Large particle problem
Old   January 24, 2017, 11:03
Default Large particle problem
CCB
weeBlueGalaxy is on a distinguished road
Hey
I have been having issues with simulating a simple pseudo 2D fluidized bed, similar to the tutorial cases provided. The solver I am using is twoPhaseEulerFoam on v2.3.x of OpenFOAM.
I am trying to simulate rather large particles (2.5mm) and have found that in my set up they do not fluidize at any velocity, also the results show that the particles have no velocity what so ever. this can be seen in case A.
I then used the original tutorial case (case B) with only changing the following:
u.air inlet uniform 3.5m/s
solid density 2526kg/m^3
particle diameter 2.5mm
Adjustable time step
This resulted in the solid phase to fluidize correctly.
I am having trouble seeing what could be causing the problem between these 2 cases.
Hope you can help
weeBlueGalaxy is offline   Reply With Quote
Old   January 24, 2017, 11:05
CCB
sorry forgot Case B
Particle tracking error alchem OpenFOAM Bugs 5 May 6, 2017 17:30
Problem with porous flow at multi-material interface with large permeability diff. Hisham OpenFOAM Programming & Development 1 June 3, 2016 11:51
forced to sticking of soot particle kmgraju CFX 0 November 27, 2012 10:08
solver stop problem in Lagrangian Particle Tracking sakurabogoda CFX 3 October 5, 2012 07:09
massless particle tracking problem Renold FLUENT 0 January 26, 2011 15:23
