Problem in temperature profiles while using rhoSimpleFoam for Nozzle case
Old   February 4, 2017, 06:04
Default Problem in temperature profiles while using rhoSimpleFoam for Nozzle case
Nik_04 is on a distinguished road
Hello every one.
I am trying to simulate nozzle flow (M_exit=0.9) open to atmosphere using rhoSimpleFoam (RANS Std k-epsilon, compressible solver).
I have created mesh using Gmsh software. I tried various boundary conditions e.g, keeping Fixed Pressure, temperature and velocity at inlet
and zerogradient at outflow. Or total pressure and temperature b.c. at inlet and z.g. at outflow etc.
But in all the cases I am getting constant temperature and density profile (along the axial direction) within the nozzle.
It's obviously not matching with the theoretical temperature .
More over it's not even matching with P/rho*R (Ideal gas equation).
I don't know what's going wrong. I have tried different boundary conditions.
It will be great if any one of you have some insight/suggestions that I can try .
I am attaching the temperature profiles which i got more or less same for different boundary conditions
File Type: png Temp_Ma_comp_theoVsrhoSimpleFoam_new.png (8.9 KB, 21 views)
Nik_04 is offline   Reply With Quote
nozzle, rhosimplefoam, temperature contours
What free stream/bulk temperature to take in this case? Thomasbr Main CFD Forum 3 August 11, 2016 04:59
Problem in temperature distribution in Ansys Fluent ALI Riaz FLUENT 0 March 6, 2016 14:05
simulation problem -- convection BC pras FLUENT 4 January 30, 2013 11:41
Problem when adding temperature to interFoam houkensjtu OpenFOAM 4 November 5, 2012 03:35
Problem with rhoSimpleFoam : exploding enthalpy and density at the walls david39 OpenFOAM Running, Solving & CFD 6 January 18, 2011 12:49
