How to use PIMPLE properly?
Like Tree17Likes
Old   February 14, 2017, 10:16
Default How to use PIMPLE properly?
floquation's Avatar
Kevin van As
floquation will become famous soon enough
Background:
I am simulating a rising bubble in OF41 with the interFoam solver.
To do so, I am currently using a uniform mesh with cubic cells (aspect ratio 1).
There are a total of 90x90x180 cells, which corresponds to 15 cells / bubble diameter. (This is relatively coarse, but should be fine enough to test the below.)
This case converges pretty well using only one outer (SIMPLE) iteration and just three inner (PISO) iterations with maxCo=0.5.
I decided to check whether using the PIMPLE algorithm - following Tobi's guide - might speed up my simulation.
Problem (I mean, challenge):
The PIMPLE algorithm slows down my simulation considerably, which is because the solution does not (barely) improve with successive outer iterations.
maxCo is only 2. (Which means that each timestep must at most take a factor four longer to be faster than the maxCo=0.5 simulation.)
Log file (snippet):
Courant Number mean: 0.000976416 max: 1.44982
Interface Courant Number mean: 0.000135741 max: 1.05712
deltaT = 7.14286e-05
Time = 0.0035
PIMPLE: iteration 1
smoothSolver:  Solving for alpha.water, Initial residual = 0.00797562, Final residual = 6.12225e-08, No Iterations 3
Phase-1 volume fraction = 0.998807  Min(alpha.water) = 2.79909e-07  Max(alpha.water) = 1.0002
MULES: Correcting alpha.water
Phase-1 volume fraction = 0.998807  Min(alpha.water) = -0.000994  Max(alpha.water) = 1.0002
GAMG:  Solving for p_rgh, Initial residual = 0.135337, Final residual = 0.000314987, No Iterations 2
time step continuity errors : sum local = 5.46316e-07, global = 1.47295e-10, cumulative = -2.1714e-07
GAMG:  Solving for p_rgh, Initial residual = 0.0940134, Final residual = 0.000266503, No Iterations 2
time step continuity errors : sum local = 4.6467e-07, global = -6.43504e-10, cumulative = -2.17783e-07
GAMG:  Solving for p_rgh, Initial residual = 0.0941178, Final residual = 0.00025847, No Iterations 2
time step continuity errors : sum local = 4.50745e-07, global = -8.69603e-10, cumulative = -2.18653e-07
PIMPLE: iteration 2
smoothSolver:  Solving for alpha.water, Initial residual = 0.00645469, Final residual = 1.00334e-09, No Iterations 3
Phase-1 volume fraction = 0.998807  Min(alpha.water) = 2.06368e-07  Max(alpha.water) = 1.00028
Phase-1 volume fraction = 0.998807  Min(alpha.water) = -0.00122852  Max(alpha.water) = 1.00028
GAMG:  Solving for p_rgh, Initial residual = 0.086505, Final residual = 0.000338267, No Iterations 2
time step continuity errors : sum local = 7.40111e-07, global = -3.00883e-10, cumulative = -2.18954e-07
GAMG:  Solving for p_rgh, Initial residual = 0.0606414, Final residual = 0.000265495, No Iterations 2
time step continuity errors : sum local = 5.8013e-07, global = -7.78486e-10, cumulative = -2.19732e-07
GAMG:  Solving for p_rgh, Initial residual = 0.0606601, Final residual = 0.000258879, No Iterations 2
time step continuity errors : sum local = 5.65676e-07, global = -8.99989e-10, cumulative = -2.20632e-07
PIMPLE: iteration 3
smoothSolver:  Solving for alpha.water, Initial residual = 0.00582153, Final residual = 2.94448e-09, No Iterations 3
Phase-1 volume fraction = 0.998807  Min(alpha.water) = 2.78524e-07  Max(alpha.water) = 1.00023
Phase-1 volume fraction = 0.998807  Min(alpha.water) = -0.00139389  Max(alpha.water) = 1.00023
GAMG:  Solving for p_rgh, Initial residual = 0.080493, Final residual = 0.000340901, No Iterations 2
time step continuity errors : sum local = 6.77737e-07, global = -1.80287e-10, cumulative = -2.20813e-07
GAMG:  Solving for p_rgh, Initial residual = 0.0560016, Final residual = 0.000246158, No Iterations 2
time step continuity errors : sum local = 4.90191e-07, global = -1.04078e-09, cumulative = -2.21853e-07
GAMG:  Solving for p_rgh, Initial residual = 0.0560882, Final residual = 0.000241618, No Iterations 2
time step continuity errors : sum local = 4.81123e-07, global = -1.22133e-09, cumulative = -2.23075e-07
PIMPLE: iteration 4
smoothSolver:  Solving for alpha.water, Initial residual = 0.00559932, Final residual = 9.83465e-10, No Iterations 3
Phase-1 volume fraction = 0.998807  Min(alpha.water) = 2.60849e-07  Max(alpha.water) = 1.0002
Phase-1 volume fraction = 0.998807  Min(alpha.water) = -0.000778589  Max(alpha.water) = 1.0002
GAMG:  Solving for p_rgh, Initial residual = 0.0612285, Final residual = 0.000199755, No Iterations 2
time step continuity errors : sum local = 4.25689e-07, global = -2.24356e-09, cumulative = -2.25318e-07
GAMG:  Solving for p_rgh, Initial residual = 0.0427183, Final residual = 0.000117493, No Iterations 2
time step continuity errors : sum local = 2.50063e-07, global = -4.87422e-09, cumulative = -2.30193e-07
GAMG:  Solving for p_rgh, Initial residual = 0.0427806, Final residual = 0.000118101, No Iterations 2
time step continuity errors : sum local = 2.51322e-07, global = -4.84618e-09, cumulative = -2.35039e-07
PIMPLE: iteration 198
smoothSolver:  Solving for alpha.water, Initial residual = 0.00473282, Final residual = 8.68777e-10, No Iterations 3
Phase-1 volume fraction = 0.998807  Min(alpha.water) = 1.54224e-07  Max(alpha.water) = 1.0002
Phase-1 volume fraction = 0.998807  Min(alpha.water) = -0.000778275  Max(alpha.water) = 1.0002
GAMG:  Solving for p_rgh, Initial residual = 0.0242179, Final residual = 1.44059e-05, No Iterations 2
time step continuity errors : sum local = 3.02184e-08, global = -2.22393e-10, cumulative = -1.3677e-07
GAMG:  Solving for p_rgh, Initial residual = 0.0168498, Final residual = 1.09407e-05, No Iterations 2
time step continuity errors : sum local = 2.29456e-08, global = -2.17156e-10, cumulative = -1.36987e-07
GAMG:  Solving for p_rgh, Initial residual = 0.0168702, Final residual = 1.08204e-05, No Iterations 2
time step continuity errors : sum local = 2.26937e-08, global = -2.14002e-10, cumulative = -1.37201e-07
PIMPLE: iteration 199
smoothSolver:  Solving for alpha.water, Initial residual = 0.00473242, Final residual = 1.01542e-09, No Iterations 3
Phase-1 volume fraction = 0.998807  Min(alpha.water) = 1.50747e-07  Max(alpha.water) = 1.0002
Phase-1 volume fraction = 0.998807  Min(alpha.water) = -0.00100276  Max(alpha.water) = 1.0002
GAMG:  Solving for p_rgh, Initial residual = 0.0231552, Final residual = 1.27849e-05, No Iterations 2
time step continuity errors : sum local = 2.60952e-08, global = 7.02594e-11, cumulative = -1.37131e-07
GAMG:  Solving for p_rgh, Initial residual = 0.0160877, Final residual = 9.21079e-06, No Iterations 2
time step continuity errors : sum local = 1.8809e-08, global = 7.69685e-11, cumulative = -1.37054e-07
GAMG:  Solving for p_rgh, Initial residual = 0.0161063, Final residual = 9.18537e-06, No Iterations 2
time step continuity errors : sum local = 1.87572e-08, global = 7.68037e-11, cumulative = -1.36977e-07
PIMPLE: iteration 200
smoothSolver:  Solving for alpha.water, Initial residual = 0.00473295, Final residual = 8.68842e-10, No Iterations 3
Phase-1 volume fraction = 0.998807  Min(alpha.water) = 1.54225e-07  Max(alpha.water) = 1.0002
Phase-1 volume fraction = 0.998807  Min(alpha.water) = -0.0007774  Max(alpha.water) = 1.0002
GAMG:  Solving for p_rgh, Initial residual = 0.0384742, Final residual = 4.37332e-05, No Iterations 2
time step continuity errors : sum local = 3.03523e-07, global = 2.45412e-10, cumulative = -1.36732e-07
GAMG:  Solving for p_rgh, Initial residual = 0.00193055, Final residual = 7.99627e-06, No Iterations 2
time step continuity errors : sum local = 5.51445e-08, global = 6.02003e-10, cumulative = -1.3613e-07
GAMG:  Solving for p_rgh, Initial residual = 0.000402165, Final residual = 6.91129e-09, No Iterations 19
time step continuity errors : sum local = 4.76783e-11, global = 1.11926e-11, cumulative = -1.36119e-07
PIMPLE: not converged within 200 iterations
Notable is that (1) alpha is out of its allowed bounds [0,1], which did not happen without PIMPLE,
and (2) the solution does not (or barely) improve with successive outer iterations. Then, remarkably, in the very last iteration convergence is great! This is presumably because under-relaxation is disabled. This is something I have seen several times before, but I have never understood.
The relevant files are listed below.
I should add that changing relTol for p_rgh from 1e-02 to 1e-03 yields a slightly better result, which still is not close to converging after 200 outer iterations.
Reducing the under-relaxation factors from 0.3 to 0.1 is yet much better, allowing PIMPLE to converge in 130 iterations, which ... is still an awful lot of iterations. Furthermore, over time it increased to 180 iterations.
Further reducing the under-relaxation factor from 0.1 to 0.01 yields a better residual (~5e-3) after 200 iterations, but PIMPLE still did not converge.
Question:
But then, how can PIMPLE ever yield a better(=faster) result than having only one outer iteration...?
In other words, what am I doing incorrectly?
Relevant Files:
controlDict:
|  \\    /   O peration     | Version:  4.0                                   |
|   \\  /    A nd           | Web:      www.OpenFOAM.org                      |
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    location    "system";
    object      controlDict;
application     interFoam;
startFrom       startTime;
startTime       0;
stopAt          endTime;
endTime         0.070;
deltaT          1e-6;
writeControl    adjustableRunTime;
writeInterval   5e-4;
purgeWrite      0;
writeFormat     ascii;
writePrecision  6;
writeCompression uncompressed;
timeFormat      general;
timePrecision   6;
runTimeModifiable yes;
adjustTimeStep  yes;
maxCo           2;
maxAlphaCo      2;
maxDeltaT       1;
libs
        "libsimpleFunctionObjects.so"
        "libsimpleSwakFunctionObjects.so"
        "libswakLagrangianParser.so"
        "libswakFunctionObjects.so"
        "libsimpleLagrangianFunctionObjects.so"
functions
    #include "bubPositionDict" //Monitors the position of the bubble over time
fvSolution:
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    location    "system";
    object      fvSolution;
solvers
    "alpha.water.*"
        nAlphaCorr      2;
        nAlphaSubCycles 1;
        cAlpha          1;
        MULESCorr       yes;
        nLimiterIter    2;
        solver          smoothSolver;
        smoother        symGaussSeidel;
        tolerance       1e-07;
        relTol          0;
    p_rgh
        solver          GAMG;
        tolerance       1e-08;
        relTol          1e-02;
        smoother        DIC;
        //nPreSweeps      0;
        //nPostSweeps     2;
        //nFinestSweeps   2;
        cacheAgglomeration no;
        //nCellsInCoarsestLevel 10;
        //agglomerator    faceAreaPair;
        //mergeLevels     1;
    p_rghFinal
        $p_rgh;
        relTol          0;
    "pcorr.*"
        $p_rghFinal;
        tolerance       1e-04;
    U
        smoother        GaussSeidel;
        tolerance       1e-07; // Doesn't do anything with momentumPredictor=no
        relTol          1e-03; // Doesn't do anything with momentumPredictor=no
        nSweeps         1;
    UFinal
        $U;
        relTol          0;
    "(k|B|nuTilda)"
        tolerance       1e-08;
        relTol          0;
PIMPLE
    momentumPredictor no;
    nOuterCorrectors 200;
    nCorrectors     3;
    nNonOrthogonalCorrectors 0;
    pRefPoint      (0 0 0);
    pRefValue      0;
    residualControl
        U
                tolerance  1e-06;
                relTol     0;
        p_rgh
                tolerance  1e-07;
                relTol     0;
relaxationFactors {
   fields
       p_rgh        0.3;
       p_rghFinal   1;
   equations
       "alpha.*|U|k|epsilon"            0.3;
       "(alpha.*|U|k|epsilon)Final"     1;
fvSchemes:
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    location    "system";
    object      fvSchemes;
ddtSchemes
    default         Euler;
gradSchemes
    default         Gauss linear;
divSchemes
    div(rhoPhi,U)   Gauss upwind;
    div(phi,alpha)  Gauss vanLeer;
    div(phirb,alpha) Gauss linear;
//    div((muEff*dev(T(grad(U))))) Gauss linear;
    div(((rho*nuEff)*dev2(T(grad(U))))) Gauss linear;
laplacianSchemes
    default         Gauss linear corrected;
interpolationSchemes
    default         linear;
snGradSchemes
    default         corrected;
wallDist
    method meshWave;
Thanks in advance.
krikre, Ramzy1990, saidc. and 3 others like this.
floquation is offline   Reply With Quote
Old   February 14, 2017, 12:11
Alexey Matveichev
alexeym has a spectacular aura aboutalexeym has a spectacular aura about
Send a message via Skype™ to alexeym
Couple of questions:
1. Do you really need this tight convergence criterion? I.e. 1e-7 is surely nice, yet, not quite sure your will find MUCH difference with 1e-4.
2. Using under-relaxation allows you to get "faster" convergence but on final iteration there will be no relaxation and your initial residual become much larger, than your convergence criterion. You can also use under-relaxation factor 0, so you always be using old converged field and number of iterations will be dramatically reduced.
3. Finally
Are you sure your BCs are correct?
alexeym is offline   Reply With Quote
Old   February 14, 2017, 13:16
piu58's Avatar
Uwe Pilz
piu58 is on a distinguished road
Dear Kevin,
the number of outer correctors and therewith the calculation time should be controled with the residuals. Please try first to let nOuterCorrectors to a high value and limit it by let's say
    residualControl
        U
                tolerance  1e-03;
                relTol     0;
        p_rgh
                tolerance  1e-03;
                relTol     0;
If that doesn't give a much higher calculation speed, then you forgot one of the variables in the residual control which pimple uses. Look at the screen logging for that.
Bashar likes this.
Uwe Pilz
Die der Hauptbewegung überlagerte Schwankungsbewegung ist in ihren Einzelheiten so hoffnungslos kompliziert, daß ihre theoretische Berechnung aussichtslos erscheint. (Hermann Schlichting, 1950)
piu58 is offline   Reply With Quote
Old   February 15, 2017, 05:04
floquation's Avatar
Kevin van As
Thank you for your replies.
I don't know whether I need 1e-7: it is a number that I based on, well, nothing.
I'll compare with 1e-4.
I understand that under-relaxation might result in faster convergence by preventing the solution from "over-shooting", i.e. essentially by smoothing the descend to the correct solution.
I understand that using a value 0 implies using the old converged fields. I reckon it will result in small residuals simply because the solution is not changing.
However, I don't see how this can be a good thing? I reckon it will result in the first N-1 outer iterations doing nothing, and the final iteration (without under-relaxation) doing all the work == PISO.
3. (...) Are you sure your BCs are correct?
I'm quite sure, yes. The \alpha field is behaving appropriately when I used only one outer iteration (i.e. PISO).
Furthermore, using settings for which the PIMPLE loop does converge, \alpha remains inside its [0,1] bounds.
Just for reference, the BCs are:
\alpha:
Bottom/Side (wall): zeroGradient
Top (atmosphere): inletOutlet; value 1 = air;
\vec{u}:
Bottom/Side (wall): zero velocity (uniformFixedValue (0 0 0))
Top (atmosphere): pressureInletOutletVelocity
p_{rgh}:
Bottom/Side (wall): zero gradient (fixedFluxPressure 0)
Top (atmosphere): totalPressure
I was already doing that, although with a value of 1e-7.
The problem in the above log-file was that after 200 iterations the solution did not drop below 1e-2 yet, meaning setting it to 1e-3 wouldn't change anything either.
Or do you mean setting it to yet much higher than 200, hoping that in later timesteps the solution does converge much faster?
By chance, a simulation of last night did converge in 100 iterations (to 1e-7) [it reached 1e-4 after about 35 iterations]. The only difference with the simulation of above log-file is that I reduced under-relaxation of p_rgh from 0.3 to 0.1.
Therefore, I'm inclined to conclude that the value 0.3 was highly unfortunate, causing the solution to basically overshoot the solution harmonically, resulting in no convergence.
I'll play around with a weaker convergence criterion and lower under-relaxation factors.
Old   February 20, 2017, 07:58
Ricky
kera is on a distinguished road
Hello FOAMers,
I am also trying to do the same. In my case I have added TEqn (with extra source terms) in interFoam. All I wanted to do at first was to use Pimple loop with max Co. 3 (with adjustable time steps), however the solver crashes (especially alpha) and when I run the case with lower time steps (and by not using adjustable time steps) the solver runs fine and pimple loop converges with few iterations.
Boundary Conditions:
\alpha
FoamFile
    version     2.0;
    format      ascii;
    class       volScalarField;
    location    "0";
    object      alpha.metal;
dimensions      [0 0 0 0 0 0 0];
internalField   uniform 0;
boundaryField
    upperWall
        type            zeroGradient;
    leftWall
         type           constantAlphaContactAngle;
        theta0         90;
        limit          gradient;
        value          uniform 0;
    rightWall
        theta0         90;
        limit          gradient;
        value          uniform 0;
    lowerWall
        type            zeroGradient;
    frontAndBack
        type            empty;
fvSchemes
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    location    "system";
    object      fvSchemes;
ddtSchemes
    default         Euler;
gradSchemes
divSchemes
    default       Gauss upwind;
    div(rhoPhi,U)  Gauss limitedLinearV 1;
    div(phi,thermo:rho.metal) Gauss upwind;
    div(phi,thermo:rho.air) Gauss upwind;
    div(rhoPhi,T)  Gauss limitedLinear01 1;
    div(rhoPhi,K)  Gauss upwind;
    div(phi,p)      Gauss upwind;
    div(phi,k)      Gauss upwind;
laplacianSchemes
    default         Gauss linear uncorrected;
    default         linear;
snGradSchemes
    default         uncorrected;
fluxRequired
    default         no;
    p_rgh;
    pcorr;
fvSolution
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    location    "system";
    object      fvSolution;
solvers
    alpha.metal
        nAlphaCorr      1;
        nAlphaSubCycles 1;
        cAlpha          1;
    ".*(rho|rhoFinal)"
        solver          diagonal;
    pcorr
        solver          PCG;
        preconditioner
            preconditioner  GAMG;
            tolerance       1e-05;
            relTol          0;
            smoother        DICGaussSeidel;
            nPreSweeps      0;
            nPostSweeps     2;
            nFinestSweeps   2;
            cacheAgglomeration true;
            mergeLevels     1;
        tolerance       1e-05;
        relTol          0;
        maxIter         100;
    p_rgh
        solver          GAMG;
        tolerance       1e-07;
        relTol          0.01;
        smoother        DIC;
        nPreSweeps      0;
        nPostSweeps     2;
        nFinestSweeps   2;
        mergeLevels     1;
    p_rghFinal
        solver          PCG;
        preconditioner
            tolerance       1e-07;
            relTol          0;
            nVcycles        2;
            nPreSweeps      2;
            nPostSweeps     2;
            nFinestSweeps   2;
            mergeLevels     1;
        tolerance       1e-07;
        relTol          0;
        maxIter         20;
 "(U|T).*"
        solver          PBiCG;
        preconditioner  DILU;
        tolerance       1e-6;
        relTol          0.1;
 U
        tolerance       1e-06;
        relTol          0;
        nSweeps         1;
    "(T|k|B|nuTilda).*"
        tolerance       1e-7;
        relTol          0;
PIMPLE
    transonic       no;
    nOuterCorrectors 15;
    nCorrectors     2;
    pRefCell 0;
    pRefValue 0.0;
    residualControl
        U
            tolerance 1e-5;
            relTol 0;
        T
            tolerance 1e-5;
            relTol 0;
        p_rgh
            tolerance 1e-3;
            relTol 0;
relaxationFactors
    fields
        p_rgh               0.3;
        p_rghFinal            1;
    equations
       U                         0.7;
       T                         0.7;
       "alpha.*"               0.7;
       "(U|T|alpha.*)Final"            1;
this is the error what I get, when I allow adjustable time step.
Create time
Create mesh for time = 0
PIMPLE: max iterations = 15
    field U	: relTol 0, tolerance 1e-05
    field T	: relTol 0, tolerance 1e-05
    field p_rgh	: relTol 0, tolerance 0.001
Reading field p_rgh
Reading field U
Reading transportProperties
Selecting incompressible transport model Newtonian
Reading marangoniTerms
Selecting turbulence model type laminar
Reading g
Calculating field g.h
No finite volume options present
time step continuity errors : sum local = 0, global = 0, cumulative = 0
GAMGPCG:  Solving for pcorr, Initial residual = 0, Final residual = 0, No Iterations 0
Courant Number mean: 0 max: 0
Starting time loop
Interface Courant Number mean: 0 max: 0
deltaT = 0.00011999
Time = 0.00011999
PIMPLE: iteration 1
MULES: Solving for alpha.metal
Phase-1 volume fraction = 0.806452  Min(alpha1) = 0  Max(alpha1) = 1
DILUPBiCG:  Solving for T, Initial residual =  1.52944e-05, Final residual = 2.09562e-05, No Iterations 5
gammaSolve CONVERGED in 5 Iterations
GAMG:  Solving for p_rgh, Initial residual = 0.999992, Final residual = 0.000911696, No Iterations 1
time step continuity errors : sum local = 0.18636, global = 1.9992e-16, cumulative = 1.9992e-16
GAMG:  Solving for p_rgh, Initial residual = 0.988129, Final residual = 0.00692632, No Iterations 5
time step continuity errors : sum local = 0.00188921, global = 1.24894e-19, cumulative = 2.00045e-16
PIMPLE: iteration 2
Phase-1 volume fraction = 0.806452  Min(alpha1) = 0  Max(alpha1) = 1.27482
DILUPBiCG:  Solving for T, Initial residual =  0.15788, Final residual = 1.9161e-08, No Iterations 34
gammaSolve CONVERGED in 34 Iterations
GAMG:  Solving for p_rgh, Initial residual = 0.929794, Final residual = 0.00366765, No Iterations 4
time step continuity errors : sum local = 0.000312566, global = -1.61339e-19, cumulative = 1.99884e-16
GAMG:  Solving for p_rgh, Initial residual = 0.252356, Final residual = 0.00113828, No Iterations 4
time step continuity errors : sum local = 9.30599e-06, global = -3.37308e-21, cumulative = 1.9988e-16
PIMPLE: iteration 3
PIMPLE: iteration 15
Phase-1 volume fraction = 0.806452  Min(alpha1) = -0.000200768  Max(alpha1) = 1.00016
DILUPBiCG:  Solving for T, Initial residual =  0.00123988, Final residual = 8.26378e-10, No Iterations 9
gammaSolve CONVERGED in 7 Iterations
GAMG:  Solving for p_rgh, Initial residual = 0.9994, Final residual = 0.0015772, No Iterations 1
time step continuity errors : sum local = 8.64201e-06, global = -3.84479e-22, cumulative = 1.99884e-16
GAMGPCG:  Solving for p_rgh, Initial residual = 0.00329089, Final residual = 1.93664e-08, No Iterations 5
time step continuity errors : sum local = 1.1703e-10, global = -9.98082e-23, cumulative = 1.99884e-16
PIMPLE: not converged within 15 iterations
ExecutionTime = 0.76 s  ClockTime = 1 s
Courant Number mean: 8.62149e-05 max: 0.019126
Interface Courant Number mean: 4.02458e-06 max: 0.019126
deltaT = 0.000143971
Time = 0.000263962
PIMPLE: iteration 1
Phase-1 volume fraction = 0.806452  Min(alpha1) = -2.26313e-06  Max(alpha1) = 1
DILUPBiCG:  Solving for T, Initial residual =  0.00384329, Final residual = 1.12649e-05, No Iterations 8
gammaSolve CONVERGED in 6 Iterations
GAMG:  Solving for p_rgh, Initial residual = 0.996876, Final residual = 0.00150053, No Iterations 1
time step continuity errors : sum local = 3.7005e-06, global = -1.47312e-22, cumulative = 1.99884e-16
GAMG:  Solving for p_rgh, Initial residual = 0.00505313, Final residual = 4.2576e-05, No Iterations 4
time step continuity errors : sum local = 7.26956e-08, global = -1.37257e-22, cumulative = 1.99884e-16
PIMPLE: iteration 2
Phase-1 volume fraction = 0.806452  Min(alpha1) = -4.47203e-05  Max(alpha1) = 1.00002
DILUPBiCG:  Solving for T, Initial residual =  0.000983497, Final residual = 6.52094e-07, No Iterations 4
gammaSolve CONVERGED in 4 Iterations
GAMG:  Solving for p_rgh, Initial residual = 0.995449, Final residual = 0.00143503, No Iterations 1
time step continuity errors : sum local = 6.01372e-06, global = 1.44792e-21, cumulative = 1.99886e-16
GAMG:  Solving for p_rgh, Initial residual = 0.00266226, Final residual = 9.27126e-06, No Iterations 5
time step continuity errors : sum local = 5.09921e-08, global = 7.36318e-22, cumulative = 1.99886e-16
PIMPLE: iteration 3
Phase-1 volume fraction = 0.806452  Min(alpha1) = -1.09703e-06  Max(alpha1) = 1
DILUPBiCG:  Solving for T, Initial residual =  0.00163286, Final residual = 9.46957e-07, No Iterations 10
GAMG:  Solving for p_rgh, Initial residual = 0.994572, Final residual = 0.00119417, No Iterations 1
time step continuity errors : sum local = 4.42903e-06, global = -1.74449e-23, cumulative = 1.99886e-16
GAMG:  Solving for p_rgh, Initial residual = 0.00406946, Final residual = 3.92242e-05, No Iterations 3
time step continuity errors : sum local = 1.86995e-07, global = 3.13402e-22, cumulative = 1.99887e-16
PIMPLE: iteration 4
Phase-1 volume fraction = 0.806452  Min(alpha1) = -0.000587911  Max(alpha1) = 1.00047
DILUPBiCG:  Solving for T, Initial residual =  0.00277735, Final residual = 1.20527e-06, No Iterations 9
GAMG:  Solving for p_rgh, Initial residual = 0.999226, Final residual = 0.00163561, No Iterations 1
time step continuity errors : sum local = 2.22823e-05, global = 4.45425e-21, cumulative = 1.99891e-16
GAMG:  Solving for p_rgh, Initial residual = 0.00309879, Final residual = 1.62382e-05, No Iterations 5
time step continuity errors : sum local = 2.81532e-07, global = 1.87072e-21, cumulative = 1.99893e-16
PIMPLE: iteration 12
Phase-1 volume fraction = 0.806452  Min(alpha1) = -0.120187  Max(alpha1) = 1.03931
DILUPBiCG:  Solving for T, Initial residual =  0.0530859, Final residual = 2.93419e-07, No Iterations 15
gammaSolve CONVERGED in 15 Iterations
#0  Foam::error::printStack(Foam::Ostream&) at ??:?
#1  Foam::sigFpe::sigHandler(int) at ??:?
#2   in "/lib/x86_64-linux-gnu/libc.so.6"
#3  double Foam::sumProd<double>(Foam::UList<double> const&, Foam::UList<double> const&) at ??:?
#4  Foam::PCG::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const at ??:?
#5  Foam::GAMGSolver::solveCoarsestLevel(Foam::Field<double>&, Foam::Field<double> const&) const at ??:?
#6  Foam::GAMGSolver::Vcycle(Foam::PtrList<Foam::lduMatrix::smoother> const&, Foam::Field<double>&, Foam::Field<double> const&, Foam::Field<double>&, Foam::Field<double>&, Foam::Field<double>&, Foam::Field<double>&, Foam::Field<double>&, Foam::PtrList<Foam::Field<double> >&, Foam::PtrList<Foam::Field<double> >&, unsigned char) const at ??:?
#7  Foam::GAMGSolver::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const at ??:?
#8  Foam::fvMatrix<double>::solveSegregated(Foam::dictionary const&) at ??:?
#9  Foam::fvMatrix<double>::solve(Foam::dictionary const&) at ??:?
 at ??:?
#11  __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6"
#12
 at ??:?
Floating point exception (core dumped)
Would really appreciate your help.
Thanks in advance.
Regards,
Ricky
If it is easy, then something is fishy!
kera is offline   Reply With Quote
Old   February 20, 2017, 08:34
floquation's Avatar
Kevin van As
Euh? You are using a bigger maxCo than me (= more unstable), but far less iterations. I was using 200 PIMPLE loops, and even then it wouldn't converge. So obviously it is not going to converge for you.
For instance, your initial residual for p_rgh is 0.999 in your final iteration... If it were any higher, the simulation would blow up instantly, therefore it blows up in due time.
Old   February 20, 2017, 09:11
Ricky
thanks for your reply!
yeah I know the example I shared with you guys was the extreme condition of the case I was trying. I initially started without adjustable time steps and using very small delta_T. I observed that it didn't required too many PIMPLE loops as PIMPLE converges within 10 iterations. so I maxed my PIMPLE Iteration value to 15.
Then I started playing around with Co. and max Co. 3 was the extreme I was using. However the solver crashes even setting Co. to 1 (i.e., with adjustable time steps). Later I tried to just increase the time step from 1e-5 to 5e-5 (without adjustable) it still crashed. It seem that for some reason the solver responds well only to time step 1e-5 or lower.
So I was wondering, what I was doing wrong and hence shared my simulation settings here,so that maybe someone with experience may figure out the silly things/mistakes I might be probably doing, as I am kinda new to OpenFOAM.
Thanks in advance.
Regards,
Ricky
Thamali likes this.
Old   February 22, 2017, 13:05
floquation's Avatar
Kevin van As
Regarding my matter, I have played around some more.
residualControl 1e-4:
As was to be expected, using a lower convergence criterion may result in the PIMPLE loop to be truncated.
For instance, using 2x200 iterations (inner x outer), it would truncate after 40-60 PIMPLE loops; using 3x200 iterations, it would truncate after 15 PIMPLE loops. Both cases use 1e-4 for both velocity and pressure, with a relTol of 1e-2.
However, sometimes the loop would randomly not converge, and use the maximum of 200 iterations. For example:
Courant Number mean: 5.78162e-06 max: 0.0502205
Interface Courant Number mean: 1.85919e-06 max: 0.0278548
deltaT = 3.53748e-06
Time = 1.53653e-05
PIMPLE: iteration 1
smoothSolver:  Solving for alpha.water, Initial residual = 0.000138561, Final residual = 2.42003e-08, No Iterations 1
Phase-1 volume fraction = 0.998807  Min(alpha.water) = -3.99334e-05  Max(alpha.water) = 1.0022
GAMG:  Solving for p_rgh, Initial residual = 0.00997852, Final residual = 7.87455e-05, No Iterations 1
time step continuity errors : sum local = 6.0439e-09, global = -5.59866e-12, cumulative = 5.95127e-09
GAMG:  Solving for p_rgh, Initial residual = 0.00698256, Final residual = 5.85491e-05, No Iterations 1
time step continuity errors : sum local = 4.49712e-09, global = -5.51211e-12, cumulative = 5.94575e-09
GAMG:  Solving for p_rgh, Initial residual = 0.0069824, Final residual = 5.78619e-05, No Iterations 1
time step continuity errors : sum local = 4.44434e-09, global = -5.48796e-12, cumulative = 5.94027e-09
PIMPLE: iteration 2
smoothSolver:  Solving for alpha.water, Initial residual = 0.000121902, Final residual = 1.6192e-08, No Iterations 1
Phase-1 volume fraction = 0.998807  Min(alpha.water) = -3.99282e-05  Max(alpha.water) = 1.0022
GAMG:  Solving for p_rgh, Initial residual = 0.00811384, Final residual = 6.74661e-05, No Iterations 1
time step continuity errors : sum local = 5.17509e-09, global = -6.19006e-12, cumulative = 5.93408e-09
GAMG:  Solving for p_rgh, Initial residual = 0.00567394, Final residual = 5.06996e-05, No Iterations 1
time step continuity errors : sum local = 3.89126e-09, global = -6.66072e-12, cumulative = 5.92742e-09
GAMG:  Solving for p_rgh, Initial residual = 0.0056749, Final residual = 5.00646e-05, No Iterations 1
time step continuity errors : sum local = 3.84252e-09, global = -6.78585e-12, cumulative = 5.92063e-09
PIMPLE: iteration 13
smoothSolver:  Solving for alpha.water, Initial residual = 0.000127866, Final residual = 1.74908e-08, No Iterations 1
Phase-1 volume fraction = 0.998807  Min(alpha.water) = -3.99321e-05  Max(alpha.water) = 1.0022
GAMG:  Solving for p_rgh, Initial residual = 0.000100243, Final residual = 2.09242e-06, No Iterations 1
time step continuity errors : sum local = 1.60489e-10, global = 5.21436e-12, cumulative = 5.867e-09
GAMG:  Solving for p_rgh, Initial residual = 7.03431e-05, Final residual = 7.03431e-05, No Iterations 0
time step continuity errors : sum local = 5.39538e-09, global = 4.82634e-12, cumulative = 5.87182e-09
GAMG:  Solving for p_rgh, Initial residual = 9.12762e-05, Final residual = 9.12762e-05, No Iterations 0
time step continuity errors : sum local = 7.00093e-09, global = 4.70905e-12, cumulative = 5.87653e-09
PIMPLE: iteration 14
smoothSolver:  Solving for alpha.water, Initial residual = 0.000127844, Final residual = 1.74961e-08, No Iterations 1
Phase-1 volume fraction = 0.998807  Min(alpha.water) = -3.99317e-05  Max(alpha.water) = 1.0022
GAMG:  Solving for p_rgh, Initial residual = 0.00833255, Final residual = 7.07639e-05, No Iterations 1
time step continuity errors : sum local = 7.73113e-09, global = 3.59177e-12, cumulative = 5.88012e-09
GAMG:  Solving for p_rgh, Initial residual = 9.76716e-05, Final residual = 9.76716e-05, No Iterations 0
time step continuity errors : sum local = 1.06395e-08, global = 3.58804e-12, cumulative = 5.88371e-09
GAMG:  Solving for p_rgh, Initial residual = 9.81798e-05, Final residual = 9.81798e-05, No Iterations 0
time step continuity errors : sum local = 1.06949e-08, global = 3.58802e-12, cumulative = 5.8873e-09
PIMPLE: converged in 14 iterations
ExecutionTime = 4910.01 s  ClockTime = 4924 s
(...) somewhat later (...)
Courant Number mean: 0.000306073 max: 0.714215
Interface Courant Number mean: 9.84419e-05 max: 0.569494
deltaT = 5.05051e-05
Time = 0.00059596
PIMPLE: iteration 1
smoothSolver:  Solving for alpha.water, Initial residual = 0.0074356, Final residual = 3.97399e-06, No Iterations 2
Phase-1 volume fraction = 0.998806  Min(alpha.water) = -1.23599e-05  Max(alpha.water) = 1.00207
Phase-1 volume fraction = 0.998806  Min(alpha.water) = -4.58158e-05  Max(alpha.water) = 1.00207
GAMG:  Solving for p_rgh, Initial residual = 0.129127, Final residual = 0.000212159, No Iterations 2
time step continuity errors : sum local = 4.67654e-07, global = 7.36887e-09, cumulative = -4.99229e-06
GAMG:  Solving for p_rgh, Initial residual = 0.0877543, Final residual = 0.000138468, No Iterations 2
time step continuity errors : sum local = 3.02863e-07, global = 9.61841e-09, cumulative = -4.98267e-06
GAMG:  Solving for p_rgh, Initial residual = 0.0875758, Final residual = 0.000137868, No Iterations 2
time step continuity errors : sum local = 3.0156e-07, global = 8.63233e-09, cumulative = -4.97404e-06
PIMPLE: iteration 2
smoothSolver:  Solving for alpha.water, Initial residual = 0.00613058, Final residual = 1.74863e-05, No Iterations 1
Phase-1 volume fraction = 0.998807  Min(alpha.water) = -1.26977e-05  Max(alpha.water) = 1.00212
Phase-1 volume fraction = 0.998807  Min(alpha.water) = -6.83868e-05  Max(alpha.water) = 1.00212
GAMG:  Solving for p_rgh, Initial residual = 0.0505464, Final residual = 6.68601e-05, No Iterations 2
time step continuity errors : sum local = 2.59894e-07, global = 3.34174e-09, cumulative = -4.9707e-06
GAMG:  Solving for p_rgh, Initial residual = 0.034465, Final residual = 4.85242e-05, No Iterations 2
time step continuity errors : sum local = 1.8928e-07, global = 3.36974e-09, cumulative = -4.96733e-06
GAMG:  Solving for p_rgh, Initial residual = 0.0345989, Final residual = 4.83563e-05, No Iterations 2
time step continuity errors : sum local = 1.88649e-07, global = 3.38312e-09, cumulative = -4.96395e-06
smoothSolver:  Solving for alpha.water, Initial residual = 0.0113192, Final residual = 6.24306e-05, No Iterations 1
Phase-1 volume fraction = 0.998807  Min(alpha.water) = -1.2685e-05  Max(alpha.water) = 1.00215
Phase-1 volume fraction = 0.998807  Min(alpha.water) = -4.9255e-05  Max(alpha.water) = 1.00215
GAMG:  Solving for p_rgh, Initial residual = 0.148674, Final residual = 0.000165971, No Iterations 2
time step continuity errors : sum local = 5.6664e-07, global = -8.35275e-09, cumulative = -1.04967e-05
GAMG:  Solving for p_rgh, Initial residual = 0.102286, Final residual = 0.000144952, No Iterations 2
time step continuity errors : sum local = 4.96449e-07, global = -8.45179e-09, cumulative = -1.05052e-05
GAMG:  Solving for p_rgh, Initial residual = 0.102577, Final residual = 0.000146689, No Iterations 2
time step continuity errors : sum local = 5.02406e-07, global = -8.48205e-09, cumulative = -1.05136e-05
smoothSolver:  Solving for alpha.water, Initial residual = 0.014228, Final residual = 2.09971e-05, No Iterations 2
Phase-1 volume fraction = 0.998806  Min(alpha.water) = -8.81257e-06  Max(alpha.water) = 1.00188
Phase-1 volume fraction = 0.998806  Min(alpha.water) = -0.000130558  Max(alpha.water) = 1.00188
GAMG:  Solving for p_rgh, Initial residual = 0.151508, Final residual = 0.000260614, No Iterations 2
time step continuity errors : sum local = 4.66009e-07, global = -6.80941e-09, cumulative = -1.05205e-05
GAMG:  Solving for p_rgh, Initial residual = 0.098692, Final residual = 0.000171859, No Iterations 2
time step continuity errors : sum local = 3.03629e-07, global = -6.87803e-09, cumulative = -1.05273e-05
GAMG:  Solving for p_rgh, Initial residual = 0.0956707, Final residual = 0.000926545, No Iterations 1
time step continuity errors : sum local = 1.63263e-06, global = -6.69686e-09, cumulative = -1.0534e-05
smoothSolver:  Solving for alpha.water, Initial residual = 0.011516, Final residual = 6.20229e-05, No Iterations 1
Phase-1 volume fraction = 0.998806  Min(alpha.water) = -1.2695e-05  Max(alpha.water) = 1.0024
Phase-1 volume fraction = 0.998806  Min(alpha.water) = -5.29868e-05  Max(alpha.water) = 1.0024
GAMG:  Solving for p_rgh, Initial residual = 0.142777, Final residual = 0.000140118, No Iterations 2
time step continuity errors : sum local = 6.68283e-07, global = -8.67101e-09, cumulative = -1.05427e-05
GAMG:  Solving for p_rgh, Initial residual = 0.00973426, Final residual = 7.50726e-05, No Iterations 2
time step continuity errors : sum local = 3.65385e-07, global = -8.56944e-09, cumulative = -1.05513e-05
GAMG:  Solving for p_rgh, Initial residual = 0.00190305, Final residual = 6.0703e-05, No Iterations 1
time step continuity errors : sum local = 2.94961e-07, global = -8.5669e-09, cumulative = -1.05598e-05
ExecutionTime = 12492.6 s  ClockTime = 12544 s
It can be seen that successive iterations do approximately nothing, resulting in the PIMPLE loop not converging. During some timesteps, the p_rgh residual would remain as high as 0.1 after 200 iterations. Once this has happened, the PIMPLE loop would never converge (within 200 iterations) in future timesteps.
Given the number of iterations per pressure iteration (0~3), the trouble is not satisfying the pressure equation, but the combined Navier-Stokes equations (right?). In fact, it appeared to converge in the first few PIMPLE loops, but at some point during the PIMPLE iteration process the residuals increase again.
Question 1: Is it a good thing that p_rgh converges within only 0~3 iterations, or is it to be expected that more work should be done within one iteration?
Question 2: In the final PIMPLE iterations, no under-relaxation is used. It is then observed that the residuals do decrease rapidly. Does this imply convergence, despite PIMPLE having wasted 199 iterations doing virtually nothing? This is effectively like PISO, isn't it?
under-relaxation:
Using the much stricted residualControl of 1e-7, I had found that using an under-relaxation factor (urf) of 0.3 for p_rgh resulted in successive iterations doing approximately nothing. Reducing the urf to 0.1, resulted in converge after 130 iterations at first, 180 later, and no convergence (within 200 PIMPLE loops) at later timesteps. An urf of 0.01 is prohibitively low, resulting in effectively no convergence (i.e., too slow for 200 PIMPLE loops).
So the situation is similar to above log snippet.
momentum predictor:
Doesn't appear to do anything (w.r.t. convergence rate).
My net conclusion so far is that using maxCo=0.5 instead of maxCo=2 results in a considerably faster simulation. Perhaps it is just my case..., but I seem unable to get PIMPLE to be advantageous.
Question 3: Any further suggestions?
Thanks in advance.
Old   February 22, 2017, 15:17
piu58's Avatar
Uwe Pilz
I had a problem which may be similar. Te simulation crashes even with maxCo way below 1.
The reason for me was a (for the problem) too high value of delta T which induces instabilities during the first steps. The ode crashes much later however. If your simulations runs for a longer time, say for several minutes, it is nearly impossible to choose a delta T too low. The value rises to normal value fast.
arashgmn and breznak like this.
Uwe Pilz
Old   January 18, 2018, 16:38
Ali Noaman Ibrahim
alinuman15 is on a distinguished road
Dear All:-
I could not find any available online materials show any simple example explains with numbers how to use PIMPLE, SIMPLE, ...
Do you know any ?
Thanks!
alinuman15 is offline   Reply With Quote
Old   January 19, 2018, 01:06
piu58's Avatar
Uwe Pilz
You find material in
tutorials - incompressible - pimpleFoam/simpleFoam
Uwe Pilz
Old   January 19, 2018, 08:21
Ali Noaman Ibrahim
Thanks for replying....
What I meant is a problem explained step by step from scratch. For example:-
2D flow in a duct begins from meshing then finding pressure , velocity... etc
such that it would clearly describe how to use ( PIMPLE, SIMPLE, ...)
Old   January 19, 2018, 08:45
Ricky
Hallo Ali,
Have a look at this one.
Regards,
Ricky
alinuman15 likes this.
Old   January 19, 2018, 08:59
  #14
Ali Noaman Ibrahim
Hello Kera
Sure ... I did ( I have it since Tobi uploaded it ).
But, the example with numbers would make it 100% clear such that when you modify a solver ( for e.g.), you are knowing what you are doing. That is why, I tried to include a liking for that in this post.
Regards
Old   June 25, 2018, 13:31
MaryBau is on a distinguished road
It is an old post, but I am experiencing the same issues that Kevin mentioned on post #1 and #8 when using pimple.
1 ) Does anyone know why the initial residuals (and sometimes the final residuals too) for p_rgh barely improve for the successive iterations (nCorrectors)?
GAMG: Solving for p_rgh, Initial residual = 0.00557566000337, Final residual = 4.13416436153e-05, No Iterations 7
time step continuity errors : sum local = 1.36818393432e-06, global = 1.35803651052e-06, cumulative = 0.000284237003099
GAMG: Solving for p_rgh, Initial residual = 0.00553195761573, Final residual = 4.21402074553e-05, No Iterations 7
time step continuity errors : sum local = 1.36838503547e-06, global = 1.35803657001e-06, cumulative = 0.000285595039669
GAMG: Solving for p_rgh, Initial residual = 0.0055229245728, Final residual = 4.12094328509e-05, No Iterations 7
time step continuity errors : sum local = 1.3681490193e-06, global = 1.35803640209e-06, cumulative = 0.000286953076071
2) Why the pimple loop would sometimes randomly not converge, and use the maximum number of nOuterCorrectors iterations? I put nOuterCorrectors=250
I already checked my mesh and boundary conditions, I have also tried modifying the residualControl values and the relaxationFactors. And the Courant number is only 0.5!
Any advise?
Thanks!
MaryBau is offline   Reply With Quote
Old   July 11, 2018, 13:20
Iman Sabahi
i.sabahi is on a distinguished road
I really like this thread and I'm facing the same problem. Could someone with more experience enlighten us on how to use pimpleFoam the best way?
I personally have a theory tho, which might be wrong but i concluded it from my understanding:
In some simpler cases the BEST and fastest outer loops number is 1, what i mean is that the fastest algorithm is PISO and outer loop calculations in PIMPLE only slow down the problem.
Could this be true? Or there always is an optimum PIMPLE setup which is faster or the same speed as PISO?
Jo88 likes this.
i.sabahi is offline   Reply With Quote
Old   July 13, 2018, 13:10
Default PISO versus PIMPLE
  #17
Daniel Witte
danny123 is on a distinguished road
Since you asked:
PISO:
does repeat the prghEq loop. At the end of that inner prgh - loop, the velocity field is updated. But this has no impact if you just repeat the PISO loop (U is not used in prghEq). This is why in converges fast since it basically nothing is done. You achieve the same result by specifying a sufficient number of non orthogonal corrections.
PIMPLE: solves alphaEqn and sets up UEqn. So, w.o. PIMPLE, you do not solve your mass balance and the offdiagonal contribution of the momentum equation is not updated either.
To improve the PISO situation, I have pulled UEqn into the PISO loop. This allows to PISO to be of some use. It did not help the solver to converge faster though.
All equations are solved at least each time step. So, if you are looking for a non transient solution you are ok anyway. If not, you need PIMPLE.
Trouble is: OF does not plot out anywhere the error of the momentum equation. But you can plot out that error with some small customized coding. Otherwise you get Coloured Fluid Dynamics.
Regards,
Daniel
Santiago and randolph like this.
danny123 is offline   Reply With Quote
Old   December 4, 2018, 15:38
Default OpenFOAM tutorials
  #18
mszeto715 is on a distinguished road
Given that PIMPLE should be used with residualControl, it must be true that many of the tutorials in OpenFOAM are outdated. Am I right to think that?
Thanks.
-Mimi
mszeto715 is offline   Reply With Quote
Old   December 17, 2018, 14:17
Joaquín Aranciaga
joaran is on a distinguished road
Originally Posted by mszeto715 View Post
Thanks.
-Mimi
Hi, if my memory is working fine, I remember Jasak saying that tutorials are not 'fine tuned'. I've been working with older and newer OF versions, and this issue aplies regardless the version. So, I'd suggest you not to use them as a 'ready to go'.
Joaquin
joaran is offline   Reply With Quote
Old   December 17, 2018, 16:16
Santiago Lopez Castano
Santiago is on a distinguished road
Background:
Log file (snippet):
Time = 0.0035
PIMPLE: iteration 1
PIMPLE: iteration 2
PIMPLE: iteration 3
PIMPLE: iteration 4
Question:
Relevant Files:
controlDict:
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    location    "system";
    object      controlDict;
startTime       0;
stopAt          endTime;
endTime         0.070;
deltaT          1e-6;
writeInterval   5e-4;
purgeWrite      0;
writeFormat     ascii;
writePrecision  6;
timeFormat      general;
timePrecision   6;
adjustTimeStep  yes;
maxCo           2;
maxAlphaCo      2;
maxDeltaT       1;
libs
functions
fvSolution:
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    location    "system";
    object      fvSolution;
solvers
    "alpha.water.*"
        nAlphaCorr      2;
        nAlphaSubCycles 1;
        cAlpha          1;
        MULESCorr       yes;
        nLimiterIter    2;
        tolerance       1e-07;
        relTol          0;
    p_rgh
        solver          GAMG;
        tolerance       1e-08;
        relTol          1e-02;
        smoother        DIC;
        //nPreSweeps      0;
        //nPostSweeps     2;
        //nFinestSweeps   2;
        //mergeLevels     1;
    p_rghFinal
        $p_rgh;
        relTol          0;
    "pcorr.*"
        $p_rghFinal;
        tolerance       1e-04;
    U
        nSweeps         1;
    UFinal
        $U;
        relTol          0;
    "(k|B|nuTilda)"
        tolerance       1e-08;
        relTol          0;
PIMPLE
    nCorrectors     3;
    pRefPoint      (0 0 0);
    pRefValue      0;
    residualControl
        U
                tolerance  1e-06;
                relTol     0;
        p_rgh
                tolerance  1e-07;
                relTol     0;
relaxationFactors {
   fields
       p_rgh        0.3;
       p_rghFinal   1;
   equations
fvSchemes:
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    location    "system";
    object      fvSchemes;
ddtSchemes
    default         Euler;
gradSchemes
divSchemes
laplacianSchemes
    default         linear;
snGradSchemes
    default         corrected;
wallDist
    method meshWave;
Thanks in advance.
You use the SIMPLE loops (or as you call them, outer) in an attempt to stabilize (make the simulation more robust) the run by introducing artificial viscosity via a relaxation flux. Is important to recall that some of the time schemes in OF add some sort of numerical flux in the convective term. Thus, repetitive SIMPLE iterations will add to this spurious flux. Note that This "error" is inversely proportional to delta t. In an orthogonal grid, such flux may become a 'false friend' if your Co becomes too small. So, if your grid is not bad, Why do you need more than one SIMPLE loop?
Santiago is offline   Reply With Quote
pimple
PIMPLE – the value of the final under-relaxation factor Zbynek OpenFOAM 9 December 22, 2023 06:26
pimpleDyMFoam computation randomly stops babapeti OpenFOAM Running, Solving & CFD 5 January 24, 2018 06:28
error while running modified pimple solver R_21 OpenFOAM Programming & Development 0 May 28, 2015 07:59
A question on the PIMPLE algorithm GerhardHolzinger OpenFOAM Running, Solving & CFD 4 February 13, 2015 07:49
Help for the small implementation in turbulence model shipman OpenFOAM Programming & Development 25 March 19, 2014 11:08
