Creating Patch inside the domain
Old   February 8, 2017, 02:26
Default Creating Patch inside the domain
vidyadhar
vidyadhar is on a distinguished road
Hello All,
In my case, I want to create a patch for injecting particles. This, I am able to do using createPatchDict on the boundary faces.
But, I want to have this injection patch interior of my domain. I could not achieve this using createPatchDict as it creates patches on existing boundary faces.
I request you to please let me know if there is a way to create a patch inside the domain.
Thanks & Regards,
vidyadhar
vidyadhar is offline   Reply With Quote
Old   February 8, 2017, 04:19
floquation's Avatar
Kevin van As
floquation will become famous soon enough
Don't ask the same question three times... You're wasting our times.
Have a look at "CellZoneInjection" and "cellSet"s.
floquation is offline   Reply With Quote
Old   February 9, 2017, 07:50
vidyadhar
Dear Kevin,
Thank you for the reply.
I tried to construct the cellZoneInjection Model following your suggestion.
I am facing the following problem. I request you to help me solving this problem, if possible. (I am using "Caelus" which is very much similar to openFoam)
Part-Output of the log file
Constructing particle injection models
Creating injector: model3
Selecting injection model cellZoneInjection
Constructing 3-D injection
Selecting distribution model fixedValue
cell zone size = 3610
cell zone volume = 6.041191959e-09
--> CAELUS Warning :
From function CML::CellZoneInjection<CloudType>::updateMesh()
in file lagrangian/intermediate/lnInclude/CellZoneInjection.hpp at line 397
Number of particles to be added to cellZone particle_INLET1 is zero
The injection model in my particle Cloud properties file is like below:
model3
type cellZoneInjection;
cellZone particle_INLET1;
SOI 0.0112; // Start Of Injection
flowRateProfile constant 1; // Flow rate profile relative to SOI
massTotal 3.4746e-08; // Total mass injected over injection duration
parcelBasisType mass; // How are the number of particles calculated
duration 1.2; // Duration of injection. NOTE: set to 1 for steady state
U0 (0 0 0.04175); // Initial parcel velocity
numberDensity 500; //Number density of particles in cell set (effective)
nParticles 500; //I am trying these options to check if particles are getting injected or not
nparcels 500;
//I am trying these options to check if particles are getting injected or not // parcelsPerSecond 4167; // Number of parcels to introduce per second
sizeDistribution
type fixedValue;
fixedValueDistribution
value 0.48e-03;
I have used toposetDict to create the cellZone:
actions
name particle_INLET1cellSet;
type cellSet;
action new;
source boxToCell;
sourceInfo
box (-0.0036 0.0012 -0.0125)(-0.0012 0.0036 -0.0115);
name particle_INLET1;
type cellZoneSet;
action new;
source setToCellZone;
sourceInfo
set particle_INLET1cellSet;
I am missing some keyword(for adding no.of particles to the cellZone
) in the injection model.
Thanks in advance,
Regards,
vidyadhar
Old   August 21, 2019, 07:48
Khaled Yassin
Yassin-K is on a distinguished road
You can create baffles and then use one of the two cyclic patches as an injection patch
How to create baffle?
Yassin-K is offline   Reply With Quote
[Other] Wedge patch '*' is not planar LilumDaru OpenFOAM Meshing & Mesh Conversion 7 September 18, 2024 06:52
Floating point exception: Zero divide liladhar CFX 11 December 16, 2013 05:07
Cyclic Boundary Condition Luiz Eduardo Bittencourt Sampaio (Sampaio) OpenFOAM Running, Solving & CFD 36 July 2, 2012 13:23
[blockMesh] Cyclic BC's: Possible face ordering problem? (Channel flow) sega OpenFOAM Meshing & Mesh Conversion 3 September 28, 2010 13:46
[Gmsh] Import gmsh msh to Foam adorean OpenFOAM Meshing & Mesh Conversion 24 April 27, 2005 09:19
