courant number increases to rather large values |
November 8, 2019, 10:55 |
#21 |
Snigdha Ghosh
Rep Power: 6 |
Thanks for your quick reply. I will do the splitting as you said and try to perform the simulation. Can you just explain a bit about why it shall be broken into inlet and outlet condition as I set my liquid in between the gap between two spheres from the beginning. |
November 10, 2019, 10:14 |
#22 |
Snigdha Ghosh
Rep Power: 6 |
Hi Ruben,
As you said I have changed the boundary condition in the faces which are grooved by the spheres as inlet and outlet conditions and other faces of the block I kept as the wall. It ran well. Thanks. If possible, can you tell me what was going wrong with the previous boundary conditions? |
July 5, 2023, 23:48 |
I can run my simulation using Laminar(simple and pimple) but not with kOmegaSST
#23 |
Farzad Faraji
Rep Power: 7 |
Hello everyone
I can run my simulation using Laminar(simpleFoam (steady) and pimpleFoam (transient)) but not with kOmegaSST, and when I want to run(simpleFoam (steady) or pimpleFoam (transient), code blows up due to courant number using pimpleFoam-kOmegaSST(as you see in the picture I have attached). This is a challenging question for me why I can simulate my problem using Laminar model but not with RANS(kOmegaSST) model. Is my mesh quality not good enough for RANS simulation? Laminar-Steady ===> works Laminar-Transient ===> works RANS(kOmegaSST)-Steady ===> code blows up RANS(kOmegaSST)-Transient ===> code blows up Thanks, Farzad |
Foam::error::PrintStack | almir | OpenFOAM Running, Solving & CFD | 92 | May 21, 2024 07:56 |
[mesh manipulation] Mesh Refinement | Luiz Eduardo Bittencourt Sampaio (Sampaio) | OpenFOAM Meshing & Mesh Conversion | 42 | January 8, 2017 12:55 |
Weird AMI Courant Number | Vyssion | OpenFOAM Running, Solving & CFD | 3 | April 13, 2016 02:31 |
Could anybody help me see this error and give help | liugx212 | OpenFOAM Running, Solving & CFD | 3 | January 4, 2006 18:07 |
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues | michele | OpenFOAM Meshing & Mesh Conversion | 2 | July 15, 2005 04:15 |
