Can not get correct result in inducer simulation by pimpleDyMFoam
Old   February 19, 2017, 01:58
Default Can not get correct result in inducer simulation by pimpleDyMFoam
TeiGyou
zxzx is on a distinguished road
Hello, everyone
Recently, I am confusing with a problem. Last week, I have spent much time but still could not solve it.
I want to simulate a running of inducer. I have tested it at 6000 rpm and 600 rpm. Even at 6000 rpm, the edge of inducer is just running at 20m/s. But I got a very strange result which above 1000m/s in 0~0.0006s. Pressure is also very strange. I calculated it by head coefficient. The data I got is 100 times than my calculating result. Now, I will show you all the file I tested. I am using the file in pimpleDyMFoam propeller.
FoamFile
version 2.0;
format ascii;
class volScalarField;
location "0";
object p;
dimensions [0 2 -2 0 0 0 0];
internalField uniform 0;
boundaryField
INLET
type zeroGradient;
OUTLET
type fixedValue;
value uniform 0;
INTERFACE_11
type cyclicAMI;
INTERFACE_12
type cyclicAMI;
INTERFACE_21
type cyclicAMI;
INTERFACE_22
type cyclicAMI;
WALL_OUTER_ROTATESIDE
type zeroGradient;
WALL_OUTER_INLETSIDE
type zeroGradient;
WALL_OUTER_OUTLETSIDE
type zeroGradient;
WALL_ROTATE_CORE_FIX
type zeroGradient;
WALL_ROTATE_CORE
type zeroGradient;
FoamFile
version 2.0;
format ascii;
class volVectorField;
location "0";
object U;
dimensions [0 1 -1 0 0 0 0];
internalField uniform (0 0 0);
boundaryField
WALL_ROTATE_CORE
type movingWallVelocity;
value uniform (0 0 0);
INLET
type pressureInletVelocity;
OUTLET
type inletOutlet;
inletValue uniform (0 0 0);
type noSlip;
type noSlip;
type noSlip;
type noSlip;
INTERFACE_11
type cyclicAMI;
INTERFACE_12
type cyclicAMI;
INTERFACE_21
type cyclicAMI;
INTERFACE_22
type cyclicAMI;
FoamFile
version 2.0;
format ascii;
class dictionary;
location "system";
object controlDict;
application pimpleDyMFoam;
startFrom startTime;
startTime 0;
stopAt endTime;
endTime 1;
deltaT 0.00001;
writeControl adjustableRunTime;
writeInterval 0.0001;
////- For testing with moveDynamicMesh
///deltaT 1e-5;
//writeControl timeStep;
//writeInterval 1;
purgeWrite 0;
writeFormat ascii;
writePrecision 6;
writeCompression on;
timeFormat general;
timePrecision 6;
runTimeModifiable true;
adjustTimeStep yes;
maxCo 1;
functions
FoamFile
version 2.0;
format ascii;
class dictionary;
location "constant";
object dynamicMeshDict;
dynamicFvMesh solidBodyMotionFvMesh;
motionSolverLibs ( "libfvMotionSolvers.so" );
solidBodyMotionFvMeshCoeffs
cellZone FLUID_ROTATE_CORE_TRI;
solidBodyMotionFunction rotatingMotion;
rotatingMotionCoeffs
origin (0 0 0);
axis (0 1 0);
omega 628; // rad/s
FoamFile
version 2.0;
format ascii;
class dictionary;
object fvSolution;
solvers
pcorr
solver GAMG;
tolerance 1e-2;
relTol 0;
smoother DICGaussSeidel;
cacheAgglomeration no;
maxIter 50;
p
$pcorr;
tolerance 1e-5;
relTol 0.01;
pFinal
$p;
tolerance 1e-6;
relTol 0;
"(U|k|epsilon)"
solver smoothSolver;
smoother symGaussSeidel;
tolerance 1e-6;
relTol 0.1;
"(U|k|epsilon)Final"
tolerance 1e-6;
relTol 0;
PIMPLE
correctPhi no;
nOuterCorrectors 3;
nCorrectors 2;
nNonOrthogonalCorrectors 1;
relaxationFactors
"(U|k|epsilon).*" 1;
cache
grad(U);
In order to decrease the simulation time, I was using laminar model to test it. Could you anyone tell what is wrong with my case? Thank you very much.
ZX
zxzx is offline   Reply With Quote
Old   February 19, 2017, 03:43
TeiGyou
I show you pics to let you know my uncorrect answer easily
File Type: png Screenshot from 2017-02-20 18-41-40.png (168.1 KB, 12 views)
File Type: png Screenshot from 2017-02-20 18-40-59.png (158.6 KB, 12 views)
PimpleDymFOAM simulation problem of Savonius rotor Sunzida OpenFOAM Running, Solving & CFD 0 March 14, 2016 02:45
Confusion abt expt / non-dim simulation result comparison quarkz Main CFD Forum 8 November 1, 2015 09:03
Simulation Problem Where Suddenly Finished With No Result Produced PeiSan Fidelity CFD 4 August 21, 2014 08:06
how to make sure the simulation result is correct? sham81 CFX 3 March 22, 2004 17:41
Result is not correct Li FLUENT 1 December 30, 2000 01:21
