Question about number of non-orthogonal correctors |
January 13, 2017, 07:41 |
Felix
Rep Power: 11 |
Hello everyone.
My current set of simulations does need a high number of non-orthogonal correctors (about 10 per pimple iteration). Is it possible to create a number of non-orthogonal correctors for the pressure which is changing with the number of the pimple iteration? That means my 1st pimple itertion has 5 n.-o. correctors and my 2nd 10 n.-o. correctors. |
January 13, 2017, 09:24 |
Arvind Jay
Rep Power: 15 |
Why do you need so many nNonOrthogonalCorrectors for? Is your mesh Mesh non-orthogonality > 80 deg?
Cheers, |
January 13, 2017, 10:10 |
Felix
Rep Power: 11 |
yes my geometrie does need it, because im using mergepatchpairs for my geometrie to combine two cylinders.
Well i just want to know if its is possible to create different numbers for the No Correctors in different pimple Iterations. |
correctors, fvsolution, incompressible, pressure |
decomposePar problem: Cell 0contains face labels out of range | vaina74 | OpenFOAM Pre-Processing | 37 | July 20, 2020 05:38 |
[snappyHexMesh] Error snappyhexmesh - Multiple outside loops | avinashjagdale | OpenFOAM Meshing & Mesh Conversion | 53 | March 8, 2019 09:42 |
ERROR #001100279 has occurred in subroutine ErrAction. | smnaryal | CFX | 11 | December 20, 2017 16:32 |
DPMFoam - Serious Error --particle-laden flow in simple geometric config | benz25 | OpenFOAM Running, Solving & CFD | 27 | December 19, 2017 20:47 |
SigFpe when running ANY application in parallel | Pj. | OpenFOAM Running, Solving & CFD | 3 | April 23, 2015 14:53 |
