Few cells with high Courant
Old   February 26, 2017, 14:32
Default Few cells with high Courant
Svensen is on a distinguished road
during the computation I've found that one or two cells produces a very high Courant number in comparison with the neighbour cells. It may be 100 or even more times higher.
So the question is: does anybody know what to do with such cells or how this problem can be overcame ?
Thanks
Svensen is offline   Reply With Quote
Old   February 26, 2017, 15:28
piu58's Avatar
Uwe Pilz
piu58 is on a distinguished road
You have the highest Co numbers at regions with a high velocity of the fluid through small cells. If this region is not of special interest for you: Make them larger. If it the area you are interested it: Accept the Co number and its implications.
Uwe Pilz
Die der Hauptbewegung überlagerte Schwankungsbewegung ist in ihren Einzelheiten so hoffnungslos kompliziert, daß ihre theoretische Berechnung aussichtslos erscheint. (Hermann Schlichting, 1950)
piu58 is offline   Reply With Quote
Old   February 26, 2017, 15:41
It is clear.
But the problem is that I have a small cells before/after/around the problematic cells but Courant is the neighbouring cells is much less the in these particular 2-3 cells
Old   February 27, 2017, 01:13
piu58's Avatar
Uwe Pilz
May you post a graphic or at least sketch of your problem / mesh?
Uwe Pilz
cfl, courant number increasing, mesh generation
[snappyHexMesh] SnappyHexMesh running killed! Mark JIN OpenFOAM Meshing & Mesh Conversion 7 June 14, 2022 02:37
Problem with divergence TDK FLUENT 13 December 14, 2018 07:00
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! sc298 OpenFOAM Meshing & Mesh Conversion 2 March 27, 2011 22:11
[snappyHexMesh] snappyHexMesh aborting Tobi OpenFOAM Meshing & Mesh Conversion 0 November 10, 2010 04:23
[snappyHexMesh] external flow with snappyHexMesh chelvistero OpenFOAM Meshing & Mesh Conversion 11 January 15, 2010 20:43
