multiphaseEulerFoam running in serial but crashing in parallel
Old   January 20, 2017, 11:38
Default multiphaseEulerFoam running in serial but crashing in parallel
BlnPhoenix is on a distinguished road
I'm running a three phase simulation with multiphaseEulerfoam. The case runs in serial but crashes in parallel using the "scotch" decomposition method. A should also mention that i use a MRF for rotation in my domain.
What can cause the crash in parallel? I'm confident that BC etc. are correct since they do just fine in serial.
BlnPhoenix is offline   Reply With Quote
Old   May 4, 2017, 04:40
For there may be someone in the future with similar problems. Check whether you recently changed your RAM. I doubled my RAM but had to use the smaller voltage of the two. This instabilty made OpenFoam crash in parallel i supose.
Error running simpleFoam in parallel Yuby OpenFOAM Running, Solving & CFD 14 October 7, 2021 05:38
error while running in parallel using openmpi on local mc 6 processors suryawanshi_nitin OpenFOAM 10 February 22, 2017 22:33
Fluent 14.0 file not running in parallel mode in cluster tejakalva FLUENT 0 February 4, 2015 08:02
Running CFX parallel distributed Under linux system with loadleveler queuing system ahmadbakri CFX 1 December 21, 2014 05:19
Problem in Running OpenFoam in Parallel himanshu28 OpenFOAM Running, Solving & CFD 1 July 11, 2013 10:19
