Adam Katz
Rep Power: 9 ![]() |
Hi Foamers!
I am trying to simulate a microfluidics setup we are investigating. The setup is composed of a microscopic channel running a dilute solution of cells of known size. My assumptions are: 1) incompressible 2) laminar 3) one-way coupling I came up with the following solvers: icoUncoupledKinematicParcelFoam (simple)ReactingParcelFoam Could you please explain the difference between the two? is there is another solver which is better? Another question: I solved my flow (without particles) using simpleFoam, can I take the results and use them as data for the lagrangian solver? Thanks, Adam |
Declan
Hi Adam,
icoUncoupledKinematicParcelFoam sounds fine if you just have one type of particle that doesn't react. You can take the results from simpleFoam and use the mapFields utility to use the steady state results as your initial condition in the lagrangian simulation. Hope this helps! Declan |
Adam Katz
Thanks Declan!
mapFields worked. Now I'm stuck with injecting the particles. (I posted a new thread) |
particle tracking, reactingparcelfoam |
Requesting suggestions for appropriate Lagrangian method | suyesh | Main CFD Forum | 0 | July 1, 2016 05:27 |
Solution method | michimichi88 | Fluent Multiphase | 0 | May 13, 2015 11:35 |
Lattice Boltzmann method vs Finite Element Method and Finite Volume Method | solemnpriest | Main CFD Forum | 3 | August 12, 2013 11:00 |
Info on method of lines approach | charlie ryan | Main CFD Forum | 2 | August 9, 2007 11:06 |
tidal flow simulation using finite volume method | Jason Qiu | Main CFD Forum | 0 | October 20, 2002 02:34 |
