Lesser than reference pressure in InterFOAM
Old   March 9, 2017, 15:58
Default Lesser than reference pressure in InterFOAM
shashank moghe
smog is on a distinguished road
Hello all,
I am setting my outlet pressure to 1e5. This should set the reference pressure for my domain. My mesh does not have dynamic motion (I have implemented acceleration addition to the gravity term to mimic the dynamic motion of my domain). There is a no slip BC for U at the walls and another patch P1. I am interested in monitoring the pressure on P1.
The problem I face - I see negative (less than 1e5) pressure at the patch for a part of the cycle (the acceleration I add to the 'g' term mimics a cycle with a fixed amplitude).
I understand that the incompressible fluid draws from the static pressure as per the Bernoulli's eqn. But since at the wall, the velocity is zero, all the dynamic pressure should get converted to static pressure - then why do I see negative gage pressure?
Any help will be appreciated. I am working with OF 2.4.x.
smog is offline   Reply With Quote
CFX Solver stopped with error when requested for backup during solver running Mfaizan CFX 40 May 13, 2016 07:50
Compression stoke is giving higher pressure than calculated nickjuana CFX 62 May 19, 2015 14:32
OpenFoam-1.7.x on Suse 11.2 (64bit) does not compile val46 OpenFOAM Installation 4 August 27, 2010 04:43
Error with Wmake skabilan OpenFOAM Installation 3 July 28, 2009 01:35
G95 + CGNS Bruno Main CFD Forum 1 January 30, 2007 01:34
