Floating point exception,anybody can help me see is there anything wrong?
Old   January 16, 2017, 15:02
Question Floating point exception,anybody can help me see is there anything wrong?
Meng Zhang
zhangchuhan33 is on a distinguished road
Hi all,
Is there anybody to check what's the problem with this case? I provide the basic setup parameters of this case.
The terminal appears :
DILUPBiCG: Solving for Ux, Initial residual = 0.99000642, Final residual = 6.8541306e-08, No Iterations 4
DILUPBiCG: Solving for Uy, Initial residual = 0.99716613, Final residual = 6.9062653e-08, No Iterations 4
GAMG: Solving for p, Initial residual = 0.99962119, Final residual = 0.025839189, No Iterations 2
time step continuity errors : sum local = 0.93527788, global = 0.36717821, cumulative = 0.36824128
DILUPBiCG: Solving for thetaxx, Initial residual = 0.99220779, Final residual = 2.9157135e-07, No Iterations 3
DILUPBiCG: Solving for thetaxy, Initial residual = 0.98351029, Final residual = 1.6324874e-07, No Iterations 3
DILUPBiCG: Solving for thetayx, Initial residual = 0.98351029, Final residual = 1.6324874e-07, No Iterations 3
DILUPBiCG: Solving for thetayy, Initial residual = 0.92808389, Final residual = 1.7059121e-08, No Iterations 4
DILUPBiCG: Solving for thetazz, Initial residual = 0.048199694, Final residual = 2.7407462e-07, No Iterations 4
Recover Conformation Field
#0 Foam::error:rintStack(Foam::Ostream&) at ??:?
#1 Foam::sigFpe::sigHandler(int) at ??:?
#2 ? in "/lib/x86_64-linux-gnu/libc.so.6"
#3 ? in "/lib/x86_64-linux-gnu/libm.so.6"
#4 exp in "/lib/x86_64-linux-gnu/libm.so.6"
#5 Foam::exp(Foam::Field<double>&, Foam::UList<double> const&) at ??:?
#6 Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > Foam::exp<Foam::fvPatchField, Foam::volMesh>(Foam::tmp<Foam::GeometricField<doub le, Foam::fvPatchField, Foam::volMesh> > const&) at ??:?
#7 Foam::Oldroyd_B_L::correct() at ??:?
#8 ? at ??:?
#9 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6"
#10 ? at ??:?
Floating point exception (core dumped)
These are boundary conditions of u and p
The u boundary condition is that
inlet
type fixedValue;
value uniform (1 0 0);
outlet
type zeroGradient;
wall
type fixedValue;
value uniform (0 0 0);
The p boundary condition is that
boundaryField
inlet
type zeroGradient;
outlet
type fixedValue;
value uniform 0;
wall
type zeroGradient;
There are some other information of this case
delta T 1e-4
mesh min volume 0.0029
inlet width 1
inlet velocity 1
This case is a very easy case to calculate the flow pattern of 2 dimensions of square tube . We give the inlet a rate of flow , use the pressure as the driven source .
Question:
What does that terminal appearance mean? What's wrong with this case?
Thank you all.
zhangchuhan33 is offline   Reply With Quote
boundary conditons, floating point exception
Floating point exceptions with own modified k-omega SST with Reboud's correction A_Pete OpenFOAM Programming & Development 3 October 18, 2016 02:45
[snappyHexMesh] How to define to right point for locationInMesh Mirage12 OpenFOAM Meshing & Mesh Conversion 7 March 13, 2016 15:07
pimpleDyMFoam constantly giving floating point exception and solution divergence fedvasu OpenFOAM Running, Solving & CFD 0 November 28, 2013 01:53
[snappyHexMesh] determining displacement for added points CFDnewbie147 OpenFOAM Meshing & Mesh Conversion 1 October 22, 2013 10:53
Floating point error and divergence detected aannjj FLUENT 0 July 2, 2013 04:44
