Instabilities with too low yplus values?
Old   February 27, 2017, 06:37
Default Instabilities with too low yplus values?
BendikS is on a distinguished road
I'm running a case with the k-omega SST turbulence model without wallfunctions, and are having some trouble with convergence.
From one guide I've read, the yplus values should be below 6. But when I try to fulfill this, I get maximum yplus values around 5-6, and avg. values of around 1, while the minimum values are as low as 0.07.
The problem is that approx. halfway though my simulations the pressure residuals suddenly increase (and stabilizes) at a pretty high level (just below 1.0). I have also tried using a smaller cells, with smaller yplus values, but the same thing happens.
However, if I have a courser mesh, with average yplus values of ~4-5, maximum values of 15, and minimum values of ~0.8, the pressure residual behaves nicely.
I've read somewhere that too small yplus values can cause troubles, and I guess that's what I'm experiencing now ?
Any thoughts?
Cheers
BendikS is offline   Reply With Quote
k-omega sst model, yplus
[Other] Contribution a new utility: refine wall layer mesh based on yPlus field lakeat OpenFOAM Community Contributions 58 December 23, 2021 03:36
OF 4.0 multiregion case calculate yPlus pbnuclex OpenFOAM Post-Processing 6 July 16, 2020 05:27
Too low Cl values Nirmodan FLUENT 0 March 10, 2015 09:39
Numerical errors in nested domain with pre-calculated boundary values Arnoldinho OpenFOAM Running, Solving & CFD 3 April 4, 2012 11:31
Calculating mass flow and Yplus values petrile_83 OpenFOAM Post-Processing 1 December 17, 2011 11:37
