Mark Position of the Particle which left the domain. |
March 15, 2017, 13:46 |
Himanshu Sharma
Rep Power: 14 |
Hi Foamer's,
I am running icoUncoupledKinematicParcelFoam. In my domain I have a inlet and an outlet. For a pre-computed flow field the "U", I initialize my particle and let them evolve with time. For example I have 100 particles at t=0 as time evolve t +dt the number of particles in the domain goes to 95. 5 Particles leaves the domain. OpenFOAM writes Positions for each time step, but doesn't write the particles which have left the domain i.e the next time step file contains 95 points. My objective: I would like to know the Particle which left the domain and write there positions as a chosen point (x',y',z') which indicate/mark that the particle has left the domain. I want to do this because I want to maintain the Number of particles in the "positions" file written by OpenFoam as constant. I will really appreciate if someone can suggest some route to achieve the objective.I am not familiar with Lagrangian classes in OF in detail, therefore if someone can direct me what modifications can help. Thank you |
March 16, 2017, 01:36 |
Yogesh Bapat
Rep Power: 16 |
Hello ,
You can try using PatchPostProcessing cloud function object. I think it should provide required information. Regards, -Yogesh |
March 16, 2017, 15:03 |
#3 | |
Himanshu Sharma
Rep Power: 14 |
Further, I found that at each time step in the Lagrangian folder, a file origID can that be used anyhow to identify which particle left as I have only single particle in each parcel, and I see that the list size changes with the time step. |
August 21, 2020, 10:27 |
Lucie Recurt
Rep Power: 6 |
hello!
maybe it's a little bit late for an answer but i had the same problem and the only solution that I found to fix it is to put stick at the outlet patch interaction so the particles don't really leave the domain but stay at the outlet and because it's inside the domain you have their positions |
PatchInjection: Initial Particle Position | mayank.dce2k7 | OpenFOAM Programming & Development | 1 | October 6, 2022 12:11 |
Multiphase flow - incorrect velocity on inlet | Mike_Tom | CFX | 6 | September 29, 2016 01:27 |
Uniform inlet particle distribution without position file | mayank.dce2k7 | OpenFOAM Running, Solving & CFD | 0 | December 5, 2013 17:24 |
Particles leave my domain (Discrete Particle Model) | diffo | FLUENT | 0 | March 19, 2009 11:23 |
how to know position of particle in PTK | areriko | CFX | 0 | November 19, 2007 21:19 |
