displacementSBRStress motion solver with large rotation suddenly blow up |
January 25, 2017, 08:06 |
ZHENKAI ZHAO
Rep Power: 11 |
Hi, guys,
i am doing a validation on two ellipses connected by a spring with prescribed motion. I have used displacementSBRStress motion solver to solve that motion. However, something strange happened. When the structure moves to some point, The running process suddenly blow up with no apparent mistake. I have checked the mesh quality, At the final step, it was like below: Checking geometry... Overall domain bounding box (-2 -2 0) (2 2 0.1) Mesh has 2 geometric (non-empty/wedge) directions (1 1 0) Mesh has 2 solution (non-empty) directions (1 1 0) All edges aligned with or perpendicular to non-empty directions. Boundary openness (2.398513805e-20 -4.756716453e-20 -5.284828887e-16) OK. Max cell openness = 2.186121641e-16 OK. Max aspect ratio = 4.022298722 OK. Minimum face area = 1.081512183e-08. Maximum face area = 0.007040362657. Face area magnitudes OK. Min volume = 1.081512183e-09. Max volume = 0.0001002957823. Total volume = 1.599918303. Cell volumes OK. Mesh non-orthogonality Max: 56.26661203 average: 16.10019355 Non-orthogonality check OK. Face pyramids OK. Max skewness = 0.5278265916 OK. Coupled point location match (average 0) OK. Mesh OK. there is also no rising residuals or force fluctuation. I have also attached the mesh formation for the final step. I doubt the problem is about the mesh quality, So I just decreased the prescribed rotational angle and it can run with no problem. But I cannot understand why for the large rotational angle, there is a mesh quality problem. Does it mean the checkMesh function is not enough to check out all the mesh problem or there are other problems existed in my case that i have not found? Or can you guys recommend some motion solvers that can deal with large mesh deformation, especially with large body rotation? PS: I have attached the initial conditions as well. If you need other information, please tell me. Thanks a lot for any help provided. ZHENKAI |
sliding mesh problem in CFX | Saima | CFX | 46 | September 11, 2021 07:38 |
mesh quality problem for displacementSBRStress motion solver | zhaozhenkai | OpenFOAM | 0 | January 22, 2017 11:02 |
Star cd es-ice solver error | ernarasimman | STAR-CD | 2 | September 12, 2014 00:01 |
Large sparse solver | Abeer | Main CFD Forum | 0 | September 18, 2002 04:18 |
solver for linear system with large sparse matrix | Yangang Bao | Main CFD Forum | 1 | October 25, 1999 04:22 |
