February 23, 2017, 11:07 |
Floating point exception using simplefoam
sibo
Rep Power: 10 |
Hi All,
I was using simpleFoam to run an airfoil flow case in parallel, and I run into this error: Code:
mpirun noticed that process rank 3 with PID 76036 on node compute-2-28 exited on signal 8 (Floating point exception). After searching around in the forum, I see some people have similar problems and some people say it might be caused by mesh. So I tried to use a coarse mesh, and the simulation is running well. Therefore, I think this error is caused by my "finer mesh", but I have no idea why finer mesh can cause this problem! Can anybody give me any suggestions about how to rebuilt the finer mesh to solve this problem? Thanks in advance! Sibo |
February 24, 2017, 01:50 |
Uwe Pilz
Rep Power: 15 |
It is a fine idea to observe the Courant number. If this number rises and rises, then your time step is too long.
A fine mesh usually need a shorter time step. That explains the behavior you see.
Uwe Pilz -- Die der Hauptbewegung überlagerte Schwankungsbewegung ist in ihren Einzelheiten so hoffnungslos kompliziert, daß ihre theoretische Berechnung aussichtslos erscheint. (Hermann Schlichting, 1950) |
February 24, 2017, 04:12 |
Agustín Villa
Rep Power: 15 |
if you check the log file, you should see what was going wrong at that point. If you post it we can take a look on it, and try to help. |
February 24, 2017, 11:09 |
sibo
Rep Power: 10 |
Hi Uwe,
Thanks for your kind reply. But I was thinking since simpleFoam is a steady state solver, which means du/dt is 0. So the dt in simpleFoam solver is just something like the number of iterations. There should not be Courant number setting. Correct me if i am wrong. Thanks! |
February 24, 2017, 11:11 |
sibo
Rep Power: 10 |
Hi Agustín,
Thanks for the advice. I adjusted my controlDict to make it output more values. After it's done, I will post it here. Thanks!! |
February 24, 2017, 12:05 |
#6 | |
Agustín Villa
Rep Power: 15 |
Take a look to your boundary conditions. Did you use wall functions? How much resolved is your mesh? Do you know the yPlus fo your mesh? More than the outputs, take a look to the log file, and there you should see the evolution of the residuals and mass continuity. |
February 24, 2017, 12:36 |
sibo
Rep Power: 10 |
HI Agustín,
I used the nutUSpaldingWallFunction in nut file. And the y plus is expected to be 0. This is the log file: Code:
Time = 526 smoothSolver: Solving for Ux, Initial residual = 0.2037803, Final residual = 0.01951528, No Iterations 6 smoothSolver: Solving for Uy, Initial residual = 0.2312924, Final residual = 0.0148174, No Iterations 6 GAMG: Solving for p, Initial residual = 0.9926779, Final residual = 0.09628591, No Iterations 14 time step continuity errors : sum local = 2.523865e+30, global = 2.128306e+14, cumulative = 2.192435e+15 -------------------------------------------------------------------------- mpirun noticed that process rank 3 with PID 19972 on node compute-4-2 exited on signal 8 (Floating point exception). Also, in my postprocessing folder, The forceCoefficient increase greatly. Code:
n# Time Cd Cl Cm 30 1.369018 -3.405345 2.043749 60 -1.856338 -3.3926 -2.006583 90 6.168214 45.1218 1.185081 120 51.43253 252.5338 33.43611 150 205.9458 724.2902 316.1817 180 11340.94 35250 17279.78 210 -10434.01 -34111.99 -17401.88 240 -921074.1 -5595259 1141612 270 1.502871e+07 9.104924e+07 -2.001005e+07 300 -356938.5 -1372324 -382784.5 330 -3105626 -1.76059e+07 3843736 360 1.640823e+07 1.004517e+08 -2.257931e+07 390 -265929.5 1016040 -2509366 420 1243717 1.338678e+07 -6188400 450 1229633 9770905 -1939033 480 1.297626e+10 1.919775e+10 -1.671089e+09 510 2.239133e+38 6.596274e+38 5.292967e+37 |
February 24, 2017, 12:38 |
sibo
Rep Power: 10 |
Sorry my mistake, the y plus are expected to be 1.
floating point exception, simplefoam |
2D NACA0012 O-Mesh GAMG Solver Floating Point Exception | mdeaves | OpenFOAM Running, Solving & CFD | 4 | September 23, 2019 03:51 |
icoFoam floating point exception (8) | leizhao512 | OpenFOAM Running, Solving & CFD | 7 | November 1, 2018 12:43 |
Floating point exception with simpleFoam | andrei.cimpoeru | OpenFOAM Running, Solving & CFD | 5 | January 27, 2016 09:44 |
Floating point exception (core dumped) for GAMG solver | yuhou1989 | OpenFOAM Running, Solving & CFD | 2 | March 24, 2015 20:28 |
simpleFoam Floating point exception error -help | sudhasran | OpenFOAM Running, Solving & CFD | 3 | March 12, 2012 17:23 |
