Cyclic Non-Convergence in Parallel PimpleDyMFoam |
February 27, 2017, 20:43 |
Collin Strassburger
Rep Power: 9 |
I have run across an issue where a single-core process of PimpleDyMFoam converges at a particular time step, yet the multi-core process has a cyclic non-convergence issue. (In my case the pressure converges until it trips a new iteration of omega, that new omega causes the pressure convergence to start over; this process repeats ad infinitum). I have attempted changing the relaxation factors, the number of correctors, and the pressure relTol. None yielded an improvement. Everything is identical between these two cases except that one is being run in parallel while the other is not. I am running on foam-extend-3.2. Any suggestions for other things to try? |
April 13, 2017, 20:42 |
Collin Strassburger
Rep Power: 9 |
As it turns out, when you use "patch-constrained" decomposition, not all point which contact the constrained patch move uniformly. Periodic points would move at half of the intended rate (those points happened to be those which corresponded to a joining of 3 cells at the surface rather than 2 cells (for an extruded semi-2D case)).
Thus, if anyone comes across this issue in the future, the solution is to not use patch-constrained decomposition in conjunction with mesh motion. |
convergence, foam-extend-3.2, multi processor, pimpledymfoam |
Problem with cyclic boundary conditions in parallel | meng9019 | OpenFOAM Running, Solving & CFD | 3 | February 5, 2019 09:11 |
Cyclic Boundary Condition Errors? | nyflyer | OpenFOAM Running, Solving & CFD | 2 | April 26, 2016 14:14 |
Force can not converge | colopolo | CFX | 13 | October 4, 2011 22:03 |
Problem with cyclic bc when run on parallel | Tek | OpenFOAM | 2 | January 20, 2011 14:40 |
Parallel convergence worse than serial! | Michael B | FLUENT | 3 | December 9, 2006 21:46 |
