Snow collection around a building
Old   March 13, 2017, 09:20
Default Snow collection around a building
Sarah Leenknegt
SarahLee is on a distinguished road
Dear Foamers
We would like to simulate the snow piling up around a building, in order to determine critical corners and test improvements to reduce local build-up.
I am however completely new to multi-phase flow. I am trying to find a tutorial to get me started, but don't find an appropriate one.
I did find the report from Jan Potac at Chalmers using twophaseeulerfoam, but this report also doesn't seem to provide a final solution and reports problems with snow not piling up, but drifting on.
If we don't get a two-phase simulation up and running, is it possible to do a steady-state wind simulation and try to predict qualitatively in Paraview through particle tracking which areas are critical?
Could anyway put me on the right path regarding tutorials, solvers or further reading material?
Thanks!
Sarah
SarahLee is offline   Reply With Quote
Old   March 16, 2017, 06:02
akidess's Avatar
Anton Kidess
You do not want to begin with a multiphase simulation, especially if you are new to OpenFOAM and multiphase flow. Start with a stationary wind simulation and do lagrangian particle tracking to see where the particles stick.
*On twitter @akidTwit
*Spend as much time formulating your questions as you expect people to spend on their answer.
Old   July 12, 2018, 04:50
Hongxiang Yu
Nicole Yu LZ is on a distinguished road
Hey, I recently started this similar program, and also I am searching for this topic, so did you finally solved this problem? can you give me some advice?
Nicole Yu LZ is offline   Reply With Quote
multiphase, openfoam, snow, wind
[foam-extend.org] paraview not runing? (foam extended 3.2 and ubuntu 15.04) Milan2013 OpenFOAM Installation 23 April 20, 2017 06:49
[OpenFOAM.org] OpenFOAM 2.3.0 on CentOS 6.5 entropies OpenFOAM Installation 33 January 4, 2017 06:01
[foam-extend.org] Error compiling OpenFOAM-1.6-ext Canesin OpenFOAM Installation 137 January 20, 2016 15:56
Paraview Compiling Error (OpenFOAM 2.1.x + openSUSE 12.2) sfigato OpenFOAM Installation 22 January 31, 2013 11:16
Compilation error OF1.5-dev on Suse10.3 darenyang OpenFOAM Installation 0 April 29, 2009 05:55
