sonicFoam simulation, no change anymore
Old   March 10, 2017, 04:49
Default sonicFoam simulation, no change anymore
homersimpson is on a distinguished road
Im running a case with an modified sonicFoam solver. I added the adjustable runtime. Meshing and and everything works fine, i also used checkMesh.I can start the Simulation and it runs smoothly without any Errors until it is finished.
Now here comes the Problem: After approx 10-12 timesteps the simulation is in a steady state. No changes in pressure/velocity anymore. There is no transition/change in the mesh or anything.
I couldnt figure out the Problem so far and i dont know to what it is most likely related. Does someone has an idea what could be the reason and where i should start to look at?
I can also post some files but which one would help you the most?
homersimpson is offline   Reply With Quote
Change settings during a simulation RaiderDoctor ANSYS 4 June 20, 2017 21:15
Change a boundary condition based on simulation result and recompute the simulation Robin.Kamenicky CFX 1 March 7, 2017 19:35
Change BCs and restart simulation be89 OpenFOAM Running, Solving & CFD 1 February 28, 2017 13:02
Change writeIntervall during simulation Christian86 OpenFOAM Programming & Development 3 February 10, 2017 06:10
Change BCs during simulation tav98f CFX 2 September 27, 2011 17:00
