error while running circCylinder3d tutorial case in foam-extand 3.1
Old   February 3, 2017, 12:48
Default error while running circCylinder3d tutorial case in foam-extand 3.1
ZHENKAI ZHAO
zhaozhenkai is on a distinguished road
I am trying to address large mesh deformation with tet mesh.
I have searched the web and found that dynamicTopoFvMesh working with mesquiteMotionSolver should be able to replace my current motion solver
"displacementSBRStressFvMotionSolver". I have installed foam-extend 3.1 and ran the tutorial case for dynamicTopoFvMesh: circCylinder3d. But after when T = 1.1s, the process stopped with an error like below:
--> FOAM FATAL IO ERROR:
size 104 is not equal to the given value of 105
file: IStringStream.sourceFile::topWall from line 2 to line 11.
From function Field<Type>::Field(const word& keyword, const dictionary&, const label)
in file /home/zzkzzk2015/foam/foam-extend-3.1/src/foam/lnInclude/Field.C at line 239.
FOAM exiting
I have checked the moving patch data in each time step and found the elements of the patch is 104. But why the elements at T = 1.1s suddenly changes to 105?
Or probably I have used the wrong version of foam-extend?
I am completely new the foam-extend. I hope someone can give me some clues so that I can have an access to the problem.
Thanks a lot
ZHENKAI
zhaozhenkai is offline   Reply With Quote
[DesignModeler] DesignModeler Scripting: How to get Full Command Access ANT ANSYS Meshing & Geometry 53 February 16, 2020 16:13
[blockMesh] BlockMesh FOAM warning gaottino OpenFOAM Meshing & Mesh Conversion 7 July 19, 2010 15:11
gmsh2ToFoam sarajags_89 OpenFOAM 0 November 24, 2009 23:50
Free surface boudary conditions with SOLA-VOF Fan Main CFD Forum 10 September 9, 2006 13:24
