February 13, 2017, 13:37 |
Opening temperature
alberto
Rep Power: 10 |
Hi.
I am trying to simulate natural convection inside a pipe. The boundary conditions are as follows: The pipe is divided into three parts, - The middle one has a temperature of 1300 - The others are adiabatics - The sides are OPENINGS, can be inlet or/and outlet How can i put this openings boundary condition in U and P_pgh? How can i put the OPENING TEMPERATURE without force the flow, i mean, without fixed the outflow temperature on that side; like wall temperature been an opening. On ANSYS CFX i can put this boundary condition definining an opening and one opening temperature. Thanks for your time. |
February 27, 2017, 11:27 |
Joachim Herb
Rep Power: 22 |
You are looking for the inletOutlet boundary condition.
February 28, 2017, 04:15 |
Rep Power: 12 |
Hello Alberto and Joachim,
I am not sure that this is right. With inletOutlet Alberto would have to specify the inflow temperature as a scalar. But how should he know the value? What about zeroGradient? Best regards, Kate |
March 2, 2017, 18:24 |
Joachim Herb
Rep Power: 22 |
I think this is exactly, what inletOulet boundary does. For outward flow direction it behaves like zeroGradient. For inflows you set the temperature with inletValue.
March 9, 2017, 16:02 |
alberto
Rep Power: 10 |
Hi i have another question, i am trying to simulate a water in a vertical pipe as in pictures, in the middle of the pipe i have a wall some temperature hotter than the water, can you tell me what am i doing wrong? the water dosnt heat passing the wall hot, i dont know what TEMPERATURE Bc i have to put at outlet in order to dont force this.
If i put a fixed value, i am forcing the outlet temperature right? and i dont want that.i already try with zeroGradient. I want the temperature of the water heated. thanks for you answer. |
March 16, 2017, 04:00 |
#6 | |
Rep Power: 12 |
Hola Alberto,
have you applied fixedValue at the inlet and at the walls? What happened when you tried zeroGradient at the outlet? Best regards, Kate Quote:
[ANSYS Meshing] Fluent Conjugate heat transfer: Temperature at a small fluid region exceed limit | RPjack | ANSYS Meshing & Geometry | 1 | June 20, 2019 08:11 |
Static temperature and Total temperature | Jong-Yoon | FLUENT | 0 | September 25, 2016 02:42 |
Inlet won't apply UDF and has temperature at 0K! | tccruise | Fluent UDF and Scheme Programming | 2 | September 14, 2012 07:08 |
difference of temperature | HKH | FLUENT | 0 | January 28, 2010 03:45 |
monitoring point of total temperature | rogbrito | FLUENT | 0 | June 21, 2009 18:31 |
