 0;
stopAt endTime;
endTime 3.0;
deltaT 0.001;
writeControl timeStep;
writeInterval 10;
purgeWrite 0;
writeFormat ascii;
writePrecision 6;
writeCompression off;
timeFormat general;
timePrecision 6;
runTimeModifiable true;
In "svSchemes" file:
ddtSchemes
default Euler;
gradSchemes
default Gauss linear;
grad(p) leastSquares;
divSchemes
default none;
div(phi,U) Gauss linear;
laplacianSchemes
default none;
laplacian(nu,U) Gauss linear corrected;
laplacian((1|A(U)),p) Gauss linear corrected;
interpolationSchemes
default linear;
interpolate(U) linear;
snGradSchemes
default corrected;
fluxRequired
default no;
p ;
In "fvSolution" file:
solvers
p
solver PCG;
preconditioner DIC;
tolerance 1e-06;
relTol 0;
U
solver PBiCG;
preconditioner DILU;
tolerance 1e-05;
relTol 0;
PISO
nCorrectors 4;
nNonOrthogonalCorrectors 2;
Someone have any sugestion what parameters I should modify for that simulations can converge for so many elements ( and also for running faster)?
I would be very happy and grateful with your answers and sugestions.
silvai is offline   Reply With Quote
Old   March 27, 2017, 11:31
guilha is on a distinguished road
How did you do the mesh? Run the checkMesh with the options -allGeometry and -allTopology.
Se Urso Vires Foge Tocando Gaita Para Hamburgo
guilha is offline   Reply With Quote
Old   March 27, 2017, 13:53
piu58's Avatar
Uwe Pilz
piu58 is on a distinguished road
Really? I recommend to start wit 2d, may be cylinder symmetric. Some of the problems may arise in this case already and can be solved without much effort.
You may get convergence problems if you have very small and large cells in the same geometry. An artery is not a geometric complicated structure and may be simplified, if you look at differets aspects of your simulation in different geometric mapping. This may save complexity and cell numbers too.
What do you want to find out with your simulation?
Uwe Pilz
Die der Hauptbewegung überlagerte Schwankungsbewegung ist in ihren Einzelheiten so hoffnungslos kompliziert, daß ihre theoretische Berechnung aussichtslos erscheint. (Hermann Schlichting, 1950)
piu58 is offline   Reply With Quote
Old   April 3, 2017, 11:19
Post first problem solved! :) Now... another problem...
Thank you for your answer.
2D simulations were already done in previous work. However, I need 3D simulations, now, for futher study.
I already solved this problem!!!
Previous simulations are converging much more faster using the multi-grid solver GAMG for Pressure. And, I also used a bounded scheme for div(phi, U) to avoid divergence. The 3D blood flow simulations using a simple model to define blood rheology and conservative equations implemented in OpenFoam, are running faster (only 1 day!) for more than 1 000 000 elements.
Also, the results are accurate since they are coincident with that obtained through the comercial code ANSYS.
However.... I also implemented a complex blood rheology to define in a more accurate way the blood physical properties. These properties are defined through a constitutive equation, which conservative equations depend on this constitutive equation. So, since OpenFoam is an Open Source Code, I modified the conservative equations and implemented the constitutive equation (defining blood rheology more correctly). This code was already validated in 2D dimension of the artery (with much less elements!).
In this way... My question is....
I want to simulate the previous case, in 3D dimension with more than 1 000 000 elements, faster. The simulations are too slow... with the risk of divergence , since, now, this code is more complex than the first one.
Do you have any suggestion (modify any method or parameter) for that simulations can run a lot more faster, for this case, and do not have the risk to diverge?
"boundary" file:
wall-interior
type wall;
nFaces 59205;
startFace 1248069;
inlet_lca
type patch;
nFaces 2625;
startFace 1307274;
outlet_lda
type patch;
nFaces 2130;
startFace 1309899;
outlet_lcx
type patch;
nFaces 2214;
startFace 1312029;
The "controlDict" file than I am using is:
application elasticshearthinFluidFoam;
startTime 0;
stopAt endTime;
endTime 3.0;
deltaT 0.0005;
writeControl adjustableRunTime;
writeInterval 0.01;
purgeWrite 0;
writeFormat ascii;
writePrecision 6;
writeCompression uncompressed;
timeFormat general;
timePrecision 6;
graphFormat raw;
runTimeModifiable yes;
adjustTimeStep on;
maxCo 0.8;
maxDeltaT 0.001;
The "fvSchemes" file is:
ddtSchemes
default Euler;
gradSchemes
grad(p) Gauss linear;
grad(U) Gauss linear;
divSchemes
default none;
div(phi,U) Gauss SFCD;
div(phi,detAfirst) Gauss Minmod;
div(phi,detAsecond) Gauss Minmod;
div(phi,detAthird) Gauss Minmod;
div(phi,detAfourth) Gauss Minmod;
div(phi,taufirst) Gauss Minmod;
div(phi,tausecond) Gauss Minmod;
div(phi,tauthird) Gauss Minmod;
div(phi,taufourth) Gauss Minmod;
div(tau) Gauss linear;
laplacianSchemes
default none;
laplacian(etaPEff,U) Gauss linear corrected;
laplacian(etaPEff+etaS,U) Gauss linear corrected;
default linear;
interpolate(HbyA) linear;
snGradSchemes
default corrected;
fluxRequired
default no;
p;
The "fvSolution" file is:
solvers
p
solver GAMG;
preconditioner
// preconditioner Cholesky;
preconditioner FDIC;
cycle W-cycle;
policy AAMG;
nPreSweeps 0;
nPostSweeps 2;
groupSize 4;
minCoarseEqns 20;
nMaxLevels 100;
scale off;
smoother ILU;
tolerance 1e-05;
relTol 0;
minIter 0;
maxIter 800;
agglomerator faceAreaPair;
nCellsInCoarsestLevel 100;
mergeLevels 1;
smoother GaussSeidel;
U
solver BICCG;
preconditioner
tolerance 1e-6;
relTol 0;
minIter 0;
maxIter 1000;
nCellsInCoarsestLevel 4;
mergeLevels 1;
smoother DILUGaussSeidel;
detAfirst
solver BICCG;
preconditioner
tolerance 1e-6;
relTol 0;
minIter 0;
maxIter 1000;
mergeLevels 1;
detAsecond
solver BICCG;
preconditioner
tolerance 1e-6;
relTol 0;
minIter 0;
maxIter 1000;
mergeLevels 1;
detAthird
solver BICCG;
preconditioner
tolerance 1e-6;
relTol 0;
minIter 0;
maxIter 1000;
mergeLevels 1;
detAfourth
solver BICCG;
preconditioner
tolerance 1e-6;
relTol 0;
minIter 0;
maxIter 1000;
mergeLevels 1;
taufirst
solver BICCG;
preconditioner
tolerance 1e-6;
relTol 0;
minIter 0;
maxIter 1000;
mergeLevels 1;
tausecond
solver BICCG;
preconditioner
tolerance 1e-6;
relTol 0;
minIter 0;
maxIter 1000;
mergeLevels 1;
tauthird
solver BICCG;
preconditioner
tolerance 1e-6;
relTol 0;
minIter 0;
maxIter 1000;
mergeLevels 1;
taufourth
solver BICCG;
preconditioner
tolerance 1e-6;
relTol 0;
minIter 0;
maxIter 1000;
mergeLevels 1;
PISO
nCorrectors 1;
pRefCell 200;
pRefValue 10000;
// nCorrectors 2;
// nNonOrthogonalCorrectors 0;
// pRefCell 0;
// pRefValue 0;
relaxationFactors
p 0.3;
U 0.5;
detAfirst 0.3;
detAsecond 0.3;
detAthird 0.3;
detAfourth 0.3;
taufirst 0.3;
tausecond 0.3;
tauthird 0.3;
taufourth 0.3;
I will be greatful! Thank you very much!
Old   April 20, 2017, 06:44
Sorry for the late answer. I am glad that you could resolve your issues.
I do not know what you can do to speed up the simulation just by the setup. An obvious answer is to run it in parallel.
Old   April 20, 2017, 08:16
Thank you very much for your answer.
I already solved the problem.
3d simulations, many elements, not convergence, openfoam
