Rep Power: 12 ![]() |
Hello Foamers,
I'm trying to symulate a vertical beam a cross flow, where the flow is driven by a volume force and the boundary condition in the fluid domain are cyclic. I've started from the beamInCrossFlow tutorials in the FSI package fro the foamextended 4 and I succesfully added the source term for the fluid equtions, but I have problems whith the cyclic conditions. After setting the inlet-outlet cycling bc, when I lunch the fsiFoam solver I get this error: """ Code:
Create time Create dynamic mesh for time = 0 Selecting dynamicFvMesh dynamicMotionSolverFvMesh Selecting motion solver: displacementLaplacian --> FOAM FATAL IO ERROR: keyword global is undefined in dictionary "/beam2/fluid/0/pointDisplacement::boundaryField" I think that the problem is somehow in the cyclic condition in the fail pointMotionU. Someone of you has some experience about this kind of problems ? Thank you in advance |
Actually I have managed to correct the error about the global patch (it was a different way to define cyclic patch in foamextended that of).
But after the first iteration the solver blow-up because the patch in the direction of fluid are not constrained (i guees) because in the pointMotionU I have to set the bc as cyclic. So anyone have a motion solver that will do the job ? |
cyclic, fsi, velocitylaplacian |
fsi analysis using fluent and boundary condition problem | peymandsr | FLUENT | 0 | November 1, 2016 10:54 |
Ramping Boundary Condition for Steady FSI Simulation | ashtonJ | CFX | 3 | August 21, 2012 03:18 |
Problem with FSI Boundary Condition | ashtonJ | CFX | 6 | June 28, 2012 04:28 |
Intial Condition in FSI Modelling | ashtonJ | CFX | 0 | June 1, 2012 05:00 |
problem with boundary condition??? | smn | CFX | 5 | November 24, 2009 06:37 |
