Large time step continuity errors
Old   March 13, 2017, 10:23
Default Large time step continuity errors
homersimpson is on a distinguished road
hi,
im running a case, where gas is flowing from two inlets into one small pipe. Inlets and outlets have micrometer dimension. The mesh seams fine if i use checkMesh.
Now my problem:
The time step continuity erros gets quite lare after approx 10 timesteps and the simulation convergerges, no change in pressure and velocity anymore although the simulation is definitely not finished. Attached you find u and p file from the 0 folder
homersimpson is offline   Reply With Quote
Transient simulation not converging skabilan OpenFOAM Running, Solving & CFD 14 December 17, 2019 00:12
High Courant Number @ icoFoam Artex85 OpenFOAM Running, Solving & CFD 11 February 16, 2017 14:40
Floating point exception error lpz_michele OpenFOAM Running, Solving & CFD 53 October 19, 2015 03:50
IcoFoam parallel woes msrinath80 OpenFOAM Running, Solving & CFD 9 July 22, 2007 03:58
Could anybody help me see this error and give help liugx212 OpenFOAM Running, Solving & CFD 3 January 4, 2006 19:07
