March 7, 2017, 06:27 |
PimpleDyMFoam solver problem
JUan Garcia
Rep Power: 9 |
Iam trying to run a simulation using PimpleDyMFoam. It is a porppeller with AMI method. I run the calculation, but when it achieve 0.0125s, it automatically stops, showing the next message: Courant Number mean: 0.00302633 max: 9.72945 deltaT = 3.57143e-05 Time = 0.00125 AMI: Creating addressing and weights between 8127 source faces and 7269 target faces AMI: Patch source sum(weights) min/max/average = 0.51174, 1.52396, 0.999245 AMI: Patch target sum(weights) min/max/average = 0, 1.6436, 0.99057 PIMPLE: iteration 1 smoothSolver: Solving for Ux, Initial residual = 0.000391146, Final residual = 1.12138e-07, No Iterations 1 smoothSolver: Solving for Uy, Initial residual = 0.000303682, Final residual = 1.33307e-08, No Iterations 1 smoothSolver: Solving for Uz, Initial residual = 0.00382204, Final residual = 6.69954e-07, No Iterations 1 #0 Foam::error:rintStack(Foam::Ostream&) at ??:? #1 Foam::sigFpe::sigHandler(int) at ??:? #2 ? in "/lib/x86_64-linux-gnu/libc.so.6" #3 Foam::divide(Foam::Field<double>&, double const&, Foam::UList<double> const&) at ??:? #4 Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > Foam:perator/<Foam::fvPatchField, Foam::volMesh>(Foam::dimensioned<double> const&, Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > const&) at ??:? #5 ? at ??:? #6 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6" #7 ? at ??:? Excepción de coma flotante (`core' generado) Somebody knows what is the problem? Thanks a lot. |
March 7, 2017, 09:38 |
Uwe Pilz
Rep Power: 15 |
Uwe Pilz -- Die der Hauptbewegung überlagerte Schwankungsbewegung ist in ihren Einzelheiten so hoffnungslos kompliziert, daß ihre theoretische Berechnung aussichtslos erscheint. (Hermann Schlichting, 1950) |
March 14, 2017, 04:32 |
#3 | |
Alexandre
Rep Power: 10 |
Check the shape of your AMI cylinder, you should have a perfect round cylinder to use pimpleDyMFoam else it will crash because of some discontinuity between the moving mesh and the non-moving mesh. In a normal case, you should at least have 0.99 or 0.98 for minimum weight when running a pimpleDyMFoam simulation. Here is a link of a ppt about AMI : https://fr.slideshare.net/fumiyanoza...using-openfoam Go directly at slide 84, it will teach you what those numbers mean. |
March 14, 2017, 06:28 |
#4 | |
JUan Garcia
Rep Power: 9 |
Thanks a lot for your help. Definitely. it is the problem. BUt, do you know how can I solve it? |
March 14, 2017, 07:49 |
#5 | |
Alexandre
Rep Power: 10 |
I can guide you to get something better but first :
1) What does your checkMesh indicate ? (send a copy/paste) 2) Did you use the propeller tutorial for your case ? (located in the openfoam files tutorials/incompressible/pimpleDyMFoam/propeller) It gives you a lot of information on how to set AMI. 3) If yes, you might have use something like InnerCylinder and InnerCylinderSmall like in the tutorial. Are you sure about the definition of your InnerCylinderSmall (AMI) ? It might be the problem for this message : Quote:
name InnerCylinderSmall; type cellSet; action new; source cylinderToCell; sourceInfo { p1 (0 0 22.5); p2 (0 0 -2.5); radius 3.5; } 4) What does your AMI patch look like ? It should be a perfectly round cylinder like AMI_1 and AMI_2 attached, and i guess that yours look like AMI_3. |
March 14, 2017, 08:20 |
#6 | |
JUan Garcia
Rep Power: 9 |
March 14, 2017, 14:19 |
JUan Garcia
Rep Power: 9 |
March 14, 2017, 14:24 |
#8 | |
JUan Garcia
Rep Power: 9 |
My checkMesh // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create polyMesh for time = 0 Time = 0 Mesh stats points: 3371504 faces: 9639571 internal faces: 9441899 cells: 3136719 faces per cell: 6.08326 boundary patches: 6 point zones: 0 face zones: 1 cell zones: 1 Overall number of cells of each type: hexahedra: 3018901 prisms: 12794 wedges: 0 pyramids: 0 tet wedges: 286 tetrahedra: 0 polyhedra: 104738 Breakdown of polyhedra by number of faces: faces number of cells 4 1696 5 3125 6 22125 7 414 8 243 9 63244 10 81 11 95 12 11469 13 7 14 18 15 2015 16 1 17 4 18 201 Checking topology... Boundary definition OK. Cell to face addressing OK. Point usage OK. Upper triangular ordering OK. Face vertices OK. *Number of regions: 2 The mesh has multiple regions which are not connected by any face. <<Writing region information to "0/cellToRegion" <<Writing region 0 with 2639593 cells to cellSet region0 <<Writing region 1 with 497126 cells to cellSet region1 Checking patch topology for multiply connected surfaces... Patch Faces Points Surface topology helice 44564 48802 ok (closed singly connected) fuera 9682 9902 ok (non-closed singly connected) AMI1 68725 69107 ok (closed singly connected) AMI2 69326 69574 ok (closed singly connected) inlet 2700 2772 ok (non-closed singly connected) outlet 2675 2753 ok (non-closed singly connected) Checking geometry... Overall domain bounding box (-0.699718 -1.50005 -0.700285) (0.700285 0.700045 0.700282) Mesh has 3 geometric (non-empty/wedge) directions (1 1 1) Mesh has 3 solution (non-empty) directions (1 1 1) Boundary openness (-1.15377e-18 6.741e-16 8.13694e-17) OK. Max cell openness = 3.95941e-16 OK. Max aspect ratio = 27.5449 OK. Minimum face area = 1.97898e-09. Maximum face area = 0.00133388. Face area magnitudes OK. Min volume = 9.17722e-13. Max volume = 2.89277e-05. Total volume = 3.38425. Cell volumes OK. Mesh non-orthogonality Max: 64.9964 average: 5.52116 Non-orthogonality check OK. Face pyramids OK. Max skewness = 3.99985 OK. Coupled point location match (average 0) OK. Mesh OK. End IN the previous message you can see some pictures of the mesh. I still have the same problem: Create time Create mesh for time = 0 Selecting dynamicFvMesh solidBodyMotionFvMesh Selecting solid-body motion function rotatingMotion Applying solid body motion to cellZone rotor PIMPLE: Operating solver in PISO mode Reading field p AMI: Creating addressing and weights between 68725 source faces and 69326 target faces AMI: Patch source sum(weights) min/max/average = 0.734303, 1.83632, 1.0016 AMI: Patch target sum(weights) min/max/average = 0.0681461, 1.17642, 0.999495 Reading field U Reading/calculating face flux field phi Selecting incompressible transport model Newtonian Selecting turbulence model type RAS Selecting RAS turbulence model kOmegaSST Selecting patchDistMethod meshWave kOmegaSSTCoeffs { alphaK1 0.85; alphaK2 1; alphaOmega1 0.5; alphaOmega2 0.856; gamma1 0.555556; gamma2 0.44; beta1 0.075; beta2 0.0828; betaStar 0.09; a1 0.31; b1 1; c1 10; F3 false; } No MRF models present Reading/calculating face velocity Uf No finite volume options present Courant Number mean: 0.0113655 max: 0.922332 forces forces: Not including porosity effects Starting time loop Courant Number mean: 0.0113655 max: 0.922332 deltaT = 0.012 Time = 0.012 AMI: Creating addressing and weights between 68725 source faces and 69326 target faces AMI: Patch source sum(weights) min/max/average = 4.32027e-05, 2.08694, 0.995326 AMI: Patch target sum(weights) min/max/average = 0, 3.0766, 0.989366 PIMPLE: iteration 1 smoothSolver: Solving for Ux, Initial residual = 1, Final residual = 0.399665, No Iterations 6 smoothSolver: Solving for Uy, Initial residual = 1, Final residual = 0.38192, No Iterations 15 smoothSolver: Solving for Uz, Initial residual = 1, Final residual = 0.399895, No Iterations 112 #0 Foam::error:rintStack(Foam::Ostream&) at ??:? #1 Foam::sigFpe::sigHandler(int) at ??:? #2 ? in "/lib/x86_64-linux-gnu/libc.so.6" #3 Foam::divide(Foam::Field<double>&, double const&, Foam::UList<double> const&) at ??:? #4 Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > Foam:perator/<Foam::fvPatchField, Foam::volMesh>(Foam::dimensioned<double> const&, Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > const&) at ??:? #5 ? at ??:? #6 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6" #7 ? at ??:? |
March 14, 2017, 15:23 |
#9 |
Uwe Pilz
Rep Power: 15 |
checkMesh says:
The mesh has multiple regions which are not connected by any face This is: You made several regions and forgot to couple them. This leads to a geometry where the flow cannot move between the blocks. Usual that is be handled by Code:
mergePatchPairs();
March 15, 2017, 05:48 |
#10 | |
Alexandre
Rep Power: 10 |
Well, you still have some AMI weights trouble, so my advices are :
1) You should check your "createAMIFaces.topoSetDict" file, you might have not correctly define your AMI. You should have the same number of faces at the end. Quote:
March 15, 2017, 07:37 |
#11 | |
JUan Garcia
Rep Power: 9 |
March 15, 2017, 07:38 |
#12 |
JUan Garcia
Rep Power: 9 |
The problem in the attachment
September 12, 2017, 10:01 |
#13 |
Maria
Rep Power: 9 |
Hi Rvilum!
I am quite new to OpenFOAM and I aim to simulate a specific wind turbine in a specific wind tunnel for my master thesis. First, I was wondering how you changed the design of the blades in the tutorials/Incompressible/pimpleDyMFoam/propeller case. Did you create a CAD model using another program? What commands do you use to include it? Secondly, do you think it will be hard to make the stator a rectangle instead of a cylinder to simulate the wind tunnel? I am thinking maybe the meshing will be hard? Kind regards, Maria Hoem |
September 14, 2017, 15:50 |
#14 |
JUan Garcia
Rep Power: 9 |
You just have to create another geometry (I used catia), after that, save it as a .stl, and the save it in /constant/trisurface, overwriting the other geometry. Secondly, do you think it will be hard to make the stator a rectangle instead of a cylinder to simulate the wind tunnel? I am thinking maybe the meshing will be hard? No, not at all. Actually, I think it would be easier. It really does not matter (at least not too much), the mesh of the quality in the borders of the volume. But it is better if you mesh it with good quality, of course. |
September 20, 2017, 06:53 |
#15 |
Maria
Rep Power: 9 |
Thank you for your answer, Juan.
I have not yet started to implement the blade desing, because I need to understand how the dynamic mesh works. So I am looking into the mixerVesselAMI2D tutorial. I want to do some of the same changes here - add a channel outside the mixer vessel. But I am having some troubles. If you would be so kind, would you look into my thread and see if you understand what I am doing wrong? Change the mesh in mixerVesselAMI2D tutorial Kind regards, Maria |
October 13, 2017, 08:44 |
Going from propeller to turbine
#16 |
Maria
Rep Power: 9 |
Hey!
I was wondering if anyone knew how to make the propeller tutorial work as a turbine? I want to extract kinetic energy from the flow instead of adding kinetic energy. Kind regards, Maria Last edited by hoemmaria; November 8, 2017 at 06:34. |
openfoam |
[Other] Openfoam for windows 16.02 [CFD support] -problem with paraview | ditmeyer | OpenFOAM Installation | 3 | May 15, 2017 13:04 |
[OpenFOAM.org] Problem in installing OpenFOAM 2.3.0 !!! | omid20110 | OpenFOAM Installation | 6 | August 1, 2016 12:20 |
Cross-compiling OpenFOAM 1.7.0 on Linux for Windows 32 and 64bits with Mingw-w64 | wyldckat | OpenFOAM Announcements from Other Sources | 3 | September 8, 2010 07:25 |
Problem with mpirun with OpenFOAM | jiejie | OpenFOAM | 3 | July 7, 2010 20:30 |
Adventure of fisrst openfoam installation on Ubuntu 710 | jussi | OpenFOAM Installation | 0 | April 24, 2008 15:25 |
