February 23, 2017, 12:03 |
Grid-induced turbulence using pisoFoam
Xander Walsh
Rep Power: 14 |
Dear All,
I am performing a model-scale LES to replicate wind tunnel results. The simulation uses the Xie-Castro mass-corrected turbulence inlet and has several refinement boxes. The issue is that there seems to be a generation of turbulence when the cell size changes. I have witnessed this before in OpenFOAM in cases where there has been no inlet turbulence. Also note that the mesh was generated using HEXPRESS/hybrid. Can anyone provide some insight or a solution to this problem? Thanks. |
les, mesh, mesh-induced turbulence;, turbulence |
On grid independent solution for pulsatile flow | David | FLUENT | 5 | March 25, 2022 04:33 |
Displaying Turbulence Intensity in LES and creating a constant Turbulence Intensity | Anwer | FLUENT | 1 | August 8, 2016 17:59 |
Dynamic Mesh resulting in Curved Grid Lines | adubois | FLUENT | 3 | April 17, 2014 11:06 |
pisoFoam elbow case with turbulence | inf.vish | OpenFOAM Running, Solving & CFD | 0 | August 19, 2013 06:17 |
MapFields to New Grid For Extreme Grid Deformations due to Body Motion | albcem | OpenFOAM | 0 | May 5, 2009 15:17 |
