solid body rotation of grid
Old   March 21, 2017, 17:41
Default solid body rotation of grid
Duncan Roy van der Heul
Duncan_vdH is on a distinguished road
We are working on a case with imposed rotational motion of a partially submerged solid body. With the imposed motion, the grid deformation is controlled by the diffusivity model.
It turns out to be very challenging to avoid grid folding in the inner part of the boundary layer cells. Even the cells adjacent to the boundary are slightly deformed,
nearly irrespective of the chosen diffusivity model.
In the 6DOF solver you can exclude deformation inside an 'inner radius'.
Is something similar possible for imposed motion? So concentrate all grid deformation
outside the boundary layer?
Thanks in advance,
Duncan
Duncan_vdH is offline   Reply With Quote
Old   March 22, 2017, 14:57
Tom Fahner
tomf will become famous soon enoughtomf will become famous soon enough
Send a message via MSN to tomf Send a message via Skype™ to tomf
Hi Duncan,
It sounds like you could have a sliding AMI interface to rotate only a part of the domain, like in the propeller tutorial, or is there a reason that this is not possible?
If so, please elaborate on the problem a bit.
Regards,
Tom
tomf is offline   Reply With Quote
Old   March 22, 2017, 15:03
Hi Tom,
Thank you for replying.
We have used a sliding mesh in the past, but found that the sliding mesh creates disturbances in the interface (the free surface interface): small artificial waves due to inaccuracies in the interpolation I think.
The geometry of the solid body that rotates has sharp corners, and it is exactly at the corners the grid folds. I was wondering why no nonOrthogonal corrections are applied for solution of the Poisson equation for the displacement.
An alternative would be to use the cell displacement from the 6dof solver but with prescribed motion. However, it is unclear how to set up such a case.
Best,
Duncan
[DesignModeler] Merge surface body and solid body balmyheart ANSYS Meshing & Geometry 0 December 19, 2016 05:39
how to make a solid body from IGES files (surfaces) e_cfd STAR-CCM+ 5 August 25, 2015 01:28
[ANSYS Meshing] how to have finer mesh in just a part of a solid body juste ANSYS Meshing & Geometry 3 March 31, 2015 08:59
how to move a solid body along a clear line m.r_khani FLUENT 0 November 26, 2011 08:04
Combustion Convergence problems Art Stretton Phoenics 5 April 2, 2002 06:59
